How much can a 2.4L boost safely?
Old Dec 3, 2007 | 04:11 PM
  #51
REDFOCZ's Avatar
wow that is a differnt looking HHR, glad to hear you got it runnig right.
Old Dec 3, 2007 | 04:17 PM
  #52
Quasimotor's Avatar
Well I did have it running right. I swapped pulley's, then put a header on a couple of nights ago, so I'm back to the drawing board.
I posted over at HPT RED, I dunno if you have any input or not there?
Jim
Old Dec 3, 2007 | 04:21 PM
  #53
chevysalesman614's Avatar
HHR on baby moons? awesome. my pops has them on his pt cruiser. you've gotta be a baby boomer.
p.s. that front end is very well done. its got a nice classic look to it.(you custom fab that? or is it a kit one could buy?) i would look into some lowering springs soon, if it was me.. then the appearance would be complete.
Old Dec 3, 2007 | 04:24 PM
  #54
Quasimotor's Avatar
Talking
Nope, I was just going for a 49 chevy look. I have a set of 17 inch wheels with P-Zeros for it too, these are my everyday burners though.
Jim
Old Dec 3, 2007 | 06:23 PM
  #55
pjk91's Avatar
Originally Posted by Quasimotor
Your not running the 2.5 bar Map? I guess you can tune without the map, but it's nice to see what happens with PE when the boost comes in.
Jim
No, no map. I have the tMap ready to go, but I haven't had time to bring it down to my tuner to do it up. I don't want to mess with it, and for the time being it is running OK.
How does that GMPP intercooler work? I have the Cobra HE...but the intercooler?
Old Dec 3, 2007 | 06:37 PM
  #56
Quasimotor's Avatar
It's just the upgrade for the intercooler (manifold end plate with additional port, and two flipped catridges).
I actually have the thick aluminum double pass heat exchanger, and with the combination of the intercooler upgrade, and heat exchanger, and larger surge tank I see very little IAT climb during boost.
Jim
Old Dec 4, 2007 | 03:53 AM
  #57
hizzo3's Avatar
i wonder if your low boost is related to the surge tank. the only other thing that i could imagine that is holding you down is the e-85 conversion, but i dont see why. what are your dyno numbers like?
Old Dec 4, 2007 | 11:13 AM
  #58
pjk91's Avatar
i have the larger surge tank as well. you can bypass the bypass valve, and see if that changes your number.
Old Dec 4, 2007 | 12:53 PM
  #59
Quasimotor's Avatar
Talking
I thought about that, but I've yet to try it to see. I think part of the low boost is just the 20% larger displacement of the engine and the fact that the blower is only so much CFM etc.
I may be on the dyno next week depending on how this E-85 thing pans out. We'll find out then.
Jim
Old Dec 4, 2007 | 01:39 PM
  #60
elecblue06's Avatar
Jim
he has a 2.4 silly so he was saying low boost in relative to him using a much bigger pulley
Old Dec 4, 2007 | 02:07 PM
  #61
IonNinja's Avatar
Jim
WTF!!!!!! another built up 2.4, where are you guys coming from????
pics!
Old Dec 4, 2007 | 03:09 PM
  #62
hizzo3's Avatar
Jim
Yeah forgot about the displacement factor. Have you dried porting the blower to see if it helps the airflow? I doubt it will help much if any at low rpms. Depending on how restrictive the blower is, there may be a gain to be had at higher rpms due to decreased resistance. Its prolly not as much as hoped though. With that E-85, you could easily go higher in boost without pistons, so long as the head bolts handle it. E-85 is 103 octane if i remember correctly. Which is why i want to go stage 3 turbo with the pistons... i may need internals and some other strengthing though from the increased power.
Old Dec 5, 2007 | 11:40 AM
  #63
dbss88's Avatar
so do these electronic superchargers actually work.. ive never heard of em until now..
Old Dec 5, 2007 | 05:13 PM
  #64
hizzo3's Avatar
Yes! and also by putting acetone in your gas tank (10% mix) works wonders!!!!
Please dont do either, I was being sarcastic. There is no way a PC fan can put out enough CFM's with out atleast a 1/2 hp electric motor.
Old Dec 6, 2007 | 05:53 AM
  #65
dbss88's Avatar
heh alright
Old Dec 6, 2007 | 01:56 PM
  #66
IonNinja's Avatar
so it basically can work but our electrical systems cannot support the power it would take to spin the fan at a high enough rate to create a gain.
Old Dec 6, 2007 | 03:53 PM
  #67
hizzo3's Avatar
if you put in a larger alternator you could... 1hp is equal to 700 someodd watts of power. most efficent motors are around 80%. that is 840watts for the motor. Then when you pull it down to amps @ 13VDC that means the electric turbo will pull 65 amps/hour of power. Still sound appealing?
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
Rduncanss06
Sep 27, 2015 11:17 PM
