E-Brake
Old Oct 8, 2007 | 09:52 PM
langzhihun's Avatar
E-Brake
Hey i gotta question about my E brake. It sux, how can i fix it? I was told that since the car is disk brakes all around that you can't make the E brake grab any better. I thought that was pretty much BS...
Old Oct 8, 2007 | 09:56 PM
SSRich's Avatar
i have that same problem on my silverado when i push down the e brake like on a little hill (that i tried it out on) it just started rolling off.
wordsthatiwrote's Avatar
I read this in a post. " Imports have Emergency brakes. Domestics have Parking Brakes. Its not meant for us to stop. Just to take the stress off the tranny when you park"
Old Oct 8, 2007 | 09:58 PM
tombomb's Avatar
i have the same problem, is there a way to tighten the cable, because i HAVE to put it in first otherwise it will start rolling...its rediculus...
Old Oct 8, 2007 | 10:30 PM
cruisn's Avatar
if you pull to hard on it, the bracket that holds the cable in the centre consol will jsut break, had it happen 4 times. car barely holds itself back on a slight hill and any tighter and **** will break again. gonna tear into it at work sometime and see if I can beef it up a bit to hold better
Old Oct 9, 2007 | 12:55 PM
rcmpayne's Avatar
Get a hydraulic e-brake that’s what drifters use, had one on my berretta,
And the cable doesn’t usually break it’s the joiner in the back. You can get bigger assemblies to upgrade them
Or search Google for e-brake mods
g5mike
Sep 24, 2007 09:27 PM
blackphoenix
Mar 3, 2007 08:03 PM
qcpursuit
Mar 20, 2006 08:20 AM
Shamrock
Nov 30, 2005 08:39 AM
