New power goals
its basicaly a plug so you delete the shaft completely the downside is its pretty much permanent. less rotating mass as well, i forgot who sells the delete kit. it might be works
and its cheaper than a nbs.
you better check the post office n see if they have your **** =p
i had mail stuck at the damn apo office for a month just sitting at a
corner.....
corner.....
Level Zero Motorsports these are the bushings required for the delete and you can just cut the stock balance shafts instead of buying the full balance shaft delete kit so you save 70 bucks
will look like this after cutting
Yeah it's getting annoying. I'm waiting currently on my css.net calendar, the tvs with pulleys, and a fatty ass check refunding my stolen household goods which is going to pay for the cams valve springs ported and polished head
and I'll look into that
