first htv 1320 received
Old Mar 21, 2008 | 11:51 PM
  #851
lsjwannabe's Avatar
let me see i will have to check it out.
Originally Posted by 06black
Sean,
hows things going?
need a hand at all?
lmk, hope things are rockin out.
you can come by if you want. but as you know it has already snowed 5 inches so my car is not moving tell that is all melted. Everything is good just need more fuel for this thing.
Last edited by lsjwannabe; Mar 21, 2008 at 11:51 PM. Reason: Automerged Doublepost
Old Mar 22, 2008 | 02:05 AM
  #852
Witt's Avatar
Heh, higher horsepower likes to show flaws in the tune.
I need to recalibrate the MAF tomorrow since IFR goes out of range at 200kpa and it threw it a full point leaner at 6500rpm. Also PE entry needs to be changed from the TPS setup I have now to a MAP entry instead. It likes to get a violent shake on PE entry and exit.
I still think I can get my current system to be able to go to 7000rpm at a decent air/fuel and the 2.75" pulley and just the stock pump. If the snow holds off, I'll know after work tomorrow.
Old Mar 22, 2008 | 10:19 AM
  #853
Area47's Avatar
Rent me! per hour
now you see why i made the pe table that i did. or various other things that people look funny at.
Old Mar 22, 2008 | 12:46 PM
  #854
06black's Avatar
i set my PE trigger to map based as well, it works like a charm.
go full TPS when out of boost and hold max TPS then the fuel only comes in when the boost hits...****** snazzy!!
the stock pump should flow the fuel needed. per the info i sent you, the stock head will flow the air needed for pretty decent power, thus leaveing the intake manifold as the main bottle neck in the system.
a redesigned version, or a massivly worked over stock piece will make the largeist differance. pm me for an idea.
i'll swing by some time i figure, i'm in NO rush to go out on the roads today tho....i'm sure you feel the same.
Old Mar 22, 2008 | 12:47 PM
  #855
Witt's Avatar
Wait, how are you full throttle and not in boost?
Old Mar 22, 2008 | 12:51 PM
  #856
06black's Avatar
T4 hotside below 3k.
i edited my post above Witt, re-read.
Old Mar 22, 2008 | 12:54 PM
  #857
Witt's Avatar
I know I know, I crack myself up.
I'll get ahold of you later after work.
  #858
06blackg85ss's Avatar
yeah I need to look over my tune... haven't really played with it in a while, but I'm pretty sure that's how I'm setup too, now if I can just get it to keep an AFR up top, I'd be happy
btw where are the goddamn videos of someone driving around with this thing.... if anything, someone e-mail em to me lol
Old Mar 22, 2008 | 12:56 PM
  #859
lsjwannabe's Avatar
there are none that i know of
  #860
06black's Avatar
Haha, you has jokes!
I'm all now.
Old Mar 22, 2008 | 12:59 PM
  #861
Witt's Avatar
Honestly you can't hear **** other than the exhaust. Its real quiet, you wouldn't be able to tell the difference with the hood closed between this and the stock blower.
I'm all now.
I'm just playin, its more a jab at Dan when he sees that more than anything.
Old Mar 22, 2008 | 01:00 PM
  #862
I know lol, just want to see what this thing does... i'm pretty pissed it was announced after I went turbo'd I would have loved to have tried it out
  #863
06black's Avatar
lol no worries man, its all good.
msg me later or when ever, you'll get a kick outta this bro.
Old Mar 22, 2008 | 01:01 PM
  #864
Area47's Avatar
Rent me! per hour
turbo = slow to respond. much like his car
Old Mar 22, 2008 | 01:03 PM
  #865
lsjwannabe's Avatar
hahah i like that
Old Mar 22, 2008 | 01:04 PM
  #866
Witt's Avatar
Haha, you are pushing more air through your engine than anyone on this site and still pissed.
Time for a big diesel turbo and a 4t65e imo.
Old Mar 22, 2008 | 01:05 PM
  #867
lsjwannabe's Avatar
its quick but your faster
what were you doing with the 2.75"?
Last edited by lsjwannabe; Mar 22, 2008 at 01:05 PM. Reason: Automerged Doublepost
Old Mar 22, 2008 | 01:07 PM
  #868
Area47's Avatar
Rent me! per hour
grinning like a teenage kid who just got laid for the first time
Old Mar 22, 2008 | 01:08 PM
  #869
lsjwannabe's Avatar
i am to but i can still push it farther
  #870
djt81185's Avatar
Big diesel turbo and brake boosting ftmfw
Old Mar 22, 2008 | 01:10 PM
  #871
Area47's Avatar
Rent me! per hour
lag = foreplay
Old Mar 22, 2008 | 01:11 PM
  #872
Witt's Avatar
Wow, if theres one sure-fire way to summon you to a forum its any mention of a diesel turbo.
Old Mar 22, 2008 | 01:15 PM
  #873
WSFrazier's Avatar
I don't think your pads and rotors agree.
Old Mar 22, 2008 | 01:17 PM
  #874
06black's Avatar
let run'em, I'll show you just how slow it responds!
bitch!
Old Mar 22, 2008 | 01:18 PM
  #875
djt81185's Avatar
Of course I respond when pure fast is mentioned
They are wear items anyway...i replace as needed
