Spike's build thread
Old Jan 11, 2009 | 05:23 PM
  #126
mike25's Avatar
Originally Posted by Armyguy151
i found some sleeves on all ecotech.com that i'm buying...i'm the the process of fully building a 06 turbo pistons rods cams forced perofrmance 3065r turbo vulcan exhaust manifold hanhs port fuler intake manifold....i'm tryin to find something about the crank anyone know where i can get a stronger one i'm going to iraq within 30 days i'm at ft dix nj right now mobing so if anyone knows let me know thanks...oh also i'm puting new pistons in and staying with the normal bore i also thought about going .10 ovr but that means tryin to find more **** ya know
also where did you get those rods i'm looking for rods....sorry i haven't been able to read the thread i'm on a limit time here thanks and good luck with your build
pauter
what did the shop charge you to build the motor(take it apart put it back together etc.)?
Old Jan 11, 2009 | 05:49 PM
  #127
ColeJJones's Avatar
Bannned
just read this thread... i said wtf! outloud when i seen the .20 over with the turbo kit... lol, cracked sleeve ftl
Old Jan 11, 2009 | 05:56 PM
  #128
mike25's Avatar
? whats the stock number for what your talking about? ive never seen anyone change sleeves in the 2.4 for a built turbo before..but then again this is a 2.2
Old Jan 11, 2009 | 06:18 PM
  #129
ColeJJones's Avatar
Bannned
i didnt understand a word you were saying??? the OP bored out his sleeves .02 over along with bigger piston obviously... what are you talking about?
Old Jan 11, 2009 | 09:27 PM
  #130
mike25's Avatar
lol sorry dont unerstand the boring out part...all i caught was something about the sleeves being to thin(.020?) and i was wondering if that was just because he bored them out(i normally dont see other built motors replacing sleeves)
Old Jan 11, 2009 | 09:43 PM
  #131
ColeJJones's Avatar
Bannned
yea its cause he bored them out. i will def be replacing my sleeves and i still wont overbore with aftermarkets
Old Jan 12, 2009 | 12:24 AM
  #132
spike's Avatar
darton states that you can go up to 87mm safely(600-800hp)....with a .02 over bore it will only be at 86.5mm.....should be fine......but on stock sleeves FAIL!!!! this is why my motor is getting sleeved
Old Jan 12, 2009 | 12:17 PM
  #133
06blackg85ss's Avatar
The other darton kit (500-100) can actually be overbored to 90mm. ( same kit I'm getting) but I'm staying with the stock bore and compression on my motor.
Old Jan 12, 2009 | 10:35 PM
  #134
spike's Avatar
90mm bore would be crazy...... it would make the car around a 2.19L with the stock stroke.....lol
Old Jan 15, 2009 | 06:08 PM
  #135
spike's Avatar
my block is going at the end of Feb.-ish 2 be sleeved. The head is also getting the exhaust ports gasket matched then as well...thats all for now
Old Jan 21, 2009 | 12:47 PM
  #136
spike's Avatar
no updates on the motor yet.....but i am getting my redline wheels back this weekend
Old Feb 3, 2009 | 09:46 PM
  #137
spike's Avatar
Im selling my 57trim turbo..... looking 4 a new turbo but im sorta lost on wat i need 2 best meet my goals on 20-22psi-ish..... any ideas (Paul or 06black)
Old Feb 3, 2009 | 09:49 PM
  #138
StevesBlack06's Avatar
talk to george at atp man
Old Feb 4, 2009 | 12:47 PM
  #139
06black's Avatar
atp's good peoples, so is FP.
from myself and Paul tho, i think you'll get the same answer.
60-1.
an amazing sub 600hp turbo.
Old Feb 4, 2009 | 04:53 PM
  #140
SloBaLt RiDeR's Avatar
im a fan of the 3071r
Old Feb 4, 2009 | 05:07 PM
  #141
spike's Avatar
60-1.
yeh thats where i got the 57 at..... thanks for teh input.... i was sorta in between the 60-1 and gt35r..... but the more i look i think the 60-1 is the best bang for the buck
Old Feb 4, 2009 | 05:22 PM
  #142
bykryder83's Avatar
gt 3076 with a .82ar thats the one i just ordered the .63 should do you just fine man
Old Feb 4, 2009 | 06:16 PM
  #143
60-1 is the **** lol. Can't wait to see how it is with the built motor (build will be done very very soon) heads out, blocks going out in a week, everything else is at my job ready to go.
Old Feb 4, 2009 | 07:07 PM
  #144
Maxim_X's Avatar
It will be nice to see what that turbo does when it's actually in its efficiency range.
Old Feb 4, 2009 | 07:29 PM
  #145
yeah I know. Thing is barely working in my car
Old Feb 5, 2009 | 09:50 PM
  #146
spike's Avatar
yeh i need moneys...... trying 2 get stuff sold 2 get more parts
Old Feb 5, 2009 | 10:23 PM
  #147
LLAMA's Avatar
hey 06blackg85ss, i was looking at your pics and can't seem to figure out where your hot side charge pipe is going. It disapears under the intake somewhere. I have a manifold hat and i still got the stock intercooling system. I'm wanting to buy the vulcan intake manifold and use a front mount, but i can't find the room for the hot side pipe to go. do you have any detailed pics on the routing of that pipe? This is my daily driver and i can't afford it to be down for extended periods of time while i'm fabbing pipes. any help would be much app.
Old Feb 6, 2009 | 04:47 AM
  #148
Maxim_X's Avatar
I think his hot side goes under his motor but I'm not certain. I'll show some pics soon of a simple way to intercool without a lot of charge piping.
Old Feb 6, 2009 | 06:18 AM
  #149
goes up over the valve cover towards the pass side, and through where the windshield washer resevior used to be.
Old Feb 6, 2009 | 09:21 AM
  #150
LLAMA's Avatar
so did you relocate the bottle or get rid of it completely? My washer bottle for is tapped for my meth injection, so i kinda need it.
