Harrop HTV1320-LSJ using Eaton TVS technology
Old Jan 24, 2008 | 08:51 AM
  #276
redlineblueline's Avatar
ah so you can use lower flow injectors on a return system than you can on returnless?
Old Jan 24, 2008 | 09:07 AM
  #277
shabodah's Avatar
Dear EVERYONE,
GM and other car manufacturer's use returnless fuel systems for ONLY TWO reasons:
1) Lower production Cost
2) Lower Emissions
THERE ARE NO OTHER BENEFITS TO A RETURNLESS SYSTEM.
WE should ALL USE RETURN-STYLE systems.
Old Jan 24, 2008 | 09:08 AM
  #278
djt81185's Avatar
yes...and return systems can prevent cylinder rich/lean issues since pressure is kept stable across the rail...assuming u enter at one end and leave/reg pressure at the other
Originally Posted by shabodah
Dear EVERYONE,
2) Lower Emissions
all evos including the current evo x use return systems...imo return systems are where its at
Old Jan 24, 2008 | 09:13 AM
  #279
hmmm a return system will be added to the mod list
Old Jan 24, 2008 | 09:22 AM
  #280
WickedSS2005's Avatar
Originally Posted by skymynx
whens it gonna be available
After sufficient testing and full completion of the product. Few months maybe?
Old Jan 24, 2008 | 09:32 AM
  #281
SJSchafer's Avatar
Put it this way - In a returnless system you actually have more fuel pressure at high VAC (idle and decel) and lower fuel pressure at WOT. That is the exact opposit of what we actually want. With small injectors, this only plays a part at the upper end of the fueling where they run out of room causing high duty cycles. People get bigger injectors to get more fueling up top, but those bigger injuectors lose the ability to run linear at really low PWs, causing low PW errors. By going to return style, you have the same effective fuel pressure everywhere, because your regulator lowers pressure during VAC and raises it as you give it more throttle. That allows you to run higher PWs at idle and decel and eliminates the low PW errors. It also allows you to run lower PWs at accelleration, giving more room up top. Other advantages as far as tuning - Your IFR table is flat, one number across the board. Also, your offset table changes only by volts, not volts and VAC. Also, witt, I have tons of respect for you as a tuner, but IMO tuning your VE and MAF to make up for fueling issues is not the best way to dial in injectors. It's just semantics, but I believe that you tune fuel for injectors and MAF and VE for air.
Old Jan 24, 2008 | 09:56 AM
  #282
Witt's Avatar
There is no other way once you pass the 550cc mark. Not a matter of semantics, its a matter of consistently achieving desired afr.
You have to realize why the IFR table is written to understand why the slack can be taken up in MAF. Its made to be a quick change method of fuel injector swapping by using the table as a common devisor. You're taking commanded fuel from one side of the equation and moving it to the other.
I'm more concerned with load on the PCM circuitry for the high impedance driver than the tune itself. Fuel tune is nothing more than pulse width. Once you start getting up into high flow injector ranges, parts become larger and power demand needed to operate them is increased. This is why you don't see high impedance fuel injectors much large than 700-800cc.
Old Jan 24, 2008 | 10:55 AM
  #283
Scythe_Snake's Avatar
GM says you don't need a Fuel Return line until like 500-600hp... so my guess is going to be NO, a return fuel line won't really help.
My belief is the same as that of Bill Hahn Jr... that our problems lie with in our very poorly designed Intake Manifold.
The return-less fuel system is a problem as well from what I learned, but the intake manifold is yet another. Perhaps Mr. Hahn should give us a better intake mani? :P
I know some company is supposed to be working on one for us taht is supposed to be killer.
Old Jan 24, 2008 | 11:07 AM
  #284
Witt's Avatar
Actually SJShafer, I take that back about having to take up IFR slack in the MAF. djt81185 and area47 informed me that adjusting the voltage flow rate modifier does work. I've been meaning to retune using this table but haven't been able to keep my cable long enough to get around to it. The goat guys keep bumming it off me.
Old Jan 24, 2008 | 11:09 AM
  #285
Deathscythe's Avatar
Scythe_Snake..., the problem with that is he really has no interest in the supercharged side of our cars. The twincharged method was of interest for a while, but when that became too problematic, then they scrapped that altogether. But you are right; we do need someone to develop a better intake manifold for our cars.
Old Jan 24, 2008 | 11:10 AM
  #286
Area47's Avatar
Rent me! per hour
wrastle dem bitches up!
you can run up to 127 lbhr injectors in hpt.
not recommended by any means.
Old Jan 24, 2008 | 11:16 AM
  #287
Witt's Avatar
You mean you don't have a ballast box yet?
Slacker.
Old Jan 24, 2008 | 11:18 AM
  #288
Area47's Avatar
Rent me! per hour
Slacker.
i have no desire to have a dsm or honda part on my car
mainly dsm part.
Old Jan 24, 2008 | 11:23 AM
  #289
djt81185's Avatar
mainly dsm part.
Atleast Hondas and DSMs have been known to go fast...
Old Jan 24, 2008 | 11:30 AM
  #290
but you spend as much money on mods on a DSM as you do replacing broken pieces
Old Jan 24, 2008 | 11:32 AM
  #291
djt81185's Avatar
Mod it when u break it..aka mod what u break
Old Jan 24, 2008 | 11:35 AM
  #292
until the timing belt snaps and fubars what you just modded
  #293
Area47's Avatar
Rent me! per hour
true enough.
i got away from dsm's and anything related to them, i plan on keeping it that way
Old Jan 24, 2008 | 12:04 PM
  #294
2K5SS/SC?'s Avatar
Wow this has nothing to do with Harrops thread I from what I can tell, but the injector resistor box does indeed work great. I used one from a CRX for my Integra. It allowed me to use the nice 560cc EVO injectors as they are much cheaper for the whopping $75 I paid for them than the expensive RC injectors! I now look at modding from a different perspective after owning my Integra. More expensive and sofisticated is not always the best way to get the same desired results.
Old Jan 24, 2008 | 12:11 PM
  #295
Edubs's Avatar
I love how you mention we're so off topic and then proceed to steer us off course...
Classic!
I'm just eff'n w/ ya 2K5...
  #296
AlphaJaguar5's Avatar
Classic!
+1 Didn't even notice that
Old Jan 24, 2008 | 12:14 PM
  #297
Witt's Avatar
Not much else to talk about until Harrop releases some more news. /shrug why not jack the thread. Doing my part to keep it alive.
Old Jan 24, 2008 | 12:36 PM
  #298
06blackg85ss's Avatar
I need to get my hands on the 875's man, someone pm me the link. I'm hitting btwn 144-156% IDC now on the 60's lol. need more fuel.... car is hungry
Old Jan 24, 2008 | 12:38 PM
  #299
Witt's Avatar
Racetronix's website.
I bet they have damn near the same min. pulse width as our crap 650/660s being a disc setup. RC engineering has 750s as well.
Old Jan 24, 2008 | 12:40 PM
  #300
gonna check that out. Also probably going to go with a return setup in a week or 2 jut need to order the rest of my parts .
