How much boost
How much boost
Alright guys I have looked for the answer for a few days and I see tons of different answers. I hope I can get help from some of u guys that have done it.
I have 2.4 cobalt its auto and supercharged. Im putting on the 42lb injectors and going to the 3.1 pulley. I want to know what is too much for PSI to run on my car. I dont want to blow a piston or anything. So I wanna know what my limit is later in the summer im going to get header/DP and exhaust on so I also want to know if that will be too much. I saw geneculley talking about not going over 250 before forging ur pistons.
I posted in the forced induction and no one replied. So hopefully I get some help here. I wanna get 10 PSI but dont wanna push it.Please guys I need some advice im getting this done this week coming up. Also im at higher elevation does that play a role?
What are your numbers? if you dont mind me asking. Cause I heard geneculley blew a piston but I think that was at 300 whp. As this is my dd i dont wanna lose it for a while.
Can u explain a lil more please? Im sorry if I sound dumb but this is my first time with anything to do with a car like this and I figure ask questions and listening is the best way to learn. My car is said to be 171 hp and 163 stock.... so I figured with 8-10 PSI i could get 230 whp.
So say you and Glowbalt had the exact same car, engine, and setup .... If you had a free flowing exhaust, and he didnt, your boost level would be lower. You would be in turn making more power than him, but at a lower boost level.
Being that you live in a much higher elevation than most of us you may need to use a slightly smaller pulley to make the power of a car closer to sea level. So, Glowbalt wasnt totally incorrect. Anything is possible with a good tune though.
alright if I dont make those numbers its ok it gives me room to work with! Later this year I will be ordering Header/DP and full catback exhaust from zzp and should be near or close. to what I want either way I feel alot better now! thanks.
