Harrop HTV1320-LSJ using Eaton TVS technology
Old Jan 25, 2008 | 04:52 PM
  #376
Area47's Avatar
Rent me! per hour
if you have an a1000 under the car. noise is the least of your worries.
Old Jan 25, 2008 | 05:03 PM
  #377
06blackg85ss's Avatar
lol, but thats a good noise though.
I'm just gonna drop my car off at my friends shop and let him do the fuel system, I really don't feel much like doing it myself right now after last weekends 18 hour fiasco with the turbo swap. which BTW sucked in my air filter and pulled all the fiberglass off the firewall..... ****** crazy. so I also need to buy a new filter and some more piping tomorrow to relocate it away from the firewall while I still have oneleft.
Old Jan 25, 2008 | 05:05 PM
  #378
Area47's Avatar
Rent me! per hour
bwhahahahha
funny **** isn't it
had a skyline do that at an old shop i worked at. i giggled. the owner cried
Old Jan 25, 2008 | 05:09 PM
  #379
lol, my filter looks like someone chewed on it,,,, still somewhat cone shapped, but it's all twisted and mangled lookin now, plus it has a **** ton of fiberglass in it, so it's time for a new, better flowing and better placed one.
Old Jan 25, 2008 | 05:24 PM
  #380
Area47's Avatar
Rent me! per hour
the main concern would be the turbo itself.
the two on the skyline ate the filters, and the turbo's to the tune of 2k a piece at dealer cost
Old Jan 25, 2008 | 05:31 PM
  #381
Witt's Avatar
Heh, Dan just uses the rad. support as a filter. If it sucks that in, I'll let ya know.
Actually its like that so it gets absoultely the quickest spool possible.
Old Jan 25, 2008 | 05:33 PM
  #382
Area47's Avatar
Rent me! per hour
al, i have an idea for your fuel system idea.
Old Jan 25, 2008 | 05:38 PM
  #383
Witt's Avatar
I'm probably going to say no but lets hear it anyway.
  #384
Raven SS's Avatar
lol so optimistic
Old Jan 25, 2008 | 05:46 PM
  #385
Witt's Avatar
Originally Posted by Raven SS
lol so optimistic
I've been the victim of enough Pittsburgh crew hairbrained schemes to spot one when I see it coming.
  #386
Area47's Avatar
Rent me! per hour
oh you're no fun!
you're not caffinated today
anyways.
y block out of the normal feed line
whatever pump you so desire to use
hobbs switch set to 5 psi to kick on "bigger" pump
y block with a check valve before, and after said pump.
y block about 6 inches away from fuel rail
-8 an line feeding it.
this is actually a current set up on a friend of mines tt402 c5z. works flawlessly
this one actually works!
Old Jan 25, 2008 | 05:56 PM
  #387
Witt's Avatar
How would you regulate the pressure of the second pump or is this a return system?
Old Jan 25, 2008 | 05:59 PM
  #388
Area47's Avatar
Rent me! per hour
ok, so i forgot the key part, like usual. aeromotive regulator.
nevermind, im in a special retard mood. forget that idea
Old Jan 25, 2008 | 06:10 PM
  #389
shabodah's Avatar
Originally Posted by djt81185
You dont have to...but i was reading a small snipet talking about how it helps with noise and flow oscillations.
My concern, is that at higher fuel pressures (if 54 is base and you're boosting 23- that comes to 77 psi) it could fail allowing lower pressure.
I couldn't care less about the noise. Heck, I'm still annoyed car manufacturers have "intake mufflers" stock. What a joke!
Old Jan 25, 2008 | 06:11 PM
  #390
Area47's Avatar
Rent me! per hour
the pressure stays the same in the rail. the volume changes.
Old Jan 25, 2008 | 06:22 PM
  #391
shabodah's Avatar
Not with the referenced aeromotive fuel pressure regulator, it doesn't.
The DIFFERENCE between manifold pressure and fuel pressure stays the same (or at least that is the goal), so that fuel metering stays the same.
Old Jan 25, 2008 | 06:25 PM
  #392
Area47's Avatar
Rent me! per hour
as i said to witt. im in special retard mode.
Old Jan 25, 2008 | 06:33 PM
  #393
shabodah's Avatar
It is Friday afterall. No biggee. lol. Where's my drink?!??!
Old Jan 25, 2008 | 06:51 PM
  #394
Area47's Avatar
Rent me! per hour
apparently i drank it all already
Old Jan 25, 2008 | 06:53 PM
  #395
shabodah's Avatar
Huh. Well, that's too bad. We should all buy the guy's (and girl's) at Harrop's a drink...
Old Jan 25, 2008 | 06:55 PM
  #396
Area47's Avatar
Rent me! per hour
i'll send em some natty lite
Old Jan 25, 2008 | 06:59 PM
  #397
SJSchafer's Avatar
So Bryan, when're you gonna trade wings with me.
Old Jan 25, 2008 | 10:36 PM
  #398
KillerBee's Avatar
Sounds to me like we are gunna need at leats 60lb injectors and some fordge pistons to get the 2.75 pully option
Old Jan 26, 2008 | 01:38 AM
  #399
Witt's Avatar
Only way it could affect pressure is if it failed and leaked to the atmosphere. Its still within a closed system.
I figured it was hairbrained.
Old Jan 26, 2008 | 01:41 AM
  #400
lol, well just met up with a friend that has a local shop, if all works well with the return setup on my car, it's gonna be out as a complete kit, so stay tune, should be done within the next 2 weeks or so
