first htv 1320 received
Old Mar 20, 2008 | 09:37 PM
  #676
lsjwannabe's Avatar
im keeping them and running a return style fuel rail
Old Mar 20, 2008 | 09:38 PM
  #677
z24turbo93's Avatar
lsjwannabe do you have a bigger pulley you could throw on and do a few runs with?
Old Mar 20, 2008 | 09:39 PM
  #678
06blackg85ss's Avatar
as I said **** 130%.... **** is garbage,,,, 185% is where it's at.. .and btw adjust your maf output freq a little higher and you lose resolution, but gain g/sec you can read.
no way you are flowing more than me, 67lb/min... and my **** just touches 11,111 Hz at 6800rpm.
(Im getting a little anxious lol)
Old Mar 20, 2008 | 09:41 PM
  #679
lsjwannabe's Avatar
i hit 52lb/min at 6200, im just telling you what the log says, im waiting on my 3" intake from rebel and then that goes on with the ls4 tb and i will run the meth
Old Mar 20, 2008 | 09:48 PM
  #680
z24turbo93's Avatar
Not to be a pest, but it takes what 5 minutes to put the bigger pulley on?
Atleast you could shut us up then with a video!
  #681
Blown 4-banger's Avatar
Originally Posted by lsjwannabe
130% Idc's At 6200 Rpm's The Maf Is Over 11,300 Hz, The Map Is Pegged, To Much Air Not Enough Fuel. I Will Not Blow My Car Up To Make Anyone Happy
Damn i wanted it to be all caps
^^^LMAO^^^
Old Mar 20, 2008 | 09:49 PM
  #682
lsjwannabe's Avatar
I have posted it 20 times the blower is to much for the car you have to have a serious setup to run this bad boy.
  #683
send it to me, my stock motor is the beastest lol
Old Mar 20, 2008 | 09:50 PM
  #684
lsjwannabe's Avatar
you guys have other guys for that, they have there blowers. i have a 2.75" pulley and im trying to run it.
gladly wire 2250 to my account and we will be set
Last edited by lsjwannabe; Mar 20, 2008 at 09:50 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 09:51 PM
  #685
My motor will gobble that thing up! Whats the smallest pulley you can run on it?!?!
Old Mar 20, 2008 | 09:52 PM
  #686
lsjwannabe's Avatar
the 2.75" is more than adequate for many people. Harrop does not make a smaller pulley
Old Mar 20, 2008 | 09:53 PM
  #687
Aww man! So I'm gonna have to get a custom 2.6" pulley machined for it!?!? Son of a bitch!
Old Mar 20, 2008 | 09:54 PM
  #688
WSFrazier's Avatar
I am not exactly sure on the tolerances and RPM limit of this blower. However, I doubt you really want to over-spin this thing like the M62.
  #689
only thing your motor gobbles up is money hahahahahha.... sorry man, I'm oppertunistic
Old Mar 20, 2008 | 09:55 PM
  #690
lsjwannabe's Avatar
i know them and you won't even come close on a 2.5
don't all of ours
Last edited by lsjwannabe; Mar 20, 2008 at 09:55 PM. Reason: Automerged Doublepost
Old Mar 20, 2008 | 09:58 PM
  #691
Guys at the Eaton booth at SEMA, said they successfully tested it to 21,000 rpm for extended periods, at different boost levels ranging from 20-30 psi (IIRC) in the abuse tests. A 2.6" pulley at 8000 rpm puts it just under 20,000, and with the way my engine will flow, it will probably be around 25-27 psi.
Old Mar 20, 2008 | 09:59 PM
  #692
lsjwannabe's Avatar
im at 25 at least on the 2.75
Old Mar 20, 2008 | 10:00 PM
  #693
WSFrazier's Avatar
Sounds good then. The snout looks like it will fit a 2.6/2.5 pulley, it was actually grinned down slightly already, if Harrop or someone makes them.
Old Mar 20, 2008 | 10:01 PM
  #694
lsjwannabe's Avatar
I was thinking the same thing
Old Mar 20, 2008 | 10:02 PM
  #695
MY ENGINES FLOW - Your engines flow
Mine will eat more air, thus lowering boost. Basically the same concept of an LSJ with a clogged cat running 24 psi.
Old Mar 20, 2008 | 10:03 PM
  #696
WSFrazier's Avatar
Lol, we all know basic engine knowledge Cam Cam. No need to shout. Some of us has built more LSJs than you, and before you
Old Mar 20, 2008 | 10:05 PM
  #697
I've built other engines though
  #698
lsjwannabe's Avatar
your ***** 8=D my ***** 8=============D
Old Mar 20, 2008 | 10:06 PM
  #699
Oh no... this is the beginning of the end of this thread....
Old Mar 20, 2008 | 10:07 PM
  #700
lsjwannabe's Avatar
since everything is a competetion
