PsykoStevo's tune installed by DOC
Old Apr 9, 2007 | 07:29 PM
  #51
iLLmaTic3s's Avatar
Originally Posted by Psykostevo
I removed the torque reduction portion of the traction control, so it no longer pulls torque from the wheels when floored. That means when you floor it your Low traction warning will come on about 80% of the time.
I have no idea why those stinking '07's threw Crank position lights. There should never be a need for crank position learn unless you are swapping ECU's with another car.
ah i see. yeah when we tuned my car we didnt touch the traction control.im guessin if we did i would get the same thing.
Old Apr 9, 2007 | 07:34 PM
  #52
Psykostevo's Avatar
Nope, his is a service light, not a low traction light. You will pick up more WTQ if you remove the torque reduction. The Low traction light means nothing, it's when the service light comes on, which has nothing to do with the tune.
Old Apr 9, 2007 | 07:36 PM
  #53
Jackalope's Avatar
And its the service light that comes on hence my problem.
And again its NOT STEVE OR DOC'S fault! This was a preexisting problem that I had hoped would go away, saddly it has not.
Old Apr 9, 2007 | 07:46 PM
  #54
iLLmaTic3s's Avatar
hmm thats really strange..are u the only one who has this problem?
Old Apr 9, 2007 | 07:52 PM
  #55
thekingsSS's Avatar
Hey Psyko, do you have any idea why a '06 5spd would switch on the CEL after a tune? When I took it to Autozone, they told me it was a P0171 code, MAF or O2 sensor before the cat. Do you know what I can do to fix it?
Old Apr 9, 2007 | 11:01 PM
  #56
fukuhos's Avatar
when i had my 2.4 i never had any cel just t/c lights
Old Apr 9, 2007 | 11:20 PM
  #57
celicacobalt's Avatar
my t/c light is steadliy on now, but my DIC never said anything about low traction or service at all.
Old Apr 9, 2007 | 11:33 PM
  #58
cgss's Avatar
steves tunes are the best. for both the 2.4 and the 2.0. psykotuned is definately the way to go!
Old Apr 10, 2007 | 12:04 AM
  #59
REDFOCZ's Avatar
I dont think there will be an issue. But do you think that your tune should work on a Ion.
Old Apr 10, 2007 | 12:46 AM
  #60
elecblue06's Avatar
+1 on wondering if it'll work with an ion, all I will have is the injector swap and maybe a cai at the time of the tune.. how much do you think it'll help me ? still about a second? i'm a 2006 2.4 manual ion for the record
Old Apr 10, 2007 | 02:01 AM
  #61
Psykostevo's Avatar
That's a lean code. Not a sensor. You need your MAF readjusted when you can get around to it. If you do not use Premium fuel ONLY you will see these codes as well.
Yeah they work on an ION though you need slightly different tuning, because Saturns tend to have differences.
Last edited by Psykostevo; Apr 10, 2007 at 02:01 AM. Reason: Automerged Doublepost
Old Apr 10, 2007 | 10:46 AM
  #62
pjk91's Avatar
yeah, i wonder if a 5spd would have the crank re learn problem too. odd.
Old Apr 10, 2007 | 11:05 AM
  #63
thekingsSS's Avatar
Nope, I have the 5spd with a tune, lean code is my only problem, and its cause the tune didnt account for my intake
Old Apr 10, 2007 | 11:18 AM
  #64
Doc's Avatar
Doc
I need to get my laptop back up and check out the tune, its a simple fix, the p0171 code. The crank relearn has happened a few times since I switched to the newer hptuners software update.
Old Apr 10, 2007 | 11:22 AM
  #65
thekingsSS's Avatar
Sweet deal, just hit me up whenever you want to meet.
Old Apr 10, 2007 | 01:07 PM
  #66
Jackalope's Avatar
DOC pmed you.
Old Apr 10, 2007 | 01:49 PM
  #67
Psykostevo's Avatar
This new .18 version has more bugs in it than ever! It must be because they added Fords to the lineup. Damn Fords! I have to reload HPtuners after nearly every car now!
Old Apr 10, 2007 | 03:20 PM
  #68
Jackalope's Avatar
Well my crank sensor is re-larned but my traction control keeps going off and as it turns out its cause of the tune. The issue I had prior was scaned and found to be due to the ice I hit and the car re-set itself and it wouldn't have been a problem. Steve's tune makes the car chirp 2nd which makes the traction control want to come on but his program says not to so the computer gets confused, truns it off all together and turns on the service traction stuff. The CEL is back because Steve is 3000 and some ft above sea level and I'm damn near at sea level so the MAF sees things outside his parameters and throws on the CEL. I've PMed DOC to see when I can drive down to visit im to get the MAF calibrated for the lower altitude and hopefully DOC can turn off the traction control at that time eliminating the damn traction control crap too.
Steve anything you can think of that I missed?
Old May 8, 2007 | 11:29 AM
  #69
thought's Avatar
Just wondering on the progress here. My buddy has the 2.4L and is gonna unload my stock injectors from me and get himself a harness. We have a couple guys in the city with HP Tuners, but we don't know how to get him a good/reliable tune for the bigger injectors. Do you have the ability to email us a tune or something??? I have no idea how that works, please help :-)
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
