SS twincharged
Old Aug 29, 2008 | 01:06 PM
  #51
bolus's Avatar
Originally Posted by csementuh
For people looking for that Oil Cap Breather... I think I found it...
http://www.pfyc.com/pc/GN3020/GNUNDE...er+Filter.html
I remember hearing from someone that the Cobalt SS oil cap was the same as the LS1 which means this should work.
Now people said that the PCV system doesn't work well with high boost applications... How high? I run a 2.7" pulley and get like 17ish PSI. Would I benefit from a breather cap?
When using the breather cap do you keep the stock systems in place? What about the stock line on the back of the valve cover that some people put a catch can in. What is the consensus of what t run? Breather and/or catch can?
thanks, my front engine vent where the PCV normally goes it covered up by the early version of the Hahn intake manifold. So I was having problems at 15 PSI.
Old Aug 29, 2008 | 01:08 PM
  #52
06blackg85ss's Avatar
same issue I was having
Old Aug 29, 2008 | 02:16 PM
  #53
csementuh's Avatar
Originally Posted by WickedSS2005
I have the breather inplace of my oil cap and a catch can. Quadracer and I have nearly identical cars with the exception of intake, header, and his 75mm pulley
Soo to clarify, you are using a breather similar to the one I posted (LS1 style) AND a catch can? What type of catch can setup are you using plumbed to where?
Also would it be worth it to do this to my M62 SC'd car?
Old Aug 29, 2008 | 04:06 PM
  #54
Kennyspec's Avatar
Hey 06blackg85ss, did you trunk mount your stock windsheild washer bottle? I was thinking of running my charge pipes this way for my air-air setup and was wondering what to do with the windshield washer bottle......
Old Aug 30, 2008 | 07:02 AM
  #55
WickedSS2005's Avatar
Also would it be worth it to do this to my M63 SC'd car?
That is the exact breather I use. I did the DIY catchcan and it runs off the back of the valve cover. Plumbed to another tiny breather
Old Aug 30, 2008 | 09:34 AM
  #56
Bill@usd's Avatar
I tune the SS myself, this is not my first, I work for a performance shop at Montreal
The car was my daily drive, The laptop is conected all the time in the car for record information, but for now,
I want a stock pulley, mine's was lost or wathever lol
if you have, let me know
video's soon
Old Aug 30, 2008 | 09:59 AM
  #57
I have 3 stock pullies laying around. PM sent
Old Aug 30, 2008 | 11:08 AM
  #58
csementuh's Avatar
Wicked, would the breather mod be beneficial to a car still on the M62 running a 2.7"? Or is it really only worth it when going TVS or Turbo?
Old Aug 30, 2008 | 03:18 PM
  #59
It's worth it
Old Aug 30, 2008 | 04:44 PM
  #60
MidnightNB's Avatar
So you made this twincharge yourself? I'm guessing so beacuse you said the turbo and s/c are running both at the same time, zzp's kit opens the blower bypass once the turbo spools. This would be sick to see in person, do you ever go to the meets in Ottawa/Gatineau? I've never gone but I'll be there for sure if your going to one, lol. I live in Petawawa, about 1.5hrs from Ottawa. When my car is paid off I'd love to go this route with it and I wouldnt mind seeing it in action... How much did you spend on parts to put this together?
Old Aug 31, 2008 | 05:41 PM
  #61
Bill@usd's Avatar
yes I made it myself, I run the same setup that zzp run, the bypass open when the turbo spoolthe problem is that my setup run a big trim, a t4 with A/R 0.86
normally this turbo spool only at 5000 rpm on a 2.0l engine and push a lot of cfm, but with the supercharger, it spool instantly and the bypass is not enough for flow all this cfm...
I'm guessing about, where the turbo guy's put their MAF, after or before the turbo, where is the best?
Old Aug 31, 2008 | 05:59 PM
  #62
BlackSS/SC's Avatar
maf goes between the turbo and throttle body on my car, blow thru
Old Aug 31, 2008 | 08:23 PM
  #63
Bill@usd's Avatar
Thanks, this is what I made
Old Aug 31, 2008 | 08:52 PM
  #64
bolus's Avatar
My maf didn't like blow through before the intercooler at all (I dont have room after) so I moved it to the cold air intake. It is working great here
Old Aug 31, 2008 | 09:14 PM
  #65
cobaltR's Avatar
subscribed for later viewing when I need it.
Old Aug 31, 2008 | 11:05 PM
  #66
MidnightNB's Avatar
I thought you were saying your running both at the same time though? since you said earlyer in the through that you hit 24psi at 2500rpm, even through the turbo has a wastegate spring for 14.5psi, and the blower is making 18psi? Its just my understanding was that the zzp only used the s/c till the turbo spooled then was only using the turbo to produce boost and by the sounds of it your using both? Either your setup kicks ass, congrats on that.
Old Sep 1, 2008 | 10:01 AM
  #67
really? I run mine btwn the ic and the TB on my car and it works perfectly.
Old Sep 1, 2008 | 09:10 PM
  #68
bolus's Avatar
It was on the hot side before the intercooler since there is no room on the cold side on my setup. 270F and boost was causing all sorts of problems. Now it is right after the filter and behaving well, it does not even mind the BOV to atmosphere. We had it pretty much tuned from scratch within 5 dyno runs
Old Sep 2, 2008 | 07:23 AM
  #69
Not bad man, I had some issues with the atmospheric venting when I tried running it draw through, it woukld just dump fuel on shifts.
Old Sep 2, 2008 | 08:22 AM
  #70
FLEX SS's Avatar
Sweet
Old Sep 2, 2008 | 10:09 AM
  #71
sleeperbalt's Avatar
Where do you put the boost controllers on the twincharger?
Old Sep 28, 2008 | 09:51 PM
  #72
Bill@usd's Avatar
My Fuc$#? stock clutch start to slip in third gear yesterday....a litlle race....I beat a black mustang Svt cobra
need to change this **** lol
I put a video anyway soon, finally tune the car, get 23 psi of boost at 3k rpm and tune the Afr to 10.5......
...poor stock engine
dont have boost controller for the supercharger
Old Sep 28, 2008 | 10:06 PM
  #73
SSdan's Avatar
I'm actually surprised it didn't go boom yet.
Old Oct 16, 2008 | 03:25 PM
  #74
cobaltssredtint's Avatar
interesting....i was thinking about going twincharged and im glad some people are taking the initiative to make twincharge another option for our cars......def unique
Old Oct 16, 2008 | 03:32 PM
  #75
recklessactn's Avatar
THIS IS ON STOCK INTERNALS! youre crazy
