transmission
Old Dec 27, 2011 | 06:12 PM
drewSS06's Avatar
transmission
ok i lloked it up on google but i wanna double tap with some other people. in the 2.4L SS is the transmission the getreg f23? reason being is that my snycros went bad from first to second.
Old Dec 27, 2011 | 06:18 PM
Mindrot's Avatar
F23 for the Manual. 4T45e for the Auto.
Old Dec 27, 2011 | 06:33 PM
drewSS06's Avatar
cool thanks
Old Dec 27, 2011 | 06:41 PM
drewSS06's Avatar
ok well another question is that i found a transmission for it but its out of a 2.2L saturn ion. i dont know the year of it if that matters. but its a f23 as well would it matter?
Old Dec 27, 2011 | 06:43 PM
Mindrot's Avatar
I don't see why it would matter. I'm sure someone in here is more knowledgeable on the F23 than I am though.
Old Dec 27, 2011 | 09:58 PM
mmcgee123's Avatar
Any f23 will do u should just rebuild it f23's are a fairly simple trans to take apart
Old Dec 27, 2011 | 10:11 PM
Validater's Avatar
I've read that the gears on the shafts are pressed on with around 10 tons of pressure. but yes they will be able to be swapped, its still an ecotec engine, the ss sc and tc transmissions I don't believe are swappable with the 2.2 or 2.4.
Old Dec 27, 2011 | 10:16 PM
drewSS06's Avatar
the only problem with rebuilding it is that i dont have the tools to take the gears and what not out of the unit itself. so i would have to take it to a shop which would run me about 1500 - 1700 to rebuild it. i know someone that has a f23 that has 34000 on it, for a decent price.
Old Dec 27, 2011 | 11:22 PM
noorj's Avatar
mine is always pretty hard to get into second gear from first. much harder than the other gears, could this be a syncro going bad?
Old Dec 28, 2011 | 01:25 AM
Ownedbyagirl?'s Avatar
Maybe yo need to readjust the shifter cable?
Old Dec 28, 2011 | 02:27 AM
noorj's Avatar
readjust how? When I put my short throw in i greased the cables and played with cable clamp positions, nothing helped.
Old Dec 28, 2011 | 12:18 PM
drewSS06's Avatar
mine wont grind unless im over 3500 rpms after that it grinds into 2nd. so if i get on it i have to let the rpms drop before i can shift. every shift after that is nice and smooth no matter what rpm it is.
RaginChopsuey
Oct 27, 2015 01:27 PM
importkiller
Sep 30, 2015 07:18 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
