first htv 1320 received
Old Mar 22, 2008 | 04:01 PM
  #901
djt81185's Avatar
Whats with all these stock engine people thinking they are fast
Old Mar 22, 2008 | 04:02 PM
  #902
lsjwannabe's Avatar
I never said i was fast lol, far from you guys, but quick enough to play.
Old Mar 22, 2008 | 04:17 PM
  #903
Cobalt_Supercharged's Avatar
Originally Posted by fast98
that depends upon what kind of inline pump, a walbro inline is not efficently cooled by air. and if you have a big aeromotive fuel pump that flows alot all your gunna do is heat up the gas. i think inline pumps are too noisy and i dont think its gunna scare away anyone lol
Don't they make a 255 in-tank pump? Wait...that wouldn't work for Cameron since he insist that driving with more than a 1/4 tank of gas is too much extra weight.
Old Mar 22, 2008 | 04:19 PM
  #904
lsjwannabe's Avatar
lol thats what we are looking into
Old Mar 22, 2008 | 04:23 PM
  #905
Asphalt Assault's Avatar
Originally Posted by lsjwannabe
i want the snow to melt
any vids, do you plan to dyno, do you know what you AIT2's are?
Old Mar 22, 2008 | 04:27 PM
  #906
lsjwannabe's Avatar
iat was around 40 iat2 was around 80 through the end of second and mid 90's in the third, i only took it to 90 though. I have a vid of me reving the car thats about it as the car is running out of fuel
Old Mar 22, 2008 | 04:32 PM
  #907
Witt's Avatar
Just got done with about 2 hours of tuning.
Fixed mostly bullshit things that I've put off, different approach at my cam idle, PE entry point via MAP, got rid of my harsh DFCO engagement, and worked on the lower MAF for a bit.
I still need to finish MAF, just way too much traffic so it has to wait till later tonight. I fixed all the low speed things I've been putting off.
Old Mar 22, 2008 | 04:34 PM
  #908
lsjwannabe's Avatar
What's the idc's?
Old Mar 22, 2008 | 04:38 PM
  #909
Witt's Avatar
What's the idc's?
I've only touched 80% so far. I'm not lieing, theres a ton of traffic right now and I just can't get anything good as far as a WOT run. I got the MAF dialed in to 10k hz, I hope to finish it tonight and have an answer.
Old Mar 22, 2008 | 04:40 PM
  #910
lsjwannabe's Avatar
hmm, i need to figure out wtf is wrong with my car then
Old Mar 22, 2008 | 05:32 PM
  #911
Raven SS's Avatar
i have mine...no engine to put it on FTL
Old Mar 22, 2008 | 06:00 PM
  #912
mike25's Avatar
hey, sound slike you guys are getting there. especially you witt... if you dont mind id like to see that setup when i come up up, sounds like an interesting piece
Old Mar 22, 2008 | 06:43 PM
  #913
06black's Avatar
look whos talkin!
at least my **** runs!!
What's the idc's?
you have a stock intake manifold, no?
you are unable to run out of fuel.
air flow=not there.
Old Mar 22, 2008 | 07:07 PM
  #914
mike25's Avatar
air flow=not there.
i wouldve though that even if he cant flow alot more air he is still flowing more air faster which would mean the injectors would be under load for a more extensive period of time....could eventually over work the injectors....but then again this is just theory so im probably wrong
Old Mar 22, 2008 | 07:39 PM
  #915
turboeco's Avatar
So Witt would you definetly say go 79#?
I'm going to run the 75mm, from the looks of your 85mm logs 60s would be pushing it.
Old Mar 22, 2008 | 09:10 PM
  #916
Area47's Avatar
Rent me! per hour
witt. stop changing files!!!!!
Old Mar 22, 2008 | 09:14 PM
  #917
Witt's Avatar
You might be able to breeze by with the 60s but I'm not sure, it would be cutting it close.
Set idle spark back to stock, coastdown stays modified like I said and 85% of stock idle adaptive numbers seems to be best yet.
Old Mar 22, 2008 | 09:31 PM
  #918
lsjwannabe's Avatar
look whos talkin!
air flow=not there.
found problem maf = fried
Old Mar 22, 2008 | 09:34 PM
  #919
ralliartist's Avatar
that sux
Old Mar 22, 2008 | 09:35 PM
  #920
lsjwannabe's Avatar
its a quick fix i can go get one on monday
Old Mar 22, 2008 | 09:36 PM
  #921
YAY! then get some dyno numbers on monday too!
Old Mar 22, 2008 | 09:38 PM
  #922
lsjwannabe's Avatar
i work maybe my bro will dyno it, im also waiting on a 3" intake and ls4 tb so then a dyno will follow
Old Mar 22, 2008 | 09:41 PM
  #923
cool. I'm just anxious that's all. I'll probably pick up a htv1320 next year. I really want to do this f23 trans swap when I get back from my deployment. That's like the number 1 thing on my mind.
  #924
Herndon_High_SS's Avatar
Is this anybody with a TVS on here?
http://www.southfloridaracing.com/fo...ad.php?t=61185
A cobalt with a TVS.
Old Mar 22, 2008 | 09:42 PM
  #925
Witt's Avatar
Probably Sunburst SS unless another orange cobalt is running around with one that hasn't posted here.
