ION3 2.4 differences?
Old Aug 11, 2006 | 01:59 PM
robvas's Avatar
Hello all,
I have a few questions about my 2006 ION3, 5 speed. It's great on gas, I like the center mount gauges, and it's an all around nice car. Past cars include 2002 Z28, Vortech 5.0, 2002 Mustang GT, a bunch of DSM's, XR4Ti, RX7 Turbo II.... Basically I wanted a plain jane driver with cheap insurance and a low payment. I wasn't looking to get the 2.4 but it was the only one the dealer had with a stick.
Are there any differences between the ION3 2.4 and the Cobalt SS NA?
Are the gear ratios/final drive in the transaxle the same? I have the 'sport suspension' option, but I'm wondering if it's the same as what's underneath the Cobalt SS.
Are the engines tuned the same? I'm pretty sure the 2.4 ION doesn't require premium.
I've actually only had the car above 4,000 RPMs a few times, just to see what would happen I think the stock tires are useless, in the rain the car understeers BAD and you can hardly drive it without the traction control kicking on. Also was wondering what the car would run bone stock in the 1/4 mile.
Thanks!
Old Aug 11, 2006 | 02:08 PM
slowion2's Avatar
rob you're going to find that aside from some of the suspension and the obvious differences in the body, it's essentially the same car with a different name
Old Aug 11, 2006 | 04:23 PM
robvas's Avatar
I figured there might be minor ECU calibration differences or at least a shorter final drive ratio on the Cobalt, just wanted to be sure. Thanks.
Old Aug 11, 2006 | 04:59 PM
joeworkstoohard's Avatar
yeah, the 2.4SS seems to be set up a little sportier... stiffer ride, bigger wheels, more aggressive body treatments, but the nuts and bolts of it are the same.
Old Aug 11, 2006 | 05:07 PM
savior's Avatar
its proven that girls like the back seats of the 2.4SS over the ION3.. if you doubt me, just ask your mom
(omg thats a good one)
Old Aug 11, 2006 | 05:12 PM
slowion2's Avatar
thats ok, guys with big wangs drive plastic cars, medically proven LOL
that was good though savior, going to have to remember that
Old Aug 11, 2006 | 05:17 PM
savior's Avatar
lol why thank you slowion
btw, are you still spraying in your saturn?
Old Aug 11, 2006 | 05:25 PM
slowion2's Avatar
if a duck farts does the water ripple? you bet
of course I am
I'm actually waiting on an electric valve for my dump to show up in the next few weeks from QTP and bumping my speed limiter up hopefully this weekend. I'm holding out on any large track events till late fall/early winter. she likes the cold air a ton more than this hot ass humid crap.
Old Aug 11, 2006 | 06:47 PM
of course I am
cold air in florida is a relative term.
Old Aug 11, 2006 | 07:07 PM
slowion2's Avatar
true, I should have said "colder" instead, what they call winter down here isn't true to the term
Old Aug 11, 2006 | 08:56 PM
i was also under the impression that under the sheetmetal may be the same, but that the oil was a few hundred pouns heavier duw to the rear doors and extra bracing to make the poly body not flex as much. plus it had more glass.
i have NO factual basis for this, other than an "i thought" comments?
p.s. about the wang thing... i'm irish, i bought an SS.
Old Aug 13, 2006 | 01:39 PM
avro206's Avatar
Suspension is different, springs, shocks, anti-roll bars are not shared. The qaud coupe is abit heavier then the 2dr Cobalt but its probably under 75lbs difference.
Trans and 3.84 gears are the same.
Old Aug 13, 2006 | 05:21 PM
slowion2's Avatar
actually the QC is about 2800lbs, the cobalt is at least 2900lbs for the coupe and over 3000lbs for the sedan
rear beam is the same on the 05+, front sway bar and rest of the suspension is not though
Old Aug 13, 2006 | 06:05 PM
avro206's Avatar
sorry but you are wrong on a few things. the Coblat 2.4 SS comes in at 2815lbs and the sedan is still under 2900lbs. It s big misconception that the sedan weighs that much--due to CHevy USA being a bunch of dumb-asses--and then every single website spreading the wrong data.
I have weighed mine at a scale. Check out gmcanada.com
SS sedan 2871lbs SS coupe 2815
http://gmcanada.com/english/vehicles...specifications
US website is wrong--end of story--they can't even get gear ratios right
You are right about the weight of a Quad coupe though....(were talking non S/C for both)
http://gmcanada.com/ss/english/vehic...Specifications
Old Aug 13, 2006 | 06:11 PM
IonNinja's Avatar
Ions are lighter than Cobalts!
my Ion 2 sedan weighs in around 2750 according to the Saturn website, I believe the exact number was 2743. And even lighter for the old Ion 1's...
Old Aug 13, 2006 | 06:14 PM
06G5GT's Avatar
My G5 GT coupe clocks in at 2781lbs and my GF's 4 door base auto with A/C clocks in at 2785lbs. For comparison, my Grand Am SE 4 door weighed 3140lbs.
Old Aug 14, 2006 | 11:38 AM
slowion2's Avatar
wow well that sucks. I know the Ion numbers are close if not right on from a weigh in a while back, but GM US is that far off is just dumb. I do believe it though.
so there's very little to no weight difference, that's pretty sweet actually
Old Aug 14, 2006 | 05:26 PM
wolfwood390's Avatar
PWWWWWWWWWWNED!
Old Aug 14, 2006 | 05:32 PM
g5mike's Avatar
I think the biggest difference tends to be from my dogs point of view,he wanted the quad coupe
Old Aug 14, 2006 | 06:17 PM
im not sure about technical diff's but one major thing i like about the quad coupe is the 2 suicide doors, i imagine it makes it alot easier to get in and out of the back which is a plus if you have alot of friends in the car all the time. thats what might sell me on the ion when it time to buy something.
Old Aug 14, 2006 | 06:25 PM
slowion2's Avatar
I'll tell you this, it's the easiest way to transport a pair of kegs that I know of
when I used to cart people around a lot it was very handy, and is from time to time
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
