2.4 turbo build (for the haters! )
LMMFAO!!Wow is all I got to say.I'm not even going to waste anymore energy typing than what I already have haha.Some peoples children.07Cobaltguy,Get some stickys's and pop off that 12 and shut some people up for god sakes lol.I will also do the same in my 2.2
Wow what? I don't see what's funny.
Did I say he was wrong? I don't think so. I asked for time slips,he showed me and I didn't say anything else.
Last edited by chevygirl2006; Oct 22, 2012 at 03:34 AM. Reason: Automerged Doublepost
oh and i saw a few people commenting saying to get an oil restrictor ..i was thinking that but wouldnt get something generic like ebay has ide like to try and match up a good size according to our oil pressure .. also ..its a wet float bearing turbo..correct me if im wrong but i thought u didnt have to run a restrictor on a floating bearing because u want the bearings to have enouph pressure to hold them up(like rod and crank bearings)..hence "wet float".. soo if i do need one what size..ide assume something kinda bigger..just a little restriction..cuz i think those restrictors ebay sells r pretty small..for ball bearing turbos ..just my basic understanding of all this any1 know more please correct me
http://s1294.beta.photobucket.com/us...ff206.jpg.html
heres everything together..i will be buying a tial .38 mm wastegate at a local spot the day i start (save on shipping
and havent gotten the oil feed flange for the turbo yet bcuz i was still up in the air on oil restrictor or not…in this picture is
ebay turbo .57 trim t3/y4
zzp exhaust mani
#60 injectors
zzp 2bar map sensor
zzp bov and pipe for vband
10 AN oil drain line and turbo flange with fitting
oil pan from zzp pre welded in a bung
innovative wideband controller and gauge
ebay boost gauge
ebay intercooler
4AN feed line
oil feed fitting
..oh and right next to the zzp mani is the old ebay one..its dirt but put in the picture for reference (not using!)
and ebay downpipe wanna b lol ..i guess ill use that as a start for the downpipe ..weld to the flange looks good
close up of the ebay mani..u can slightly see where i started to bore out the holes cuz it didnt quite fit..but after i saw how close to the sides i was getting and that i souldnt have to be modifying a exhaust manifold that should fit lol ..i quit and got the zzp
IMG_1394_zpsd8415238.jpg picture by niconegron1 - Photobucket
IMG_1396_zpsed092778.jpg picture by niconegron1 - Photobucket
looking down the exhaust side of the turbo
ebay piping,cuplers,filters
IMG_1397_zps18d0dde9.jpg picture by niconegron1 - Photobucket
when you copy the image code you dont need to do anything other than paste it. with direct link you have to go into advance options and press the image link button then paste it there
