Aftermarket front mount oil cooler
Old Oct 12, 2014 | 12:53 PM
colodude18's Avatar
Originally Posted by ecaulk
do you machine these? Those look great.
+1
Old Oct 12, 2014 | 02:09 PM
mrbelvedere's Avatar
Originally Posted by ECaulk
Do you machine these? Those look great.
kinda
Old Dec 13, 2014 | 06:31 PM
colodude18's Avatar
Update:
Got the adapter plate (big thanks to Mr. Belvedere) and found a cooler that'll work for cheap. Now just need to order the lines and fittings and we'll be on our way. Installation is planned for January, with much appreciated help from ecaulk To be continued!
Old Dec 13, 2014 | 07:21 PM
ChrisR1S's Avatar
Subd for results. That plate looks sweet! Takes up much less room than my setup. Is the sealing surface o-ringed?
Old Dec 13, 2014 | 08:01 PM
colodude18's Avatar
Yeah I think it will be a very nice mod! Let's see your setup!
Old Dec 13, 2014 | 08:06 PM
use -10 line
Old Dec 13, 2014 | 08:28 PM
Originally Posted by mrbelvedere
use -10 lone
Thats what we're planning, it looked like NPT 1/2inch threads going into the cooler. Do you run or recommend running an oil pressure gauge with an oil cooler setup?
Old Dec 13, 2014 | 09:08 PM
TStone's Avatar
Good idea to run the gauge regardless of the setup
Old Dec 16, 2014 | 02:04 AM
Sharkey's Avatar
http://www.ebay.com/itm/221159318437?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i ordered one of these guys for my ecotec porsche swap. im going to run a performance world remote filter setup and an oil cooler of some sort.
Old Dec 16, 2014 | 08:22 AM
you can if you want
Old Dec 16, 2014 | 09:42 AM
  #36
RyBread761's Avatar
Ive always loved the idea of an external oil cooler. Something about having coolant that close to oil scares me if it ever goes bad.
Old Dec 16, 2014 | 10:18 AM
  #37
Axelthered05's Avatar
a little late in the game but this is what I did, purchased a drill and tap set for 1/2 NPT and adapted the stock oil cooler for front mount
Old Dec 16, 2014 | 10:34 AM
  #38
ItalianJoe1's Avatar
Are you running any sort of heat shield between the turbo and the coolant pipe on the rear of the engine? I know I saw on a ZZP kit for a 2.4L that the turbo heat from being so close to the coolant line was increasing coolant temps on the car. It wasn't a track car so just running the fans earlier was enough to control it but in your case with constant hard use it would be too much to just absorb. Just at thought.
Old Dec 16, 2014 | 11:12 AM
  #39
AaronJ's Avatar
Instead of using that plate, what are people's thoughs on using the new DDMworks adapter for oil coolers? Their adapter replaces the plastic top of the oil filter port-thingy with a machined piece with ports for fittings to be threaded in.
Old Dec 16, 2014 | 12:26 PM
  #40
colodude18's Avatar
You mean the one that Sharkey linked above? I wonder if it would flow as well as the adapter plate that Mr B makes...
Old Dec 16, 2014 | 12:34 PM
  #41
AaronJ's Avatar
OMG no way, . I am at work so I couldn't view the ebay link, but I just pulled out my phone to look at it. That is the exact same thing DDMworks just came out with. I'm not sure they know this thing exists . The only difference might be that DDM's still allows the stock oil filter to be used instead of requiring a remote filter.
Old Dec 16, 2014 | 12:39 PM
  #42
Sl0wbaltSS's Avatar
Bigger rad and hood delete
Old Dec 16, 2014 | 01:37 PM
  #43
Get out of useful threads will your bullshit comments.
Old Dec 23, 2014 | 09:08 AM
  #44
Originally Posted by Sharkey
CBM 10813 Ecotec 2 2L 2 4L L61 LE5 Remote Oil Filter Adapter Cooler Billet USA | eBay
will not work on any ecotec with a factory oil cooler you would need to mod the block for it to work
Old Dec 23, 2014 | 09:30 AM
  #45
AaronJ's Avatar
Why is that? Is there not enough oil pressure that high up in the block to push the oil through an additional oil cooler? To be honest, until reading this thread I had no idea we had an oil cooler stock. I feel like that was never really common knowledge .
Old Dec 23, 2014 | 10:01 AM
  #46
where the factory oil cooler bolts to the block there is a metal sleeve you have to remove and then plug the block before that cap can be used
Old Jan 6, 2015 | 05:37 AM
  #47
KonnerTomlinson's Avatar
so would the DDM works adapter be usable if you were say using a gen3 2.4 block without a factory oil cooler ?
Old Jan 6, 2015 | 08:14 AM
  #48
should be but contact them to be sure
Old Jan 8, 2015 | 09:28 AM
  #49
this is what I want to use to run a remote cooler & filter http://www.alphafabindustries.com/co...cooler-adapter
Old Jan 8, 2015 | 10:24 AM
  #50
colodude18's Avatar
Originally Posted by KonnerTomlinson
this is what I want to use to run a remote cooler & filter ALPHA FAB INDUSTRIES, INC. ? CBM ECOTEC STYLE BILLET REMOTE OIL COOLER ADAPTER
That's what we're talking about here.
It's not a plug-and-play item on the LNF as Mr. B explains in post #46.
