first htv 1320 received
Old Mar 24, 2008 | 04:09 PM
  #1126
06black's Avatar
Originally Posted by Witt
Its not the timing. Its the fuel, actually the wideband is fubarred I think.
I've only had the blower a couple days and I've only had 10 hours off between trips and been on the road 2-3 days at a time. I'll have most of this week off and will get it tuned correctly hopefully in time for opening day at the track on Saturday. We'll see.
whats the WB doing?
as they die, they go leaner and leaner....
Old Mar 24, 2008 | 04:11 PM
  #1127
Area47's Avatar
Rent me! per hour
Originally Posted by 06black
whats the WB doing?
or not move at all!
Old Mar 24, 2008 | 04:20 PM
  #1128
Blown 4-banger's Avatar
You guys all talk about fuel stuff, and sensors, and junk. I just want my car to have an engine sitting in the engine bay
Old Mar 24, 2008 | 04:23 PM
  #1129
turboeco's Avatar
You should have a stocker to play around with, during all this downtime. Yeah its wasted money, but at least you could cruise your car.
Old Mar 24, 2008 | 04:32 PM
  #1130
Witt's Avatar
whats the WB doing?
Engine is exhibiting lean symptoms.
Wideband is showing rich conditions, however as engine speed increases and the wideband shows an increasingly richer burn, the factory narrowband is slightly dropping in voltage.
I'll be off work soon and should have time to play with it for a while tonight.
Old Mar 24, 2008 | 04:35 PM
  #1131
Area47's Avatar
Rent me! per hour
don't with it too much
Old Mar 24, 2008 | 04:38 PM
  #1132
Witt's Avatar
lulwut?
Old Mar 24, 2008 | 04:48 PM
  #1133
Area47's Avatar
Rent me! per hour
"don't play with it too much"
missed a w3rd and fUx0r3d it up
Old Mar 24, 2008 | 04:49 PM
  #1134
Witt's Avatar
Yes.
Yes you did.
Old Mar 24, 2008 | 04:53 PM
  #1135
06black's Avatar
well just as back up, i always believe the narrow band over the wideband....factory equipment is rarely ever wrong when showing just a general conditions.
can you swap out your factory 02 sensor at all?
i got frickin box of them, but i bet you dont have any....
when the WB dies, it wont read rich, thats just not how they die....this is strange.
can you send me your logs, I'll stare them over.
you should have me e-mail from the fuel e-mail i send you.
Old Mar 24, 2008 | 04:56 PM
  #1136
Witt's Avatar
It may not be dieing as much as being inaccurate due to maybe heder design and behavior at high air velocity, I don't know.
I'll mess with it tonight and give you a better idea.
Old Mar 24, 2008 | 04:57 PM
  #1137
Area47's Avatar
Rent me! per hour
which wideband is it
  #1138
Witt's Avatar
Aem.
Old Mar 24, 2008 | 05:03 PM
  #1139
Area47's Avatar
Rent me! per hour
aem = fail.
80 dolla's
Old Mar 24, 2008 | 05:04 PM
  #1140
Witt's Avatar
aem = fail.
80 dolla's
Speaking of fail, any new pictures for me?
Old Mar 24, 2008 | 05:27 PM
  #1141
Area47's Avatar
Rent me! per hour
maybe
Old Mar 24, 2008 | 08:04 PM
  #1142
06black's Avatar
aem = fail.
80 dolla's
AEM > you
Old Mar 24, 2008 | 08:20 PM
  #1143
WSFrazier's Avatar
Plx > *
Old Mar 24, 2008 | 08:28 PM
  #1144
djt81185's Avatar
Originally Posted by WSFrazier
Plx > *
Truth
Old Mar 24, 2008 | 09:34 PM
  #1145
Cobalt_Supercharged's Avatar
I had a stock O2 sensor go bad on me and I started getting a lean code. I would try changing the sensors. Much cheaper than changing pistons or valves IMO.
Old Mar 24, 2008 | 09:47 PM
  #1146
Area47's Avatar
Rent me! per hour
AEM > you
if you only knew kiddo, if you only knew.
Old Mar 24, 2008 | 10:18 PM
  #1147
06black's Avatar
"kiddo", bitch i've killed 3 men!
what kinda POS WB you got honkey.....
Old Mar 24, 2008 | 10:20 PM
  #1148
06blackg85ss's Avatar
damn no vids... I spend all day working on fueling my car, and still no vids lol...
but anyway, that damn walbro pump actually fits quite perfectly... just need to cut back the feed line (grey plastic part) about 1/4 inch and mill down a plastic tab on the inside of the top of the canister and wala... even the harness is the same... so far at 18psi... 11.4:1 across the board, and my fuel pressure is back to 58 psi.. woot
  #1149
WSFrazier's Avatar
If you want to get technical, he ain't got no running wide band at the moment...
  #1150
Witt's Avatar
Widebands are for pussies imo.
BTW 79lb/hr injectors max on the stock fuel system, 2.75" HTV pulley, 7000rpm@11.4 afr.
Aeromotive Digital FMU timez.
