Why does it seem like most 2.4 tubos here are...
Old May 3, 2008 | 06:03 PM
Moof's Avatar
Originally Posted by REIGN SS
I would suggest reading some of Beck's threads, he has a supercharged 2.4 5spd and shares alot of his information.
Link to said threads? I'd like to indulge in his experience.
Old May 3, 2008 | 06:06 PM
xCobalt05x's Avatar
Originally Posted by Moof
the manuals are that weak?? How the hell are people even thinking of having turbo 5-spd then?
remember GM under-rates all their shizzzz..... so with that in mind, that 325trq rating on the auto trany... yeah, it falls under GM's under rated abilities
Originally Posted by CTCOBALTSSS
Chevy Cobalts come with two different transmissions depending on your model. Here is some info.
Here is the GM transmission guide.
http://www.gminsidenews.com/index.php?page=trans_guide
2.2L/2.4L Manual
Getrag F23
Type: transverse front wheel drive, five-speed manual transaxle.
Engine Range: 2.2L-2.4L
Max Gearbox Torque: 170 lb.-ft.
Weight: 102 lbs.
Applications: Chevrolet Cobalt, HHR; Pontiac G5
2.2L/2.4L Automatic
Hydra-Matic 4T40E/4T45E
Type: four-speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with electronically controlled torque converter clutch.
Engine Range: 2.2L-3.5L
Max Gearbox Torque: 325 lb.-ft.
Weight: 188 lbs.
Assembly Site: Windsor, Ontario
Applications: Chevrolet: Cobalt, Malibu, Pontiac: G5, G6, Saturn Vue 4-Cylinder.
With a max TQ rating of 325 lb/ft, it doesn't seem to be the weak link..
2.0L Supercharged
GM Europe F35
Type: transverse front wheel drive, five speed manual transaxle.
Engine Range: 2.0L
Max Gearbox Torque: 258 lb.-ft.
Weight: 99 lbs.
Applications: Chevrolet Cobalt SS
here ya go
Old May 3, 2008 | 06:08 PM
REIGN SS's Avatar
Original Hayden Fanatic
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/you-know-what-f-f-23-stands-100041/
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/becks-2-4-s-c-dyno-98345/
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4-s-c-tranny-aftermath-96072/
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4l-supercharged-videos-81339/
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/2-4-supercharge-build-commencing-75755/
How-To:
https://www.cobaltss.net/forums/how-guide-43/how-beck%92s-2-4l-supercharged-build-walkthrough-80620/
Old May 3, 2008 | 06:16 PM
Moof's Avatar
Hrm.... appears as though the 5-speeds are a real weak link with performance.
Old May 3, 2008 | 06:17 PM
GreenPurgatory's Avatar
lol, all the autos have come out of the closet to justify themselves.
Manual FTW!
I would only go for auto if I was considering ease of driving.
Old May 3, 2008 | 06:22 PM
xCobalt05x's Avatar
not to mention that Vince at trifecta cracked the TCM and he re-tuned my trany to shift at 7200 rpms and moved my rev limiter to 7500 rpms and upped all the line pressures to eliminate slipping while going into the next gear
Old May 3, 2008 | 06:43 PM
BoostedG5's Avatar
I have a 5spd turbo running 14lb's of boost with a spec flywheel and cltuchmasters fx300. Only a seriously staged car would be able to even touch me. The turbo tech mounts help so much.
Old May 3, 2008 | 06:56 PM
Brandon97Z's Avatar
not quite....the j-bodies run the same f23 trans and alot of them are holding up fine. Anywhere from 200-400whp
Old May 3, 2008 | 06:57 PM
HackAbuse's Avatar
You're running 14 pounds and this is all you've got?
http://www.youtube.com/watch?v=xCwipGzPYRc&feature=user
Sorry, but something must seriously be wrong here
Old May 3, 2008 | 06:58 PM
xCobalt05x's Avatar
what about my engine:
Wiseco forged 8.9:1 pistons
Egale forged H beam rods
Ferrera Valves
Ferrera duel valve springs w/ titainium retainers
Comp Cams Stage 1
3 angle valve job on the head
Cometic Head gasket
ARP head studs
ACL rod bearings
60# injectors
t-60-1 hifi turbo with ceramic ball bearings
Trifecta tuning for both ECM and TCM
as soon as i get my CV axels in..... boosting to 22psi
Old May 3, 2008 | 07:01 PM
  #36
mkulrey13's Avatar
do you not read hack? thats before the clutch and notice/hear the stocker slipping Mine did the same thing when i had my stocker.
Ferrera Valves
Comp Cams Stage 1
Cometic Head gasket
ARP head studs
ACL rod bearings
60# injectors
Hope you have a different mani, that plastic is going to go BOOOM!
Old May 3, 2008 | 07:02 PM
  #37
xCobalt05x's Avatar
lsj intake mani with block off plate and addapted for the 2.2 throtle body
Old May 3, 2008 | 07:07 PM
  #38
HackAbuse's Avatar
Weren't you only able to pull off a 15.x last week at the track?
Old May 3, 2008 | 07:08 PM
  #39
xCobalt05x's Avatar
15.x, lol detla pulled out a 15.3 pass all motor with bolt ons
Old May 3, 2008 | 07:09 PM
  #40
mkulrey13's Avatar
Yea with my first time with the new power/completely spinning off the line till 3rd. Kinda hard to pull anything faster. I do not have driver mod yet. But my trap was nice :P
Ahh nice nice, wish i had the money like you
Old May 3, 2008 | 07:10 PM
  #41
HackAbuse's Avatar
Dude, I LOVE your avatar
(xCobalt05x)
What was your trap again?
Old May 3, 2008 | 07:23 PM
  #42
xCobalt05x's Avatar
lol i started this project 3 years ago.... its taken way to long to finish it and next weekend, it shall be done. lol im shooting for mid to high 13's before i up the boost when the axels come in
(xCobalt05x)
lol thanks, i found it on a web site
Old May 3, 2008 | 07:27 PM
  #43
HackAbuse's Avatar
I think your axles will handle the abuse just fine unless your using DR's
SS/SCs break axles because they launch too hard with a stick, when you launch with an Auto, the power is already at the wheels, theres no 'jolt' of power.
Old May 3, 2008 | 07:30 PM
  #44
xCobalt05x's Avatar
interesting
Old May 3, 2008 | 07:31 PM
  #45
mkulrey13's Avatar
98mph.
Old May 3, 2008 | 07:34 PM
  #46
xCobalt05x's Avatar
hey, ill post up my buddies 15.1 on 75hp dry shot of nitrous bone stock, no bolt ons
Old May 3, 2008 | 07:35 PM
  #47
mkulrey13's Avatar
also notice his 60 is 2.4 while im 2.89 i need driver mod badly!
Old May 3, 2008 | 07:41 PM
  #48
xCobalt05x's Avatar
lol, i cant get a driver mod, my pass is the car on the left side at 2.6
but when we went stock for stock, my automatic out performed his manual. my best pass was a 16.704 and his not on nitrous was a 16.75
this was my best pass in my automatic
this was his best pass
Old May 3, 2008 | 07:55 PM
  #49
Red2.4SS's Avatar
Not really, I have a turbo 5 spd and its been fine.
Old May 3, 2008 | 07:59 PM
  #50
IonFeright's Avatar
its all personal preference. I personally wouldnt own an automatic car. It doesnt get more boring than driving an auto. I doubt anyone one here has come close to topping out the 2.4 auto or manual tranny anyways so that cant be the reason.
