The Motor is IN!!!!!!
Like another member said what exactly are you doing. All i saw was that you apparently swapped the engine or took it out to upgrade internals. Detailed information would be helpful to understand this thread
The entire cooling stystem is in!!!
The oild pan is being run though hot water not to clean it out
Then comes electrical and im done!!!!!
yeppie
and neutral balance shafts i was told you dont need them if you dont rev over 7-7200 rpm when powershifting or what not
Honestly i want this for an autoX car so we shall we but i plan to drag to
yeppie
Originally Posted by Cobalt_Supercharged
Read his sig and imagine him doing all the work for it. Now your up to speed, or atleast he will be.
all the work is done im just playing connect the dots with wires now
ok so after like 21 hours of straight automachanines i am so tired i passed out in my engine bay under the car, in the shower and on the steps headed downstaits
She is not running and for that matter neigher am I.
I just have to connect the oil pump, and put the intake manifold on then attach all the little wires
does any1 happen to know where i can find a wiring diagram at?
DAMN BRO... good luck to you... I myself am going through the same build.. but I bought a spare motor to build up so my wouldn't be down for too long... but it looks like I'll be doing most the work myself and I hope all goes to plan...
bdwarr06, all the wires sort of fall in place believe it or not. Don't forget the cam sensor connector, as that is the one I forgot. Once I plugged it in, we were up and running.
Word of advice, since the engine has been out of the car for a week or so, get electrical connector cleaner from the parts store. Spray both the connector and receptacles on all the parts. This seems dumb, but it solved another issue I was having with one of the sensors not getting the correct readings. Good luck, and get that thing fired up!
I give you major props man. I yanked and fixed an engine on my old car by myself, and I know exactly how much of a pain in the ass it is. Hope the rest is easy on you. Def. agree with 2K5SS/SC? about the connector cleaner. I had 4 plug malfunctions when I finally put mine back together.
Dano
Dano
We're all pulling for him, but I have a feeling someone is taking a well deserved nap and may not have everything together for a few hours...either that or he's plugging away at those connections right now.
lol get a bit of rest man.
make sure your head is clear to do a final checkover so its all smooth sailing.
besides....youll enjoy it far more if your rested when it fires up, so you dont collapse just when its play time!!!
btw.....you better get that first fireup on video!
yea i wont be able to work on it until tonight though work sucks
just have the upper intake manifold and the header to put on parts wise and the drive belt, and one coolant hose 1 tranny mount bolt
and then as assload of electrical connectors
By the way when I finally finished my headgasket job, it was 2:00AM and I definitly drove for like an hour or so because I was so happy despite the fact I had to be up early the next morning in my Full Service Dress to attend a funeral!
