OFFICIAL Blown 4-banger build updates!
Old Aug 22, 2008 | 07:45 PM
  #1676
Blown 4-banger's Avatar
Yeah, whatever. I don't really care. I don't want to drive it really until I get some of the bugs worked out.
Old Aug 24, 2008 | 05:42 AM
  #1677
Uh... No new updates. New belt will be here on monday. I bled the intercooler system in the mean time. On the first drive, the intercooler had maybe a couple cups of fluid in it. The ambient air temp was like 98 degrees (like 12 in the morning), and my IAT2 was 164-167 degrees. After bleeding the intercooler, ambient air temp was 113 (mid-day), and IAT2 was ~125-130. Huge difference. Still gotta figure out WTF is up with the knock sensor
Old Aug 24, 2008 | 12:25 PM
  #1678
hatrickstu's Avatar
sorry if you already said this, but im not going back through haha. what IC setup you running
Old Aug 24, 2008 | 05:29 PM
  #1679
Josh@ottp's Avatar
what codes do you have?
Old Aug 24, 2008 | 07:35 PM
  #1680
FASTL61's Avatar
both o2's and knock sensor and A/C press. sensor
what else am i missing cam?
Old Aug 24, 2008 | 07:55 PM
  #1681
Josh@ottp's Avatar
code numbers
Old Aug 24, 2008 | 08:05 PM
  #1682
FASTL61's Avatar
i dont remember...killa cam will have to scan them again...there were like seven codes poppin up first one was for the A/C pressure switch was not connected then all the other one when it was running so well have to wait for him to scan them again
Old Aug 24, 2008 | 08:06 PM
  #1683
Ported blower, dual pass intercooler mod, and cobra HE. Intercooler and blower were cyro frozen (33% better heat dissipation).
I'm getting 2 codes for the knock sensor, 2 for the front o2 sensor, and 1 for the ac pressure sensor.
Old Aug 24, 2008 | 08:59 PM
  #1684
WSFrazier's Avatar
Might some dumb, but I am assuming you have the right connection for knock sensor, and also on the right spot on block?
Old Aug 24, 2008 | 11:02 PM
  #1685
Tomtwtwtw's Avatar
Ever find out what those two danglers were at the front of the car?
Old Aug 24, 2008 | 11:16 PM
  #1686
BAPerformance's Avatar
The multiple codes for the same problem are probably a pending code and a set code. They both mean the same thing so disregard the pending code as long as it's identical to the other one.
Old Aug 24, 2008 | 11:17 PM
  #1687
FASTL61's Avatar
no idea....i found a repair manual for the cobalts and looked at the wiring diagram but couldnt find what they were..im at a loss
Old Aug 24, 2008 | 11:47 PM
  #1688
Josh@ottp's Avatar
post pics of the connectors
Old Aug 24, 2008 | 11:51 PM
  #1689
FASTL61's Avatar
im not @ his house...they were both 2 wire connectors up front on the bottom one was on the driver side...the other was on pass. side...if i remember correctly one was light green and red????other white and blue??????i could be wrong but i searched everywhere on the engine and trans for any un connected sensors but i couldnt find anything at all.
Old Aug 25, 2008 | 03:22 AM
  #1690
I'm almost positive we got the knock sensor plugged in. So I hope its not fuct. Also I think we just forgot the plug in the O2 sensor.
Old Aug 26, 2008 | 10:15 AM
  #1691
Herndon_High_SS's Avatar
So how's the car running cam? Did you ever find out what was wrong?
Old Aug 26, 2008 | 11:09 AM
  #1692
OniMirage's Avatar
my buddy with the 98 gsx had the same issue when he got his motor built as well just something small an seemingly easy ends up always being the issue, in his case there were boost leaks and an issue with the throttle body
Old Aug 26, 2008 | 11:17 AM
  #1693
Drove it to the gym last night. I runs and drives, thats all I care about at this point.
Old Aug 26, 2008 | 11:41 AM
  #1694
Asphalt Assault's Avatar
crucial parts plugged in not sure? how can you do that to a new motor?
Old Aug 26, 2008 | 11:53 AM
  #1695
Tomtwtwtw's Avatar
Eh, you don't need an o2 sensor...when you get high just standing behind the car, you know it's running rich enough.
Old Aug 26, 2008 | 11:57 AM
  #1696
Actually, its learning pretty good. It now idles around 13.8-14.2 arf, much better than 12.3-12.6! I might need a new O2 sensor though.
Old Aug 26, 2008 | 12:33 PM
  #1697
Can you post the actual description of the codes here? I'm just curious what it says...
Old Aug 26, 2008 | 12:37 PM
  #1698
FASTL61's Avatar
code P0WTF?
ECM not recognizing such high performance....TUNE ME!!!!!
Old Aug 26, 2008 | 12:52 PM
  #1699
Psykostevo's Avatar
Since when did you start working out? You realize you have to hit puberty before it really pays off, otherwise you don't have the testosterone levels to build real bulk.
Old Aug 26, 2008 | 12:53 PM
  #1700
06blackg85ss's Avatar
hahahahahahaha!!!!!
