OFFICIAL Blown 4-banger build updates!
LSX RWD S/C conversion
I am thinking engine size, twin turbo.
I think with some minor timing adjustments on the cams, I can change that....
*rubs hands menacingly*
Not really though, I'm gonna leave them as is. Crane designed that grind specifically for my car, I'll trust them.
Whenever I can get over there LMAO!
Just don't drop the soap!
Last edited by Psykostevo; Aug 22, 2008 at 02:49 PM. Reason: Automerged Doublepost
Used wrinkle finish black paint that I bought as Autozone. Also, its totally untuned hence the stockish idle sound. Trust me though, anyone who was there even with the crazy richness, timing, and high idle speed, could clearly hear some nasty cams sneakin out the exhaust. Just at idle, the exhaust blows your hand away from the exhaust pipe HARD. It definitely did not do that when it was stock. I am super excited to get this thing tuned and ****. I was averaging 14.2 mpg on my first drive
I got up to like 1/3 throttle at 3500 rpm, and it put me in the seat pretty good, this thing will make power through 8000 rpm, so the break in period is going to be torturous! Also the clutch is AMAZING!!! Its got quite a bit less pedal pressure than stock, but you can tell is a crazy clutch because as you let it out, it chatters pretty good. It feels almost like stock (except for the mild chatter), and Will from Centerforce said the clutch could easily handle 800 hp
Awesome clutch!
Also, here is a video from my phone, just a walk around at idle. Real quick.
****'s weak! Here's a real walk around!
i hope the best for ur lsj cam...hopefully urs can break the curse lol....my only concern is that a local guy here did a complete build with a 2.4 block new pistons rods ported polished all that jazz and laid down 29x to the wheels..i'd like to see this after some kind of FI swap. i dont see it being the car it can be with the m62
Last edited by Blown 4-banger; Aug 22, 2008 at 02:59 PM. Reason: Automerged Doublepost
