SPEC stage2+ or 3+ , etc..
Im planning on getting the ZZP stage 3 kit next year in between summer - winter depending on job situation. Looking up clutches and planning the before tasks before i take a trip down there and have them do it.
Which clutch would ppl recommend.
ALSO while were on the subject
Other then a Wideband gauge what other ones would be good ideas in the car.
Lastly what are some boost controllers i was planning on the
AEM TRUBoost set-up
Opinions, Thoughts, SUggestions.
Thanks!
AEM TRUBoost set-up
Thanks!
stage 2 would be better for daily driving, guess it depends if you care about the drivability of the clutch on a daily bases.
Ever look into the exedy clutches?
im going with the stg 2 kit from them within the next 2 months so ill post up how it goes. i plan on getting the stg 2 + kit from spec as well.
next spring i plan on getting headwork done as well as the valve spring upgrade like they did, then building an extra motor im gonna be picking up.
i would go with the stage 2+, but have you looked at the exedy stage 2 clutch because you can find it pretty cheap and a few sc and tc 2.2s and 2.4s on here are using it.
zduce, how much for the header and dp individually?
header:?
DP:?
Weve already talked about this, but how soon are you selling them?
Oh and zduce whats the difference between the CA V1 & CA V2??
header:?
DP:?
pm me later on. dont wanna crowd this thread.
but hopefully within the next 2 months. as soon as i finish my 2 summer school classes and get my reimbursement back. ca v1 is no longer made and the v2 is slightly bigger, it was also polished and not that ceramic coat stuff
TurboTechRacing
12-14-2005 05:07 PM
