Turbo progress is finally underway. Gutted engine bay pics inside!
Old Sep 17, 2008 | 04:14 PM
  #101
StreetDreamz's Avatar
Originally Posted by Pully Police
Grow up. You may have had an ecotec over 500hp. Have you torture tested it? How much does it see full load? If *I* were to jump in it, would you have full confidence that it would be reliable and stand up to repeated WOT runs? (basically, my goal would be to have it **** out a sleeve).
If you have a daily driver that only sees full load about 5% of the time, you may only brush the limits of the stock sleeves briefly....again, this is simply gambling and one day you will roll on the throttle and pop an engine. YOu put any track time on that car and actually run the car, you will quickly see where the flaws are. You build it right and it will just ask for more.
A 100% stock motor with repeated highway runs with a 150 shot and C16 on top of about 17psi of boost, with timing advanced to well above 20 degrees sounds like a pretty good way to torture test a motor to me. Did it every weekend pretty much since June until about mid August when I started the tear down for the turbo build. This is not a DD either. It's just a WOT car.
By the way, compression is still within stock spec, not close to the lower end of it either ;-)
GM did good on this motor. I can't wait to find the limits of the LNF either, although to be honest I never found the limits of the LSJ.
You sound like one of those guys who gets pissy about an EVO9 on a stock turbo running 500awhp and 127mph trap speeds without nitrous. Just because you can't do it, doesn't mean someone else doesn't know how.
The LSJ will rip uncoiled 7/16" ARP studs out of the block before the iron sleeves go.
Old Sep 17, 2008 | 04:57 PM
  #102
Pully Police's Avatar
I'm not pissy at all. Who says I can't do it? Who says I even want to?
280-300whp from the LSJ is all I want. Cant do much with 500 HP through a glass tranny anyways. I am not going to argue with you and reference published facts and advice from GM racing any more. Have fun re-inventing the wheel.
Old Sep 17, 2008 | 06:14 PM
  #103
1bdstlLSJ's Avatar
Nice turbo there, i just got a GT3071R .82 A/R, hehehe boost lagggggggggggggggggggg FTW!! Im starting my project in December! Good luck with the car running/driving good when all is said and done!
Old Sep 17, 2008 | 06:21 PM
  #104
06blackg85ss's Avatar
eh as much as I hate this. These motors do hold up well when properly tuned actually, key is richen it up, up top. to like 10.8 above 6200 rpm to keep it cooled down (cylinder temp wise) I dunno I beat the ever living **** out of my car every time I get in it (everyone that knows me can attest to that) and I've been pushing over 350 and over 400whp for almost 15k miles without really a hickup. Still on the high side of compression tests too (somehow)
Old Sep 17, 2008 | 07:48 PM
  #105
1bdstlLSJ's Avatar
What turbo are you running? Thats awesome you have been going for almost 15k with little to no problems and still have good compression!
Old Sep 17, 2008 | 08:00 PM
  #106
To boot I have never blown up a tranny either. Just clutches.
Old Sep 17, 2008 | 08:06 PM
  #107
turbonetics HiFi 60-1 T3/T4 ball bearing.... **** is uber
same here, but only killed the stock clutch at 37000 miles
Last edited by 06blackg85ss; Sep 17, 2008 at 08:06 PM. Reason: Automerged Doublepost
Old Sep 30, 2008 | 11:28 AM
  #108
Ferretts's Avatar
Check the Pro Ecotec Race Engine Handbook - Page 29 and 30.
Best qoute ever haha
Turbo Johnny
Feb 21, 2019 09:41 AM
bigdogstokes16
Oct 8, 2015 10:28 PM
Cptnslo
Sep 24, 2015 09:32 AM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
09BlkCrusader
Sep 9, 2015 04:47 PM
