Transmission= TOAST?
Old Oct 3, 2009 | 07:09 PM
mrkrackie's Avatar
Angry Transmission= TOAST?
So this was a steady increasing problem with my transmission that started almost a year ago. The traction control off light comes on and then the car will jerk really hard between gears. Even from Drive to park u can see the car jerk when you shift it. Its an automatic transmission. My guess is that its done for. Any idea of what could be happening. my car only has 45xxx miles on it so I'm hoping they will cover it under warranty but you never know. Chances are they will blame me and not cover it. Typical GM.
has anyone else experienced this?
Old Oct 3, 2009 | 07:14 PM
HunterKiller89's Avatar
replace the clutch packs. Your tranny is increasing line pressure to save what little of the clutch discs there is left IIRC
Old Oct 3, 2009 | 07:27 PM
mrkrackie's Avatar
would that be covered by the factory warranty? and i recently installed a K&N typhoon intake a week ago. that wouldnt have anything to do with the engine light would it?
Old Oct 3, 2009 | 07:49 PM
riko540's Avatar
I'm not sure what type of warranty you have but mine is 3 years/36k miles. So if I was in you shoes I'd be sol. I'd go to a dealer and find out if its covered. As far as the intake goes that wouldn't have caused the trans. to fail so it shouldn't be a problem.
Old Oct 3, 2009 | 07:51 PM
you dont have any CELs do you? MAF is working right? I think I remember something along the lines of the transmission shifting really hard when it can't get an engine load signal from the MAF sensor
Old Oct 3, 2009 | 09:55 PM
SSfamilywagon's Avatar
Yes the MAF can effect the trans. When I 1st got my car, I tried making a intake for it an ended up puttin the MAF in backwards. Traction light, no Check engine, came on and trans shifted very firm. Would bark the tires from 1st to 2nd. Figured out what I did and put the MAF in correctly and it fixed all my probs
Old Oct 4, 2009 | 11:56 PM
mrkrackie's Avatar
i dont think my MAF sensor is in backwards because the screw holes only line up one way. and i use to have this problem at a smaller extent before the new intake with the traction control light but no engine light, it usually went away on its own.
Old Oct 5, 2009 | 12:45 AM
BlueStang's Avatar
Red face
U.S. cobalts have a 5 year 100000 mile power train warrenty so its a matter of weather they say it was or was not abused
Old Oct 5, 2009 | 12:58 AM
mrsilent13's Avatar
nope...u lie...i bought mine in 05 and only received a 36k or 3yr warranty
Old Oct 5, 2009 | 01:39 AM
_UnLiMiTeD_'s Avatar
the 3 year/36k miles warranty is for the bumper to bumper warranty. The powertrain is 5 year/100k miles for ALL cobalts, 05 and up
Old Oct 5, 2009 | 01:57 AM
BlueStang's Avatar
ah check your facts before you post the 3yr 36 k is the bumper to bumper. i said the power train is 5yr 100k
Old Oct 5, 2009 | 02:27 AM
CordiaDOHC's Avatar
thought it was 07 and up!
Old Oct 5, 2009 | 02:31 AM
Acey's Avatar
For 06 I know this:
Basic - 3 yr/36,000 mi
Drivetrain - 5 yr/60,000 mi
Roadside - 3 yr/36,000 mi
Rust - 6 yr/100,000 mi
Old Oct 5, 2009 | 02:38 AM
BlueStang's Avatar
Red face
so if you only have 45k sounds like its a warrenty issue and should be covered
Old Oct 5, 2009 | 02:57 AM
type in 2005 chevrolet cobalt powertrain warranty, then do it for 06,07,08,09, powertrain is the same and comfirmed on 10 sites for each year, this isnt rocket science
Old Oct 5, 2009 | 03:36 AM
BlueStang's Avatar
that's right
ok here it is right from GM. 05 & 06 cobalts have a 5yr 60k on the power train warrenty. 07, 08, 09 & 2010 have a 5yr 100k power train warrenty on U.S. cars
Old Oct 5, 2009 | 03:48 AM
blueg5gt's Avatar
i have an 07 Pontiac g5 gt with the automatic transmission. Traction control came on and the check engine light came on the same time i installed my header/down-pipe combo (catless). My trans does the same thing yours does now and the dealership told me that the O2 sensor in my down-pipe is blown, there is a rub in my exhaust that is blowing the traction control fuse causing the firmer shifts. Told me 300 for he O2 sensor and my exhaust needs bent to prevent the rub that is blowing my fuse. I dont know where the rub is and they couldnt tell me. So i would check your Traction control fuse to see if its blown and go from there.
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
