Performance Radiator
Old Dec 12, 2007 | 06:17 PM
LS6Rally's Avatar
any one know where i can get one?? thanks
Old Dec 12, 2007 | 06:31 PM
mike25's Avatar
im not sure...but just curious....what would this do for you?
Old Dec 12, 2007 | 06:36 PM
steddy2112's Avatar
Less heat soak I would imagine...if you get the GMPP flash the electric fans always run and the second I get on it, the temp usually drops and stays at 185.
It doesn't add HP, but it keeps the cooling system always going
Old Dec 12, 2007 | 07:44 PM
LS6Rally's Avatar
i bought mine from a chevy dealer and aweek later i found the radiator has damage. so i was just gonna upgrade now. they wont fix it they deny that it was already there. so i figured go big it wont hurt the car.
Old Dec 12, 2007 | 08:14 PM
Projekt's Avatar
anyone got a link for the performance radiator and how much % cooling is gained from it?
Old Dec 12, 2007 | 08:56 PM
pjk91's Avatar
justgetsomeone o tune your car so the fans are always on.
Old Dec 12, 2007 | 11:03 PM
LS6Rally's Avatar
as stated previously, radiator has damage. could give a **** less about the fans
Old Dec 13, 2007 | 08:26 AM
celicacobalt's Avatar
I would say to check out your local radiator shop and see if they can advise you on one to order that they could modify to fit your cobalt. I know koyo and fluidyne are great radiotors if you can get one to fit.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
Tupp
Sep 30, 2015 08:18 PM
