Ported head
Old Jun 26, 2008 | 01:07 PM
EXsoccer1921's Avatar
Ported head
Will the cnc ported head from CED work on the LSJ?
http://www.crateenginedepot.com/stor...-P333C129.aspx
Also, i'm looking in to getting performance cams, intake and exhaust valves, and higher rpm springs and retainers. anyone have any good links? can't find any on the vendors' sites.
nvm, scratch that on the cams, found them on CED, but i still need valves, springs, and retainers.
Last edited by EXsoccer1921; Jun 26, 2008 at 01:07 PM. Reason: Automerged Doublepost
Old Jun 26, 2008 | 01:08 PM
lsjwannabe's Avatar
no that is for the 2.2l. They do make a lsj head for 1200 though. I would honestly buy a spare and get it ported. The cams will not work because they dont have a hex for the cam sensor.
Old Jun 26, 2008 | 01:12 PM
okay, gotchya. where can i find the LSJ head since it's not on their site? along with some good cams?
Old Jun 26, 2008 | 01:17 PM
ls1fbody's Avatar
Haz l33t wheelz.
ill be watching this thread
Old Jun 26, 2008 | 01:18 PM
Jackalope's Avatar
The gain you'll see from cams VS. the cost to run them IMO is NOT worth it AT ALL! Do all the bolt on you can and if you want a port job I'd recomend gasket matching the intake and exhaust posts as that makes for the largest gains while not going totaly crazy! Don't forget the law of diminshing returns, basicly you can only spend so much on mods that you reach a point where its just not worth the cost anymore.
Raven SS's Avatar
u can either buy one from jbp or buy a spare head from ebay and send it to a local shop to get ported..and cams is all on u..the only real cams for our car is the jbp cams but people have got hks 272 regrinds on blanks or stock cams and ran those...i dont recommend it
Old Jun 26, 2008 | 01:31 PM
well i looked on the JBP website and you have to have a dealer code or something to buy them, maybe i'll give them a call
Old Jun 26, 2008 | 01:37 PM
Area47's Avatar
Rent me! per hour
so. some people think cams are fail in these cars?
newp!
once the lash adjusters quiet down, the low end comes back, sort of. there is a tradeoff with everything you do. remember that. my car has retarded top end pull now above 5k. everytime i drive a stock cammed lsj i find myself waiting for the power. well it's not there. even on a couple cars with my kill tunes in them. i slam into the rev limiter. the 272's flatten the torque curve out, and carries the peak hp over a broader range.
Old Jun 26, 2008 | 02:01 PM
so you're suggesting hks 272 regrinds??
Old Jun 26, 2008 | 03:16 PM
Blown 4-banger's Avatar
newp!
After seeing flow numbers on the stock ports, I honestly think you would gain more power with a decent port job with the stock cams. Seriously man, the EGT has to unbelievable on your car!
Old Jun 26, 2008 | 03:23 PM
Deathscythe's Avatar
area, what's the idling like? is it bearable for normal driving?
Old Jun 26, 2008 | 03:34 PM
well i'm lookin for about 450whp so i'm pretty sure i'm gonna need some cams AND a machined head with ported intake and exhaust valve spots
Old Jun 26, 2008 | 03:36 PM
Josh@ottp's Avatar
We offer a stage 1 and a stage 2. the only difference being the valvetrain on the stage 2. For more info pm me.
Old Jun 26, 2008 | 05:57 PM
Area47's Avatar
Rent me! per hour
i daily drive my car. it drives no different that a stock car does. i have hidden a lot of the cam noise at idle. keeps people away from me.
cam. amazing things happen when valve lift is over .400. my egt's are fine.
Old Jun 26, 2008 | 06:47 PM
The difference between .300" lift and .400" lift on the exhaust side, is literally 1 cfm more flow. .300" lift = 158 cfm, .400" lift = 159 cfm.
Old Jun 26, 2008 | 06:49 PM
Raven SS's Avatar
numbers dont lie
Old Jun 29, 2008 | 09:27 AM
Jackalope's Avatar
And for that 1 CFM how much did it cost you? Thats why I said not worth it IMO. The amount of cash your gonna plop down to pick up a couple horses just is not worth it, unless your going for that last 2 extra HP that will net you that last .02 in a 1/4 mile.
Old Jun 29, 2008 | 01:45 PM
Area47's Avatar
Rent me! per hour
there is more to it than flow numbers.
Jan 12, 2016 12:01 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
