Harrop HTV1320-LSJ using Eaton TVS technology
Old Feb 9, 2008 | 08:49 AM
  #726
06blackg85ss's Avatar
yeah that's what I picked up too, exedy ftw lol. I just need to do something asap with the fuel situation. I'm hitting crazy IDC's and my car is just all over the place with fueling, no matter what I change in the tune, or anything it always does the same thing at 22 psi, so I'm running 19 right now, but since the clutch is slipping I really can't get any accurate numbers, also that could be why my car does what it does, but we will soon find out once the new clutch is in.
Old Feb 9, 2008 | 10:03 AM
  #727
Area47's Avatar
Rent me! per hour
revelations hit me. your wacky idc is an issue between maf and pe.
Old Feb 9, 2008 | 10:13 AM
  #728
yup, 2.5" piping is f'in up my maf output freq, hence why the high numbers, there;s a lot of turbulance in there, you can actually hear it under boost. But will all be fixed in the next few days, car is getting gutted and pretty much totally redone.
Old Feb 9, 2008 | 10:22 AM
  #729
Area47's Avatar
Rent me! per hour
sweet!
i was also shown the light in pe tweaking. the car doesn't like straight lines in trying to maintain a steady afr
look at your afr actual in reference to your commanded
Old Feb 9, 2008 | 10:25 AM
  #730
yeah I know, the curve is usually a little spikey, this log run is from my first pulls with the new turbo in and pretty much untuned. I haven't had time to try and dial it in lately, and since everything is getting completely redone, I'm not gonna bother, plus I won't really be driving it much once I pick up the jeep. but I do want to get it ready to run at the track march 1st, so I'm going to need to put a lot of miles on it and a lot of dyno time.
Old Feb 9, 2008 | 10:35 AM
  #731
Area47's Avatar
Rent me! per hour
holy crap. you don't have much time left man!
since you're not driving the car till the motor n crap goes in it, my idea for a fix is null and void.
Old Feb 9, 2008 | 10:45 AM
  #732
supercharged414's Avatar
I can't wait to see Paul's cobalt on the track in March. I saw it last night and it sounds bad ass. Good luck finishing up Paul.
  #733
well motor is being delayed again for abit due to me getting screwed out of half my bonus at work (long story but only got 4g's instead of 8g's came out to $2400 after taxes) I figure the intake mani, new fuel pump, return line, new FMIC, new BOV and piping are the most important right now to keep the stock motor alive, which somehow it still is after a few pulls on the street where the car leaned out to @14-15:1 afr under full boost. (It does freakish things like that occasionally)
Old Feb 9, 2008 | 10:50 AM
  #734
06black's Avatar
Originally Posted by Area47
sweet!
man, who came up with that idea!!!
Old Feb 9, 2008 | 10:51 AM
  #735
Area47's Avatar
Rent me! per hour
im not saying ****!
Old Feb 9, 2008 | 11:11 AM
  #736
lol I wonder.
For reasons due to air turbulance at the maf, my car does not respond well to that kind of tuning, 06black I tried running your tune and the car did not like it one bit, idled like ****, leaned out real bad, actually got some KR (I never get any for some odd reason). I can't wait to redo this **** so I can finally tune it properly. anyone that looked at my tune on the car was surprised it actually ran, but it's the only way it does.. damn cobalts
Old Feb 9, 2008 | 11:21 AM
  #737
djt81185's Avatar
How can u figure its the maf and pe...there is no hz logged for the maf...only lb/min which isnt calculated until after it receives the hz reading and goes thru the maf calibration table.
And what is this straight line pe **** u talk about...pauls car has the same problems as mine...spill it or ban.
Old Feb 9, 2008 | 11:24 AM
  #738
the HZ actually stays pretty good, but I had to play with the maf output vs freq to get the car to somewhat run right, hence the high maf lb min reading compared to the VE reading. Won't have to worry about it soon though.
for fueling issues though, once I get the hahn port fueler setup, I was thinking about running a set of 42's as the primary injectors and 60's as secondaries, completely zero out the stock computers control of the fueling in boost, and leave that up to the port fueler setup which will run on a simpler MAP VS RPM map (1000 point adjustable too) I think that will clear up 99% of my issues
Old Feb 9, 2008 | 11:27 AM
  #739
djt81185's Avatar
I meant u cant see maf turbulence unless u have the hz up...if the curves are smooth there is no turbulence
Old Feb 9, 2008 | 11:30 AM
  #740
Area47's Avatar
Rent me! per hour
look at the afr actual vs cmnd.
the maf stays set at a pre-determined setting. then the pe is changed according to the air flow so to speak. forced induction isn't a straight line.
if i spilled more, id be drawn and quarted
Old Feb 9, 2008 | 12:56 PM
  #741
djt81185's Avatar
The commanded vs actual only shows the failing of the injectors to fire for the proper time and their result on the af...which makes it go lean. also pe isnt based on airflow..its based on rpm
Old Feb 9, 2008 | 01:08 PM
  #742
Area47's Avatar
Rent me! per hour
hence the so to speak
air flow does play a role in how pe is added in said percentage. a 2.7 car is flowing "more air" than a 2.8 car. so, a person adds fuel in the pe side to go with this. or maf settings, either one.
everyone has different tuning styles. air flow is not linear
Old Feb 9, 2008 | 01:15 PM
  #743
2K5SS/SC?'s Avatar
My PE table has never been a straight line. Mine sort of starts high and about mid rpm range swoops down to a lower level with some minor speed bumps at the end. My A/F ratios stay on target though!
Now, I am still learning the timing tables though. I've got it figure out for the most part, but I just don't like the idea of selecting a big group of blocks and typing in what advance I want in the end. I personally think that a steady progression to what I desire for timing make better sense. Am I right on this, or just completely jacked up?
  #744
well anyway, new fuel system will be ready for testing by the weekend, new clutch will be in. and hopefully my parts from Hahn arrive this week so I can "fix" my piping.
Old Feb 9, 2008 | 01:17 PM
  #745
Area47's Avatar
Rent me! per hour
timing is easy!
i hate fuel
Old Feb 9, 2008 | 01:20 PM
  #746
yeah timing is the easy part. fueling is what really sucks
Old Feb 9, 2008 | 01:21 PM
  #747
Area47's Avatar
Rent me! per hour
someone who is in the same boat as me.
is it sinking?
Old Feb 9, 2008 | 01:23 PM
  #748
lol right now yes, but after new pump and return line, hopefully not.
Also I need to put my SCIP sensor back in. I think thats whats causing my horrendous bog if I go WOT it drops to 10.0:1 afr even if its out of PE. stupid sensors....
Old Feb 9, 2008 | 01:25 PM
  #749
2K5SS/SC?'s Avatar
Oh, I agree on that too! Fuel takes forever to dial in for me as I make small adjustments so I don't break anything!
Area, do you think you could possibly send me a screen shot of your "good" timing table? I promise I won't give it out and I can't use it anyhow since I'm away from my car for the next 5 months anyhow! I'm just curious to see what yours looks like compared to mine and the one Paul sent me awhile back.
Old Feb 9, 2008 | 01:27 PM
  #750
Area47's Avatar
Rent me! per hour
i have a whole bunch of em. just depends on my mood on which ones i run
