first htv 1320 received
Old Mar 24, 2008 | 11:04 PM
  #1176
jester's Avatar
Originally Posted by WSFrazier
What cams you go with Paul? I am really tempted to head to the Jersey meet with Al to take a look at your car. I am trying to actually buy mine back.
Iv got an empty seat or three as well
And I drove past your old car about three times last weekend
Old Mar 24, 2008 | 11:09 PM
  #1177
Greased's Avatar
so im curious, is it the fact that this is a new product or is it actually really difficult to tune? or is it just a matter of figuring out your technique?
because this is deterring me from buying one in the future if you genius's (serious, no sarcasm there) are having such a difficult time ironing out the kinks.
Old Mar 24, 2008 | 11:11 PM
  #1178
WSFrazier's Avatar
I actually took it for a spin today. She still scoots.
Old Mar 24, 2008 | 11:13 PM
  #1179
Witt's Avatar
The same happened with MAFTs back in the day, HPTuners and 60 lb/hr injectors and so on.
The key with this thing is it appeals to everybody that has an LSJ for the most part. You can run a bigger pulley with a stock bottom end and fuel system with some injectors and simple tuning and not have a problem. You also have an upgrade path if you want to pulley down and make retarded numbers like the ones that are fighting our fuel systems are doing.
Old Mar 25, 2008 | 01:03 AM
  #1180
2K5SS/SC?'s Avatar
Witt,
Would it be safe to say that if one were to upgrade to the Walbro that Paul installed, and put in the 79# Racetronix injectors you have, that it would provide sufficient fuel for the HTV1320 @ 7000-7200 max rpms?
Paul, please PM me a price for the pump/canister setup you might plan on selling. Also do you still have that stock gutted blower for the other project we discussed awhile back? I'm still keeping my options open here, but I'd like to get a game plan going for when I get back home.
Old Mar 25, 2008 | 06:46 AM
  #1181
06blackg85ss's Avatar
Yeah man still got that gutted blower, forgot to take it home from C/A yesterday, but it's still there, actually have 2 or 3 blown up s/c's if anyone needs one.
Old Mar 25, 2008 | 09:33 AM
  #1182
Witt's Avatar
Originally Posted by 2K5SS/SC?
Witt,
I'm handling it fine at 7000rpms with 79s and a 2.75" pulley though I am at the limit. The pump doesn't seem to be giving any issue.
Anything more though will require something to boost compensate fuel pressure.
Old Mar 25, 2008 | 11:17 AM
  #1183
mike25's Avatar
hey witt i hit you up with a pm....send me one back when you get a chance....and good work with the cars guys...definately making headway
Old Mar 25, 2008 | 11:31 AM
  #1184
Area47's Avatar
Rent me! per hour
wheeeeeeeeeeee
good info to know paul.
bryan. innovate lc1. bitch.
kbai
Old Mar 25, 2008 | 11:42 AM
  #1185
Deathscythe's Avatar
how/ why is or would the innovate wideband be better than the aem?
Old Mar 25, 2008 | 11:47 AM
  #1186
Area47's Avatar
Rent me! per hour
more accurate. logging software comes with it. cheaper replacement costs when the sensors go bad. doesn't say aem.
Old Mar 25, 2008 | 11:52 AM
  #1187
Omega_5's Avatar
The AEM is slightly less accurate than the Innovate... but where the Innovate really shines is the latency. The Innovate has the least latency of all the wideband units on the market.
Although for a gauge, latency isn't a big deal... but for tuning and logging, it's a very big deal!
Old Mar 25, 2008 | 11:55 AM
  #1188
The only thing i remember seeing for the innovate was the handheld tuner thingie...(?) Does it also come with a gauge to mount?
Old Mar 25, 2008 | 12:04 PM
  #1189
djt81185's Avatar
It uses the same sensor my PLX does...the 80 dollar Bosch LSU4.2 also I have yet to see anything have a better refresh rate then my m300 plx...gauge refreshes ridiculously fast and same with the logging itself.
Old Mar 25, 2008 | 12:07 PM
  #1190
I need that man, my aem is wierd,, ,also from what it displays, to what is actually logged is always off... I dunno
Old Mar 25, 2008 | 12:24 PM
  #1191
is the scan rate that bad for the aem?
Old Mar 25, 2008 | 01:34 PM
  #1192
06black's Avatar
i will give the PLX props from refresh rate, but i'll put money on how accurate and refresh rate of the AEM being dam good.
i will never use, install, nor recommend an inovate unit. every one i've seen or dealt with has had issues, be it F-body or LSJ....pure garbage.
the gauge is different that whats logged?
let me know paul, i had the same issue and i re-wrote the EB offsets into the Scanner. fixed the issue real good.
Old Mar 25, 2008 | 01:38 PM
  #1193
Area47's Avatar
Rent me! per hour
i have had zero issues from my lc1 innovate
Old Mar 25, 2008 | 01:46 PM
  #1194
pjk91's Avatar
The LC-1 is very sensitive when it comes to ground offsets. I sold mine for an AEM. I wish I didn't do that. The Innovate gauge is way sexier than the AEM's tacky LED bar/number display. I had a few minor issues with my LC-1 that frustrated me at first, but then I figured them out. By the time I figured it out, I had a buyer for it...who made out like a bandit. Hopefully he is putting it to good use.
Old Mar 25, 2008 | 01:51 PM
  #1195
06black's Avatar
this issue is caused by the lack of work done on HPT part...not AEM nor me.
assjockey.
HPT has pre-made offsets for most widebands...the one for the AEM is wrong.
Old Mar 25, 2008 | 01:54 PM
  #1196
2K5SS/SC?'s Avatar
^^ I really need to get your scanner setup then. I'm using the one Paul sent me which works pretty damn good, but if yours is better I can't go wrong for asking the turbo god.
Old Mar 25, 2008 | 01:56 PM
  #1197
06black's Avatar
meh, no turbo god.
dan got my into this whole mess...then i spent the next 15mo learning and reading every thing i could about turbos...how they act, react, how to pick the rite one, what variable effects what, ect.
PM me your e-mail, and i'll CC you onto the one i shoot paul.
Old Mar 25, 2008 | 02:15 PM
  #1198
Area47's Avatar
Rent me! per hour
assjockey.
cumdumpster.
this is why you set it up yourself
Old Mar 25, 2008 | 02:20 PM
  #1199
djt81185's Avatar
LOL the plx doesnt give a **** what its grounded too...mine has power from rear cig lighter and then grounds to the black going away from the rear cig lighter...is within .1-.2 afr of the 2 dynos i had afr readings at. And its electrical taped in...black tape ftw
Old Mar 25, 2008 | 02:23 PM
  #1200
Witt's Avatar
I call shens on anything installed electrically in your car correctly, including the use of "black tape".
