LNF cams
Old May 16, 2009 | 11:52 AM
riko540's Avatar
Originally Posted by elecblue06
it's swappable for any 2.4 however.. it wont be a good grind if you're sc'ed will it work? yes.. will it give some gains.. probably... but it wouldn't be optimal
Thats what i was thinking cause the LNF cam has a grind designed for a turbo.
Old May 16, 2009 | 12:00 PM
elecblue06's Avatar
i mean the ss/sc guys were running 272 cams for a while.. and saw gains which are turbo grinds but they're not the best setup at all
Old May 16, 2009 | 12:24 PM
rockstar014's Avatar
well the only other cam that is made for our car is that JBP as far as i know
Old May 16, 2009 | 01:41 PM
riko540's Avatar
yes however their grinds are for N/A cars
Old May 16, 2009 | 03:16 PM
prvdoughnut's Avatar
so if i were to do the zzp turbo kit on my car and put those cams on i would see even more of a gain? and they are pushing 350 whp with stock internals safely?
Old May 16, 2009 | 04:29 PM
riko540's Avatar
You can only transfer the exhaust cam from the LNF and yes you would see more gain. How much of a gain is unknown though.
Old May 17, 2009 | 01:19 AM
Matt M's Avatar
The LNF exhaust cam has less duration than the LE5 exhaust cam(194 deg vs. 195 deg @1mm lift). The LNF cam has more lift, but barely(.406" vs. .395"). I doubt that there would be any gains from this swap.
Old May 17, 2009 | 05:46 PM
Turbo06Sedan's Avatar
i had my work order one, they got it in. doesnt look like it'd be worth the pricetag they want for it.
Old Nov 8, 2009 | 08:05 PM
Team_Overdose's Avatar
i have a 2.4 n/a auto with obx headers back no cat aem cai and tunned by hp tuners. can i use the exhaust side lnf cam?? or what else can i do ??
Old Nov 8, 2009 | 09:10 PM
riko540's Avatar
It would be better for a turbo application. As far as N/A goes I would either do a custom regrind or get the cams that J-body performance offers.
Old Nov 9, 2009 | 04:17 AM
  #36
slobalt08's Avatar
Would we need to upgrade the valve springs as well?
Old Nov 9, 2009 | 07:53 PM
  #37
ok cool ... so what else can i do too my car or how much more power can i squeeze out of it ??
Old Nov 9, 2009 | 09:14 PM
  #38
riko540's Avatar
To be honest I really don't know.
well intake, full exhaust, cams, and a tune you'll around 200-210 whp. The cylinder heads would be my next guess seeing as the pistons and rods are good up to 400 hp. Most people don't modify any further after the cams.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
