SCcobaltSS's Engine Build
Old Apr 28, 2010 | 11:28 PM
  #126
SCcobaltSS's Avatar
I tested the incoming signal to the sensor and it is 2.5 volts from both wires. Is that correct?
Old Apr 28, 2010 | 11:31 PM
  #127
UgliestTurtle's Avatar
Where is it located??? (I could find if i wanted to but I am tired) Ill see if I can find the voltage on my SS.
Old Apr 28, 2010 | 11:50 PM
  #128
SCcobaltSS's Avatar
Its located under the IM on the right side. Just above the starter.
Connector looks like this
Its kinda hard to get to.
The supply voltage to the sensor was 2.5 volts on both purple and yellow wire. I have not tested the actual sensor output when it was cranking its difficult. But the supply harness was still reading 2.5 volts while cranking.
Last edited by SCcobaltSS; Apr 28, 2010 at 11:54 PM. Reason: Automerged Doublepost
Old Apr 29, 2010 | 11:22 AM
  #129
SCcobaltSS's Avatar
Old Apr 29, 2010 | 03:11 PM
  #130
Have some one crank it while you test that sensor...
Ill do the same and see what I can get
Old Apr 29, 2010 | 03:15 PM
  #131
SCcobaltSS's Avatar
I am not too much worried about the sensor. It is brand new. I was just needing the supply voltage of the purple wire (pin diagram shows yellow is the signal wire going to the PCM) when the car is in the "on" position.
Old Apr 29, 2010 | 03:43 PM
  #132
importkiller's Avatar
Epic build with epic failure...good luck man, I wish I had any ideas but I do not.
Old Apr 29, 2010 | 03:44 PM
  #133
BlackBaltSw's Avatar
Good luck bro, I had some insane electrical difficulties when i did my clutch. Something happened. It friend the actual Fuse Block. Check that maybe u have the same problem. Most electrical **** worked, car just wouldnt crank.
Old Apr 29, 2010 | 03:47 PM
  #134
SCcobaltSS's Avatar
It has been full of its ups and downs. Epic fail... not quite. Now if I could never get it started. Maybe.
Thanks,
Block seems fine. Car cranks and I have power to everything. Even power where I dont need it
Old Apr 29, 2010 | 03:48 PM
  #135
Thanks,
That sucks man, wish i could help ya but ur far.
Old Apr 29, 2010 | 03:50 PM
  #136
SCcobaltSS's Avatar
No worries. I am in the home stretch I think. Gotta follow the loom of wires and find the pinched/torn wire. Ill get it. I wont quit and send it to the shop..... yet.
Old Apr 29, 2010 | 04:16 PM
  #137
OH ****! one more thing i just remembered, THis gonna sound bad BTW. Randomly when my car used to hit a heavy enough bump my car would stumble and bog. Eventually it would hut any bump and Die for s split second and fire back up. The harness you have a picture of, above^^^ is where i had a wire that was so worn it split itself apart. All in all i cut the harness out and hardwired it together. Never had a problem since. lol.
Old Apr 29, 2010 | 04:29 PM
  #138
SCcobaltSS's Avatar
Oh ok. Yah I think that it is just pinched or shorting out on another.. I will do what I have to I guess. haha
Old Apr 29, 2010 | 04:41 PM
  #139
AnthonyCM's Avatar
wow just read all 8 pages....that sucks man i'm sorry to hear your having these issues
Old Apr 29, 2010 | 04:46 PM
  #140
SCcobaltSS's Avatar
Yah it blows, but I think I am close to a solution. Which is good.
Once it starts I am going to make a new build thread and have a sound clip and probably rename this one to. "IF YOUR CAR DOES NOT START AFTER BUILD AND YOU HAVE CHECKED EVERYTHING, READ THIS."
Last edited by SCcobaltSS; Apr 29, 2010 at 04:46 PM. Reason: Automerged Doublepost
Old Apr 29, 2010 | 05:11 PM
  #141
HAHA Diagonsing sucks until you find it and you feel proud...
and Also clarify where you are at right now.. What you have and dont have..
Could make us think of something bc were not there to get hands on.
Old Apr 29, 2010 | 05:25 PM
  #142
SCcobaltSS's Avatar
I dont have spark and fuel. Everything else "seems" to work except the CKP sensor.
I have tested the supply harness to the CKP sensor and both wires on the harness show 2.5V. (That test was done with the harness unhooked from the pigtail of the CKP sensor)
I assume this is an issue and that is why I am saying I think I am close to a solution.
Old Apr 29, 2010 | 05:28 PM
  #143
And you said that you got a new CKP sensor?
Old Apr 29, 2010 | 05:34 PM
  #144
SCcobaltSS's Avatar
Yes the sensor is brand new. Dont take that by me saying it doesnt work that it actually does not work. That is just the problem area that we think is not allow my car to see RPM.
I will test that when I get home.
Old Apr 29, 2010 | 06:53 PM
  #145
Well just because its new does not mean it works... Ive had plenty of brand new parts not work... just saying...
Old Apr 29, 2010 | 10:26 PM
  #146
SCcobaltSS's Avatar
Yah I know. Me too. Well I messed with the sensor and with the wires. unplugged the comp. Now I get fuel but I have a crank position performance code. So I just changed the sensor back. I am going to check for spark now. Just to make sure.
When I tried to start it, it sounded like it wanted to go over it just didnt. Fingers crossed.
Old Apr 29, 2010 | 11:16 PM
  #147
Sounds like ur making small progress. Good luck bro
Old Apr 29, 2010 | 11:51 PM
  #148
SCcobaltSS's Avatar
Guess what! It started for 5 seconds after I fucked with it. Then tightened everything down and it started and idled! Will post sound clip later tonight or tomorrow. **** YES!
Old Apr 30, 2010 | 12:34 AM
  #149
Congratz
Old Apr 30, 2010 | 12:51 AM
  #150
ItalianJoe1's Avatar
******* nice bro.
Damn crank sensors
