Harrop HTV1320-LSJ using Eaton TVS technology
Old Jan 24, 2008 | 06:53 PM
  #326
Witt's Avatar
Originally Posted by Area47
thanks. i work out
Modest are we?
To the guy above. Those extra injectors and rail allow a second set injectors to be used instead of having a larger set of low impedance injectors. Improves drivability and idle when low impedance ones would be otherwise required.
Old Jan 24, 2008 | 07:04 PM
  #327
AlphaJaguar5's Avatar
Originally Posted by Witt
Modest are we?
What the light ball said.
Old Jan 24, 2008 | 07:17 PM
  #328
shabodah's Avatar
I'm not here to pick on the manifold and the fuel design of it, but side-by-side injectors in a 4 valve engine would provide a better pattern and thus, better fuel atomization than front and rear injectors.
Old Jan 24, 2008 | 08:35 PM
  #329
06blackg85ss's Avatar
Originally Posted by ebristol
If you are getting the Hahn intake manifold why not go for the PortFueler option?
Bill is making it sound like it is easy to tune and you wouldn't have to worry about getting bigger injectors. Just a thought...
already ordered man.
but with my power goal I'm going to need more fuel then the stock PCM can supply on it's own, so 8 injectors should cover me til I run out of things to do to the car lol
Old Jan 24, 2008 | 08:49 PM
  #330
SJSchafer's Avatar
Actually SJShafer, I take that back about having to take up IFR slack in the MAF. djt81185 and area47 informed me that adjusting the voltage flow rate modifier does work. I've been meaning to retune using this table but haven't been able to keep my cable long enough to get around to it. The goat guys keep bumming it off me.
Actually, I was going to mention that. Area47 uses my fueling tables. Marcin Pohl and I actually confirmed that the method does work. We can't really verify for sure that it works impeccably past the 63.5 mark, but I am in the process of working on a way to prove it for sure. If my testing works out, you will be able to switch from 42s to 60s without ever having to change the MAF.
Wish me luck.
Sorry to thread jack.
Old Jan 24, 2008 | 09:15 PM
  #331
widebody_balt_ss's Avatar
all this talk about fuel is awesome, dont get me wrong. but I want more on the damn supercharger!!! with all due respect
Old Jan 24, 2008 | 09:20 PM
  #332
well once you get into the power levels this s/c is capable of, you're eventually gonna need to the fuel setup anyway. might as well learn about it now
Old Jan 24, 2008 | 09:42 PM
  #333
quadracer0387's Avatar
so with this you will not need a return-style fuel system... correct?
so how big of injectors would you need?
Old Jan 24, 2008 | 09:51 PM
  #334
LopsidedJester's Avatar
I'm also curious as to know the fuel demands. i know its said not to be a bolt on kit, but would there be a sufficiently smaller pulley to run on the supercharger to be able to run on 42lb injectors, or would it be spun way to slow to be efficient or useful?
Old Jan 24, 2008 | 10:12 PM
  #335
USMCFieldMP's Avatar
Rattlesnake Race Shop
Do you mean a way LARGER pulley?
Old Jan 24, 2008 | 10:21 PM
  #336
sorry, thats what i meant, a larger pulley to push less air for the 42 lbers.
Old Jan 24, 2008 | 10:26 PM
  #337
Raven SS's Avatar
my question to this is why?! if ur gonna buy this its for more power..why would u back it off?! just doesnt make sence to me if ur gonna dead it down below a m62 then i dont see the point of buying it..
Old Jan 24, 2008 | 11:10 PM
  #338
i mean more for a temporary purpose til 60lbers are bought, installed and tuned, but i guess i see your point. Probably shouldn't install it til power is ready to be made, it is a pretty serious blower
Old Jan 24, 2008 | 11:30 PM
  #339
Yeah... that'd be like buying at GT42R turbo and hooking it up... buy only running like 5 psi so that you can use your stock injectors. Haha... yeah, not really worth it.
Old Jan 24, 2008 | 11:51 PM
  #340
liolixli's Avatar
I can't wait until that extra tax refund thing comes. My money I think is going back into the Australian economy lol.
Old Jan 25, 2008 | 12:21 AM
  #341
2K5SS/SC?'s Avatar
Originally Posted by Edubs
I love how you mention we're so off topic and then proceed to steer us off course...
Classic!
I'm just eff'n w/ ya 2K5...
I know you're just messing around! All the threads we get in lately seem to go this way. I just have to say that as a catch 22 clause up front before I join in on the fun!
As for the 750's or 875's, I'd love to see them tried out on our HPTuners controlled PCM.
Paul, do it....hey ::head nod:: do it....
If we could get those to work well it would make the 400+whp mark a lot easier to get to for sure. When do we need to upgrade the fuel pump though is what I'm wondering? Most Honda guys upgrade to Walbro 255's at around 440cc even know I've found you can run 560's on a stock pump without a worry. We're already up to 60lb injectors which are equivalent to 630cc's, so how much farther can we go safely?
Old Jan 25, 2008 | 06:54 AM
  #342
I dunno anyone know what are max gph is on our fuel pumps? or at least what size they are.
Anyway sold some extra stuff I had laying around, so tomorrow I'll be ordering the fuel pump and what ever else I need to do the fuel system over.
BTW does anyone know if the SMG fuel rails for the older eco's will bolt up to our motors? I would much rather use a straight flow through rail then the 02 cavi rail I got.
Old Jan 25, 2008 | 07:32 AM
  #343
2K5SS/SC?'s Avatar
Paul are you going to try the injectors before the new fuel system or are they going to be a part of your custom setup?
Old Jan 25, 2008 | 10:48 AM
  #344
Area47's Avatar
Rent me! per hour
honda, in their worldly wisdom, didn't plan ahead in 92 that the b series would see a level of hp that they are being pushed to now. hence the tiny pump from the factory. it was ment for 300k miles of flawless operation. not 100k of 500 fwhp.
dropping fuel pressure on th lsj is a sign of the pump running out of breathing room. or a clogged filter. either one
Wish me luck.
oh heerrooooooo
long time no talk
Modest are we?
i do what i can
Old Jan 25, 2008 | 11:03 AM
  #345
SJSchafer's Avatar
oh heerrooooooo
long time no talk
Yea, been real busy and the weather sucks. How's stuff?
Old Jan 25, 2008 | 11:06 AM
  #346
Area47's Avatar
Rent me! per hour
cold, snowing. again. usual stuffins. work sleep, video games. repeat
back doin better?
Old Jan 25, 2008 | 11:13 AM
  #347
SJSchafer's Avatar
back doin better?
Much better. Thanks. If this weather ever clears, I will pulling out my 42s and putting the 60s back in. My fingers are crossed to get some numbers for the 60s that everyone can use without all the idle and decel issues.
Old Jan 25, 2008 | 11:20 AM
  #348
Area47's Avatar
Rent me! per hour
no surge with a/c or defrost on? i have since adjusted my driving style to compensate for this cute little lsj ordeal. just seems a bit annoying sometimes. oh well
Old Jan 25, 2008 | 11:26 AM
  #349
djt81185's Avatar
I was doing some research on fuel rail designs for return setups and the 02 cavi isnt a bad setup at all...It allows us to keep the pulse dampening capability of the lsj rail end with the controllability or a return line...I was gonna go straight thru but i think im going to try the cavi first.
Old Jan 25, 2008 | 11:33 AM
  #350
shabodah's Avatar
What benefit is there to having pulse dampening in a return style system?
