New power goals
374whp
I'm sure he made more, and just didn't feel the need to post it.
Last thing on the tracking says Departed USPS in San Diego on DEC 28th
they must have put it on the boat
it sat in san diego for 5 days over the holiday
FOr as much as you paid for shipping i think you got screwed, should have gone to the post office.. Ups store is
and I think i may get the balance shaft delete instead, I think i'll be better off with that.
trying to see what else would fit the budget for the motor.
Definitely gotta' port match the exhaust and intake side to even think about getting to 400..
I wish I had E85.
A little bit of a learning curve, but i have a ton of support from some local guys helping me out, I'm not an idiot at all mechanically, but it's a learning process, as I go.
Will update more as soon as parts start coming in and work gets done.
I wish I had E85.
Last edited by tylerjclance; Jan 12, 2012 at 01:38 PM. Reason: Automerged Doublepost
wife didnt wanna stand in line with the 30lbs tvs >_<
I wish I had E85.
I wish I had E85.
its basicaly a plug so you delete the shaft completely the downside is its pretty much permanent. less rotating mass as well, i forgot who sells the delete kit. it might be works
and its cheaper than a nbs.
you better check the post office n see if they have your **** =p
i had mail stuck at the damn apo office for a month just sitting at a
corner.....
corner.....
google ecotec balance shaft delete kit
I wish I had E85.
I wish I had E85.
Reading this I see you are stationed in Germany? Who will tune your car there, or is that still in the US?
I'm from Holland and going a similar route as you. LSJ + ported head&78lb's + TVS. Still doubting on cams or adding Meth. (E85 is getting a bity cheaper, but still $$ and very rare here) But I mounted all this in the rear of an Opel Speedster, so per kg my performance should be pretty OK.
Do the tuning myself with HPT on the road, as HPT tuners or even SC's are not very common in Europe.
Agreeing with the compression thing; if you running E85 or meth, raising compression should bring you bigger numbers without stressing the SC on high boostpressures.
Ow, and you can easily do a balancer delete yourself for 0$. Simply cut off the stock shafts right after the 1st bearing and knock the rear bearingshells 7.5mm further into the engineblock to block off the rear oil channels. Simple!
No, not yet.
Gotta' get the ZZP site to start working for me so I can start ordering some parts!!!
I'm trying to wait to do the PNP head so i can install these parts while everything is taken apart.
Last edited by tylerjclance; Jan 13, 2012 at 05:43 PM. Reason: Automerged Doublepost
