Questions About Water Methanol Alcohol Injection - Post Them Here
#251
to AIS:
lsj full supporting mods(full exhaust, raw cai with ls4 throttle body) 2.6 pulley with 60 lbs injectors, dual pass h/e, ais stage 1 meth injection kit.
my question is: what meth to water mixture should i have to get maximum power output from my street tune?
#252
http://www.alcoholinjectionsystems.c...duct_info.html
^^^ thats the full kit i need to install this right? comes with everything just making sure i read it right going to nget this just for insurance on my 2.2sc
#253
50/50 meth/water should do the trick just fine. If you're looking more for octane boost, try 60/40, but make sure you tune for it. I'm not a whiz at this stuff, but I would assume you need to retard timing a little for that mixture. Anyone else got feedback here?
#254
Ok. I have a stage 2 trunk mount kit. I just bought the stainless lines and the dual connection that I want for my ss/sc. I want the mix to atomize better so what size nozzles do I need for it to be effective?
#255
the ones they give you in the kit should be fine, unless you're running two nozzles, in which case i wouldn't know. I'm assuming you are, so I would thing you would need one nozzle larger than the one they give you.
#257
hey i have a front mount kit right now...but where do you guys have it mounted in the engine bay???it needs to be below my windsheild wiper tank and i have no idea where to go with besides the bumper beam in back or the fans. any sugg.???
#258
Why does it need to be below the washer tank? Its a pump, it will suck it vertically. Or am I missing something? Do they have a gravity fed pump or something?
I have a Devils own kit and I mounted mine on the fender, where the option B tank would go, basically.
I would worry about water damage if the pump is that low, unless they are completely sealed.
#260
question for you water/meth gurus, i put some parade windshield washer fluid in which im going to assume is ~40% meth/60% water, i could and probably am wrong, and i also added a bottle of heet, im curious as to what you would estimate my ratio to be? would it be closer to 50/50 or would it be higher?
tnx
#261
you can advance your timing more with water meth..
tnx
tnx
https://www.cobaltss.net/forums/south-central-60/meth-fluid-help-155857/
hope that helps.
#263
I think my meth pump just went out, it has a proper ground/power supply, fuse is fine. It just won't spray, plugged the power line directly up to the always on metal piece and it didn't spray. What should I do about this? Would AIS send me a new one? It's the trunk mount stage 1 kit.
#265
As much as i should read through the last 15 pages, im kinda lazy so here goes. For your stage 2 kit, it states it can be ran as a 2 dimensional system using 0-5V, MAP, MAF, etc. Also it states free windows based software AVAILABLE. I'm trying to put 2 and 2 together here. Is the water meth system tuned by the included software? and if so, what would someone need to change? Do you guys offer advice and tuning help for the engine, as in if i hook up the system get it going and than scan with my HP Tuners, can i send the data log for you guys to review and adjust my timing, boost, etc?
#266
Non Authorized / Non-Supporting
All New AIS Competition Rear Trunk Mount Water Methanol Injection Systems
Were proud to announce the release of our all new "Competition Series" trunk mount water methanol injection systems. We designed this specifically for our racers in mind. While the tank sports a simple, clean fuel cell look from above. Its package with a lot of new features as listed below making it very functional as well.
If anyone has any questions or would like to get in in the special were running contact us at 801.447.2559.
All pre-orders will be the following prices until tanks are avoidable to ship late next week.
AIS Stage 1 Competition Trunk Mount $349.99
AIS Stage 2 Competition Trunk Mount $479.99
Once the tanks arrive and systems are available to ship the new retail prices below will apply.
AIS Stage 1 Competition Trunk Mount $419.99
AIS Stage 2 Competition Trunk Mount $549.99
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed also to also break up the floor of the tank to help control fluid slosh
*3 gallon capacity
#268
There's a lot of factors to consider. Such as the type of fluid your spraying, how much boost, how much horsepower, type intercooler or if its non-intercooled, etc. It varies with every application. We do pre-compressor injection on a lot of dual turbo 1200+ horsepower setups which require a lot more then a 400 horsepower engine. Just varies.
Rodney
Rodney
#269
#271
On a set up like yours I would use a number 2-3 GPH nozzle pre-turbo when using a 50/50 mix or washer fluid. If using pure methanol run a number 5 GPH nozzle. Let me know if you have any other questions or how I can help.
Rodney
Rodney
#273
hello AIS Ive been reading the prior posts and was curious if you could explain to me if metanol would be useful on a fully bolted NA L61, i know its effects are really worth while for FI applications but I was playing with the idea, I would need tuning correct?
