Need Clutch Help ASAP!
Old Feb 25, 2010 | 08:34 PM
seller232004's Avatar
we just replaced the clutch on my 2.4, now clutch is not bleeding, still goes to the floor i have nothing, how else can i bleed the clutch, need help right now please, thanks
Old Feb 25, 2010 | 08:41 PM
DebadgedBALT77's Avatar
how is it not bleeding? are you pumping the pedal fast before you started bleeding? you may have aerated the fluid, if thats the case, let it sit for a while till the bubbles calm down.
Old Feb 25, 2010 | 08:45 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
You might not have hooked the Distribution Block up properly... I think I had that problem when I did a transmission swap.
mmcgee123's Avatar
When u disconnected the slave did u let all the fluid drain out if so good luck ull have to pull the master and bench bleed it other wise if u didn't pull the cap of the resivor opens the bleeder on the slave and just gravity bleed it
Old Feb 25, 2010 | 09:01 PM
its been sitting for a while now, still no fluid draining yet?
we didnt let the fluid drain out, we also havnt tried it with the cap off, im so pissed right now, trying to get this done so i can trade it in tomorrow morning for my 09 ss/tc.
Last edited by seller232004; Feb 25, 2010 at 09:01 PM. Reason: Automerged Doublepost
Old Feb 25, 2010 | 09:03 PM
mmcgee123's Avatar
Take the cap off and open the bleeder as much as it can it'll work that's how I did mine
Old Feb 25, 2010 | 09:06 PM
ok well my dad said that he did that and still nothing, what else can we try???
Old Feb 25, 2010 | 09:11 PM
mmcgee123's Avatar
How does ur break pedal feil ?
Old Feb 26, 2010 | 01:01 AM
brake pedal feels normal, but i still have nothing for clutch wtf?
Old Feb 26, 2010 | 12:15 PM
mmcgee123's Avatar
Go buy a vacum bleeder
Old Feb 27, 2010 | 06:18 PM
ok got one today, still didnt work...not a drop came out. so we had our other buddy come over and he tried then said the master cylinder is ****, so now i got to buy that, who sells em just dealership and crate engine depot?
Old Feb 27, 2010 | 07:27 PM
mmcgee123's Avatar
That makes no sense that ur master is bad they don't just randomly go bad If u still have brakes there another issue ur over looking bc the clutch and the brakes are all the same hydrolic system
Old Feb 27, 2010 | 08:01 PM
john_boy1987's Avatar
dont feel bad mine is doing the same thing now. i have been trying to figure it out for the past week.
Old Mar 3, 2010 | 12:55 AM
finally got it fixed today, put a new clutch master cylinder in and good to go now, going to trade it in now $400 later lol
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
