first htv 1320 received
Old Mar 21, 2008 | 12:25 AM
  #726
USMCFieldMP's Avatar
Rattlesnake Race Shop
Originally Posted by Witt
If they are using a blow through MAF, the air is compressed and doesn't cause the reaction from the MAF as being uncompressed and cooler.
Hmmm... true.
Old Mar 21, 2008 | 12:27 AM
  #727
lsjwannabe's Avatar
any reason you did not take it to 8
  #728
KillerBee's Avatar
Can't really compare the temperatures. The stock blower one was on a dyno after a few pulls, the HTV on the street with cooler ambient, different gear, and a moving car.
Those are 79lb/hr injectors installed.
so you might as well say your gunna need 79lbs to work with this cause if its at 74% IDC then 60s are gunna be way high. So its safe to say 79lbs are going to be needed with this supercharger
  #729
zrated89's Avatar
Those are 79lb/hr injectors installed.[/QUOTE]
dam so the 60's will be close to being maxxed out even with the 3.34pulley
Old Mar 21, 2008 | 12:29 AM
  #730
lsjwannabe's Avatar
Just means its that much faster
Old Mar 21, 2008 | 12:30 AM
  #731
KillerBee's Avatar
exactly
Old Mar 21, 2008 | 12:31 AM
  #732
EthensCobalt's Avatar
witt what kinda power will you be putting down ?
  #733
zrated89's Avatar
witt how much boost are you seeing?
Old Mar 21, 2008 | 12:32 AM
  #734
lsjwannabe's Avatar
looks to be about 15 psi
more than his 2.8 setup
Last edited by lsjwannabe; Mar 21, 2008 at 12:32 AM. Reason: Automerged Doublepost
  #735
Witt's Avatar
Other runs I did take it to 8k but was recieving knock due to the cooler IAT2 and stupid me still had the IAT spark adder still enabled from the dyno runs. I figured most people using the 3.34" pulley will be stock engines and won't be running any higher than 7k anyway.
Old Mar 21, 2008 | 12:34 AM
  #736
lsjwannabe's Avatar
true nice job buddy
Old Mar 21, 2008 | 12:35 AM
  #737
Witt's Avatar
About a 1.3psi increase over the stock blower and 2.8" pulley if you do the math from that MAP value above. 15.3 stock blower vs 16.6 with the TVS.
Old Mar 21, 2008 | 12:42 AM
  #738
SSdan's Avatar
How does it feel vs the 2.8 setup?
Old Mar 21, 2008 | 12:43 AM
  #739
Witt's Avatar
About the same. I can't feel the 1-2psi difference.
Old Mar 21, 2008 | 12:44 AM
  #740
SSdan's Avatar
Hmm..
Old Mar 21, 2008 | 12:45 AM
  #741
KillerBee's Avatar
but those of us with gm stage 2 will feel a big difference
Old Mar 21, 2008 | 12:46 AM
  #742
lsjwannabe's Avatar
2.75" you might feel a difference
Old Mar 21, 2008 | 12:47 AM
  #743
Witt's Avatar
Probably. No idea what the actual power to the wheels is yet. It could have higher or lower parasitic loss, the thermal efficiency difference, etc.
Yeah, from what you are telling me, it'll probably be out of the ballpark for most. I'm going to hate having to install a custom MAF housing and still haven't decided on the route I want to go with fuel yet.
Old Mar 21, 2008 | 12:48 AM
  #744
lsjwannabe's Avatar
don't redline it thats all i can say
Old Mar 21, 2008 | 12:50 AM
  #745
Raven SS's Avatar
u might wanna go the same route as me then...ls2 maf with a return style fuel system
Old Mar 21, 2008 | 12:52 AM
  #746
Josh@ottp's Avatar
a ls2 maf doesnt change anything besides the size of the pipe the maf sensor is in. just get a 3 inch intake
Old Mar 21, 2008 | 12:53 AM
  #747
Raven SS's Avatar
its frequency is higher..and i have the same intake as ur brother
  #748
Witt's Avatar
Eh, bigger MAF housing would do the same, no guarantee if the LS2 MAF would give me the overhead needed.
I'm debating on return style or using a returnless electronic fuel pressure regulator with the supplemental pump I have.
Old Mar 21, 2008 | 12:56 AM
  #749
Josh@ottp's Avatar
raven ....ya its frequency will lower but thats only becuase its in a bigger pipe, the stock maf in a 85mm housing will give the same readings
witt i would go with a return style with a walbro in tank
Old Mar 21, 2008 | 12:57 AM
  #750
Witt's Avatar
Eh, its a pain in the ass to get the fuel sending unit to work with an aftermarket pump. I thought I found one or two that would be the stock height but I'm not 100% sure yet.
