first htv 1320 received
Old Mar 21, 2008 | 10:49 AM
  #776
Raven SS's Avatar
Originally Posted by jgarciarivera
A walbro gss342 does not fit inside the black cylinder module in the fuel tank. Is longer than stock
didnt u post that the gss342 can be made to work
Old Mar 21, 2008 | 10:55 AM
  #777
djt81185's Avatar
Originally Posted by lsjwannabe
you ever race a stock cobalt, think of that
i ran out of fuel so i have to try a few things to see if i can band aid it if not it may be a while.
If my car were running, and witt and i were racing...witt would be looking like the stock cobalt of the race hahaha
Old Mar 21, 2008 | 10:59 AM
  #778
Edubs's Avatar
What kind of air are you moving per cyl? I remember you were pushing somewhere around 315g on the 2.5...
Old Mar 21, 2008 | 11:05 AM
  #779
Area47's Avatar
Rent me! per hour
Originally Posted by Witt
I know you believe the LSJ with the TVS is faster, but did you really have to swap the LS2 out for it?
Hmm, from what Paul has been posting about running the MAF out of range on his turbo, I'm thinking if the PCM can continue to convert cylinder airmass from frequency at higher than 11,100hz tweaks can just be made in the PE table.
I'll get it to work one way or the other when I swap pulleys, its just getting the fuel there that's going to be fun. I'm seriously considering the Aeromotive Digital FMU at this point. I already have the required pump.
my idea's do carry some thought behind them sometime mr man.
Old Mar 21, 2008 | 11:06 AM
  #780
lsjwannabe's Avatar
over 400, and my dynamic cylinder airmass is close to 2.0, most pullied cobalts do 1.08~1.20
well we can't beat everyone can we
Last edited by lsjwannabe; Mar 21, 2008 at 11:06 AM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 11:46 AM
  #781
Witt's Avatar
Originally Posted by WSFrazier
We haven't even gotten decent videos yet. The weather here fucked us the first night.
I'm hoping he gets time from work to put the 2.75" on this weekend, I want to see first hand how that fkr compares to Dans RL and my 2.5 pullied car.
Its going on in about an hour. I'll be doing logging on it on my way to work today.
Thats a big IF.
Old Mar 21, 2008 | 11:49 AM
  #782
Edubs's Avatar
[QUOTE=Witt;2102117]Its going on in about an hour. I'll be doing logging on it on my way to work today.[QUOTE]
Al, your springs are these right?
http://www.dezod.com/pd_supertech_ti..._stainless.cfm
Old Mar 21, 2008 | 11:50 AM
  #783
lsjwannabe's Avatar
Thats a big IF.
get ready for it lol
Old Mar 21, 2008 | 11:51 AM
  #784
Witt's Avatar
Yeah, the Supertech 78lb with their seat locators on the inner spring.
Cup of coffee, shower and it'll be on.
I don't know if I'm going to giggle at first when I see the MAF or be pissed off I have to spend more money on the fuel system.
Old Mar 21, 2008 | 11:53 AM
  #785
Edubs's Avatar
Hey, at least you'll make more power before you run out of fuel...
  #786
Blown 4-banger's Avatar
Originally Posted by fast98
witt the maf is gunna be accurate to 11250 hz and after that you can just add in with pe.
blown4banger go with a intank pump, the external are noisy and unreliable. the pump is acctually cooled by the fuel around it, so a external pump is gunna run hot and that shortens its life.
and i dont think anyone is gunna need larger than a 3/8 fuel line from what i've seen
Well, as you should know based on previous instances. I tend to over build (I want 400-500 whp, so I built the motor to withstand 800 ). So I figured, I would make the fuel system so that it barely has to work, in order to feed the motor. Plus, inline pumps are cooled by the air passing over them. Also, when you hear a car before it starts up, with the distinct whir of larger fuel pump, is just screams "Don't **** with me, unless you got some power"
  #787
lsjwannabe's Avatar
Yeah i think it will be the giggle followed by tears as you know what has to happen
Old Mar 21, 2008 | 11:54 AM
  #788
Rangerondubz's Avatar
  #789
Witt's Avatar
Leaner = moar powa imo
Old Mar 21, 2008 | 11:55 AM
  #790
lsjwannabe's Avatar
or theres a dying cat in my car lol
im running those 130% idc's with a 12.0 afr at 6200. the thing is scary
Last edited by lsjwannabe; Mar 21, 2008 at 11:55 AM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 11:56 AM
  #791
Witt's Avatar
I need to at least get it to 7k with a 12-1 afr. Cams don't come in until 5700 so its make or break for me.
Old Mar 21, 2008 | 11:57 AM
  #792
There is always a dying cat in my car!
See thats why I want to upgrade my fuel system, if I can make 500 whp, while my injectors sit at like 60-70% IDC, I'll be happy.
  #793
Area47's Avatar
Rent me! per hour
mo powa at 12.4 than 13.4
don't ask how i know this.
Old Mar 21, 2008 | 11:59 AM
  #794
lsjwannabe's Avatar
your broke then lol, i don't think the 79's will cut it either
me thinks you like to play on the dyno to much
i would be happy to see those idc's to.
Last edited by lsjwannabe; Mar 21, 2008 at 11:59 AM. Reason: Automerged Doublepost
Old Mar 21, 2008 | 12:00 PM
  #795
Raven SS's Avatar
79's with a FMU or return style system
should be good
Old Mar 21, 2008 | 12:01 PM
  #796
Witt's Avatar
should be good
This is my thought.
  #797
lsjwannabe's Avatar
60's can work with a return style
Old Mar 21, 2008 | 12:04 PM
  #798
Witt's Avatar
For 439 bucks to Summit and a couple of AN fittings and very little mess I can have all my fuel issues solved with Aermotive's digtial FMU. I already have the pump for it.
Oh, btw, the 2008 Aeromotive catalog is available on their site now, its pretty good, lots of new things like quick-connect to AN fittings and such.
Old Mar 21, 2008 | 12:05 PM
  #799
Raven SS's Avatar
my wife doesnt like u al
Old Mar 21, 2008 | 12:06 PM
  #800
Witt's Avatar
I'm stretching my own to the limit here as well. Kinda why I have to cool it on car parts for a bit.
