LSJ Mini Build ;)
Like this? After I installed it, I manage to stick my index finger and touch the notch to see if it was still in position and it was...
I did had piston #4 on tdc but what is the best way to know if it was on compression?
After I re timed the cps, car fire up. I let it run for couple mnts and turn it off.......when I try to fire up again it never did. It only turns but it does not start.........and codes p0365 & p 0366 came bak......and I call it a day
look at this picture.....line the notch on the crank pully up with the mark on the front cover.....that should be tdc cylinder 4 on the compression stroke. see, picture.
then line the notches on the camshaft sensor up and install, see picture.
Im ready to get this thing up and running. So do I need to remove the crank pulley?
And like this....this is the crank pulley notch align with line on valve cover around 11 o clock
I tooj a pic of a mirror....sorry it might look confusing lol
Thats what I did. First I pull #4 plug and inserted a screw driver, once I was at tdc, I checked crank pulley and I was 1/16 off line but the adjusted it a bit. Then I align sensor just like ur diagram above. But now it wont turn on....it only tries and tries vut wont fire up......
