LE5 cam swap into LAP
Old Aug 17, 2011 | 03:17 AM
  #51
09LAP's Avatar
Originally Posted by FlyingLow
I believe I had a sensor (either crank or cam) go bad and throw off the reference point. As for right now it runs like absolute garbage. Surges like bucking bronco at a stoplight, hold the rpms steady at 1500-2500 and you hear the thing misfire nonstop, and its down on power. Got my ass handed to me by a stock scion tc. And I have full bolt ons
. I'm about to just give up on this motor, throw a low miles boneyard motor in and sell the thing.
did they time it with a gun or by the refrence points on the chain/gears/ect...?
Old Dec 23, 2011 | 08:14 AM
  #52
09LAP's Avatar
low you ever find out?
Old Aug 23, 2012 | 10:18 AM
  #53
rcarr0327's Avatar
anything?
Old Aug 23, 2012 | 02:37 PM
  #54
nhanson's Avatar
Im still thinking they are swappable....
Old Aug 25, 2012 | 03:20 PM
  #55
rcarr0327's Avatar
From reading this thread I'm leaning towards that too, really wanna try this out.
Old Aug 25, 2012 | 03:44 PM
  #56
nhanson's Avatar
I emailed ZZP and they said the cams were specifically for the LE5 and wouldnt work. But didnt tell me what was different.
Old Aug 25, 2012 | 09:11 PM
  #57
elecblue06's Avatar
could be too much lift/ duration or something
Old Sep 4, 2012 | 07:58 PM
  #58
09LAP's Avatar
same, leaning more towards duration :/
Old Sep 4, 2012 | 08:57 PM
  #59
LS6Rally's Avatar
Flying low, are you now driving the car with "16 bent vales and nicked pistons" why is it running like ****?
the LAP is 10:1 vs the LE5's 10.4:1 so the piston to head height shouldn't be an issue, especially with the reduced stroke of the LAP (94.5vs98mm) we've already established that the head is the same P/N, so i would imagine everything would be the same, possibly even the cams, but im sure valves, springs and whatnot are.
So IMHO the timing was not set properly on Flying's car, as others have stated.
has anyone looked up the stock cam specs for both motors? i've been hunting for LAP stuff, but no luck
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
Old Sep 4, 2012 | 10:38 PM
  #60
09LAP's Avatar
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
ya the lap junk is hard to find been hunting occasionally but with no luck
Old Sep 4, 2012 | 11:38 PM
  #61
nhanson's Avatar
this is the best i found
https://www.cobaltss.net/forums/2-2l...-specs-137232/
Old Sep 9, 2012 | 01:12 PM
  #62
09LAP's Avatar
^^^nice find
Old Dec 1, 2013 | 09:12 PM
  #63
09cobalt 2.2's Avatar
Hate to dig up an old thread but has anybody find out if you can use 2.4 comp cams in a LAP
Old Dec 2, 2013 | 12:46 AM
  #64
nhanson's Avatar
Nope. ZZP said no to me but didnt give any reason why.
Old Dec 2, 2013 | 11:35 AM
  #65
hmm strange
Old Dec 3, 2013 | 08:00 PM
  #66
rcarr0327's Avatar
i think someone needs to just do it. from some evidence that has been floating around with part number and stuff i personally think it will work. i know from experience the 2.4 and 2.2 heads are interchangeable
Old Dec 3, 2013 | 08:35 PM
  #67
LE5
Bore - 86MM
Stroke - 98MM
Intake Cam
Duration - 210.3
Lift - .415
Exhaust Cam
Duration - 195.4
Lift - .395
this is incorrect just saying.
Old Dec 9, 2013 | 01:57 PM
  #68
I would try it but im working 10 to 11 hr days then 6 to 8 on Saturday and its my only car. maybe us vvt guys are better off tunning vvt
Old Dec 9, 2013 | 02:01 PM
  #69
LS6Rally's Avatar
Thanks for telling everyone Im wrong, but not helping with the correct info...
Bore is 88 not 86 Stroke is Correct.
Old Dec 9, 2013 | 07:56 PM
  #70
Sorry, i wouldve but i did not know the exact number, just that it is not 86. Thanks for the correction.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
Tupp
Sep 30, 2015 08:18 PM
ThoR294
Sep 28, 2015 05:31 PM
