find the max efficieny
Old Sep 27, 2007 | 01:35 PM
Area47's Avatar
Rent me! per hour
find the max efficiency
Old Sep 28, 2007 | 01:35 AM
OneAMCoffee's Avatar
So what are you trying to say?
You should add this to the tread I have for Eaton TVS superchargers.
Regards,
Ryan
Old Sep 28, 2007 | 11:38 AM
Area47's Avatar
Rent me! per hour
this is a totally different subject actually.
hence the new thread.
Old Oct 5, 2007 | 08:37 PM
XM15's Avatar
I wish I could read compressor maps. lol
Old Oct 5, 2007 | 08:40 PM
calchr2's Avatar
where its darkest blue is where the supercharger is most effecient. i could be wrong, its been a while since i went over this stuff
Old Oct 5, 2007 | 08:44 PM
XM15's Avatar
That part I've got. It when terms like "pressure ratio" and "surge" come into play that I move on to simpler things.
Like intakes.
Old Oct 5, 2007 | 08:48 PM
Blur.fx's Avatar
Pave It All...
My question is the pressure ratio... Is that in bar?
So you take it times 14.7 to translate into PSI or am I totally on the wrong track... Because if I'm right that is a lot more boost than I expected.
Old Oct 5, 2007 | 08:51 PM
SSdan's Avatar
Lamens terms.
Old Oct 6, 2007 | 07:23 PM
Blown 4-banger's Avatar
9000-11000 RPM with 700-850 m^3/hr intake volume flow, and a pressure ratio of 1.5-1.7.
9000-11000 RPM is slow as ****
Old Oct 6, 2007 | 07:41 PM
06black's Avatar
even at max eff% its flow rates are lacking.
and a grand total of ~4000rpm or so in that maxx eff% is week.
however if you drop a minimal amount to the 70% eff% range then its usable RPM range becomes much more forgiving.
73%-70% isnt bad for a roots blower at all.
thinking of swapping?
Old Oct 6, 2007 | 07:46 PM
If I got that blower, I'd spin it to 17k no questions asked.
Old Oct 6, 2007 | 10:22 PM
06black's Avatar
well dependent on your system PR the ill-effects of that excessive rpm might not be THAT bad.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dennis69
Oct 20, 2015 04:49 PM
agentirons
Oct 16, 2015 02:11 AM
Delta coupe
Sep 30, 2015 08:11 AM
Iceberg
Sep 28, 2015 01:31 PM
