Harrop HTV1320-LSJ using Eaton TVS technology
Well, those of us that aren't looking for 500+whp applications.
well for the 60's I do have the flowmatched ones..
If someone tells me which injectors they are, I'll order em right now and try em out since I need something desperately since I am running out of injector @5800 rpm now stays btwn 132-144% IDC at WOT and 22psi. I will also be doing the return setup on the car soon, just waiting to pick up this jeep my friend got so I have something to daily drive while the car is down
http://www.racetronix.com/01D129xFM.html
Then you can put in bigger injectors
still on the stock motor, but doing the cams and valve springs very soon.
new motor will have:
Pauter Billet Chomoly rods
diamond racing 9.5:1 pistons
ARP head studs
Cometic head gasket
Still tossing up btwn the JBP stage II head, or just getting mine ported
272 cams (going out this week to get reground)
Stock crank
Sleeves (still need to order lol)
Hahn intake mani (just waiting for it to come in)
will be converting to return style fuel system soon.
ARP head studs
Cometic head gasket
Stock crank
ARP head studs
Cometic head gasket
Stock crank
ARP head studs
Cometic head gasket
Stock crank
Ok so I'll go return style first. Probably order the fittings and pump and crap this weekend. should have it in a week or so later. Then we shall see, but even with the experiences I've had with the sRT-4 guys, they go to 750-850 cc injectors on a return line setup @400whp or so.
ARP head studs
Cometic head gasket
Stock crank
ARP head studs
Cometic head gasket
Stock crank
Comes out of the FMIC at 2.5" and increases to 3" for about 12"s where the MAF is, then back to 2.5"
I know it's a shitty setup, but for now that's all I got. Haven't had anytime to fix it yet, was going to do it last weekend, but issues with installing the bigger turbo prevented me from finishing it.
definitely will do man.
Last edited by 06blackg85ss; Jan 24, 2008 at 01:08 PM. Reason: Automerged Doublepost
Dan is saying his shims haven't moved except for the part on cylinder two where the con rod bearing failed. I want to be 100% before I change blowers. When I get a day off this weekend I'll pull the cam cover and verify they are still where they should be.
ARP head studs
Cometic head gasket
Stock crank
ARP head studs
Cometic head gasket
Stock crank
Bill is making it sound like it is easy to tune and you wouldn't have to worry about getting bigger injectors. Just a thought...
want to know my feelings on it. look inside it. you will see my feelings.
if the shims are set in one place. i don't see the need for a revision. then again. my **** is still in boxes in my basement
It just seems to me like a lot of hassle when I can just convert to return and use my pcm instead of an SMT-6 or whatever he's using. That being said that is a sexy ass piece of hardware and defiantly a smart idea for alot of cars. A nice size primary injector with a bad ass secondary injector always makes for a nice dd.
