Freshly installed ZZP SC Kit, cranks but won't fire
The performance shop that is going to clear my Crank Relearn DTC has a dyno...I'm curious of course but I may forgo the rollers for now as my ass dyno doesn't lie. I'm older, so it isn't a burning priority to know exact #s...I mainly did this so passing someone wasn't a prayer followed by a roll of the dice.
Mission accomplished!
Stock 3.4 ZZP pulley. Steve figures my PCM somehow kept the factory 6750rpm oil temp cutout, my core return is going to be retuned and then sent back to me and that should be that. Very annoying when it kicks in (or out, depending on semantics) but better than my old Spec-V 6spd 2-3 grind.
yay for me on being correct on the injector call!!! im glad u finally got it running...i am still trying to get my hazard of a car running right...its becoming rediculous...jacked up tune...jacked up supercharger...jacked up computer...zzp really screwed me over on this one!!!
Good to hear. Definitely would like to see a dyno of your car. Are you on the stock zzp stage 1 pulley? And have you and zzp figured out why your bouncing off the limiter between gears? (though I can occassionally catch my car off gaurd and do this going from 1st to 2nd with my auto)
Interesting, I went to start the car today and I've got a power steering flashing on the DIC and all but the coolant temp are showing dashes as I scroll through. No mileage, avg. fuel consumption, avg. speed, its all gone.
Steering feels heavy, as I test drove it to see just wtf was going on...seems like it is loath to up shift.
Going to pull the negative on the battery later and try again...sigh.
Yeah...I'm at the point where I'm going to ask ZZP for a discount on the HPTuners, as they sell it.
Checked the 60amp fuse for the power steering, it is good. damn!
Good idea Cordia, guess I took the term 'kit' a little too literal...it will get you 85-90% of the way there.
She's pooched, one bad PCM that ZZP needs to do some diagnostics on for sure as according to my research all these newest problems of today are PCM related. No matter, a new one was mailed to me last week and should be arriving shortly. Gawd let it be done with there and then.
Interesting, the shift lock on my tranny (the one that disengages when you press the brakes to shift out of park) is now clicking every time I brake...I keep my right hand on the shift lever and can hear and feel it every time. Its like the pcm has a gremlin in it, changing values and wiping data. I had a suspicion when it wouldn't start for as long as it did, and the fact that it was flashed with the same code used in their test mules and yet shifted differently in mine that something wasn't quite 100%. Code is code, if a value is set at 7k and flashes into the pcm as 6750, somewhere within is a bad sector/corrupted eprom addy or whatever.
Sweet throw up a new video! Im interested to see how it runs! Ive been wanting to do this but the current debate over the 08 rods has me thinking about just staying with a larger pulley so I want to see how yours runs on the larger pulley (I was thinking of going 2.8)
Glad to hear you got everything in order! I'm still slowly trying to fix all my problems...have to replace the coupled in the sc and get a new tune and find my boost leak and ill be good to go too!
Git'er done Navy Man...brave of you to guinea pig the stage 2, I deliberately stayed away to let them teethe the bugs out and I'll upgrade once I hear some positives.
I'm lazy, still haven't gone to clear my crank code. I've got winter tires on now by law and that takes the fun out of driving as I can light these puppies up at almost 50mph, not meant for performance.
Had a couple drives, the tune is much better. How much better I can't say as the weather has been wet, cold, snowy and downright unbecoming to having a bit of fun.
New vids are on the menu Cordia, I'll post them here after the storm clears and I'm able to do some highway merges @ WOT.
when i got my ecu back from hahn i had to do my timing because my ecu didnet rember were my engin had stoped you will need to plug it into the gm obd scanner and find out crack position
(P0315-Crank Position System Variation not learned) is the code you will get
Turbo Johnny
Feb 21, 2019 09:41 AM
