NGK 1 step colder plugs
Old Oct 4, 2011 | 12:01 AM
DFZ24's Avatar
I would like to know which NGK 1 step colder could i use for the car?? how do i know if it is a 1 step colder??
with a gap of .043 or around there (i think could use if it is .001 different, correct if im wrong)
on my research i came across this ones.
LFR6A-11 (V-power/regular class): found on a build thread, but dont know whats the gap. On NGK website doesn't says it is a 1 step colder.
ILTR5B11 (iridium/premium class): Got info from Advance auto parts. does not says if it is 1 step colder on NGK website.
ILTR5B11 $9.23
LTR5IX-11 (iridium/premium class): Got info from Advance auto parts. does not says if it is 1 step colder on NGK website.
LTR5IX-11 $7.83
LTR6IX-11 (iridium/premium class): found in MP website and it says is for the SS/TC. On NGK website doesn't says it is a 1 step colder.
if none of this, what would be the part number or plug i need to get.
Thank you in advance.
Old Oct 4, 2011 | 12:10 AM
outtamymind's Avatar
hmm i can't remember which ones i have in my car but they are the one step colder from NGK
Old Oct 4, 2011 | 12:14 AM
mtbrent's Avatar
Stock plugs are heat range 5. You want heat range 6 to be one step colder. I used LFR6A-11 for 30k when I had the m62 on. Forget what gap they came, but they are copper plugs and you can gap them anywhere you want. I ran mine at .038.
Old Oct 4, 2011 | 12:16 AM
ya i just double checked at its the ltr6's i have in my car. can't remember the gap though lol
Old Oct 4, 2011 | 12:21 AM
DFZ24's Avatar
ok how the gap will affect the car???? and how you can measure the gap if you bent them or gap them.... lol
Old Oct 4, 2011 | 12:24 AM
the gap will have a huge effect on the car depending on if its too weak of a spark or too strong of a spark. you want to use a gapping tool to set the gap drive it for a few days and check for misfires and running rough, then regap accordingly and drive for another couple of days. i know when i had just an intake i had to keep the gap at around .040 then when i started adding more mods i had to adjust them a little more to get a gap that matched my car.
Old Oct 4, 2011 | 12:25 AM
DFZ24's Avatar
LTR6IX-11
this one is heat range 6 with .043 gap..... think it will work?
Old Oct 4, 2011 | 12:27 AM
.043 is the stock gap, since you are turbo'd i would start closer to .038ish and adjust accordingly
Old Oct 4, 2011 | 12:30 AM
DFZ24's Avatar
LTR6IX-11
on NGK website says it will increase performance, improve acceleration, and fuel efficiency.
ILTR6B11
but this one dont, what is the difference in Laser (longer life) and the other, will i get the same increase, improve and fuel efficiency???????
copper is the only one that can be gap?
mtbrent's Avatar
Go to your nearest auto parts store and get a plug gapper. Should be under $5. From what I've seen with boosted ecotec's, you want as large of a gap as possible without getting spark blowout at high rpms. Typically people decrease gap as they turn up the boost because they run into spark blowout and loss in power. But, if you can run the stock gap and have no issues with power up at top rpms, then I would certainly do that.
Yea, I dont believe they recommend gapping the other types of plugs, besides copper. Copper is great for boosted applications, but is known for not lasting as long. I had 20k on my first set and they had widened .003. Worked great though
Old Oct 4, 2011 | 12:31 AM
more or less, the regular iridiums will do you just fine but it wouldn't hurt anything to get the laser iridiums either.
Old Oct 4, 2011 | 12:35 AM
DFZ24's Avatar
ok i think thats what is happening right now, when i step on it, the car like bogs or jumps (cant explain it, find the word, or the term for it lol) and missfire like crazy (by interceptor) and then engine lights begin to blink, and when i stop flooring it and drive regular it stop blinking.
Old Oct 4, 2011 | 12:38 AM
mtbrent's Avatar
Good chance of it if you are running stock gap with the turbo! FWIW, ss/tc stock plugs are gapped at .035.
Old Oct 4, 2011 | 12:40 AM
DFZ24's Avatar
i dont know what gap are the one the zzp kit brought, most likely they are the same gap as the stock.
well the one that modern performance sell for the ss/tc is gap .043 they are the LTR6IX-11 and are 1 step colder
Old Oct 4, 2011 | 12:56 AM
mtbrent's Avatar
They need to be gapped then. Do a quick search on this site, you will see what the tc stock gap is(.035). When upping the power, they run them .030-.033 it seems.
What I would do, is get your gapper and find out where you are at first. Then drop .002-.003 at a time, until your problems go away. If things dont get better by 0.030, gap is not your issue.
Old Oct 4, 2011 | 01:00 AM
09BlueBaltSS's Avatar
The plugs that MPx sells for the lnf need to be regapped which is tough on iridium because they will crack. I think for your application the gap should be in the .035-.040 range
Old Oct 4, 2011 | 01:08 AM
DFZ24's Avatar
ok, i will do that tomorrow, and check it out.
Thanks alot for all the help. ill let you know anything. but it might be for next month lol
Old Oct 4, 2011 | 01:11 AM
Dee_Balt07's Avatar
Usually if your CEL is blinking it means your CAT is being damaged. Check to see if your throwning n e codes
Old Oct 4, 2011 | 01:14 AM
DFZ24's Avatar
hmmmm..... the kit brought a catless downpipe.... i will check tomorrow, but last time i did it no other codes came up after it stop blinking.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
tomj77
Oct 4, 2015 11:39 AM
SSLOW06
Oct 1, 2015 07:21 PM
