Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
Questions About Water Methanol Alcohol Injection - Post Them Here
Old Apr 7, 2009 | 05:37 AM
  #251
ajjaro's Avatar
to AIS:
lsj full supporting mods(full exhaust, raw cai with ls4 throttle body) 2.6 pulley with 60 lbs injectors, dual pass h/e, ais stage 1 meth injection kit.
my question is: what meth to water mixture should i have to get maximum power output from my street tune?
Old Apr 9, 2009 | 09:29 PM
  #252
Jn2's Avatar
Jn2
http://www.alcoholinjectionsystems.c...duct_info.html
^^^ thats the full kit i need to install this right? comes with everything just making sure i read it right going to nget this just for insurance on my 2.2sc
Old Apr 9, 2009 | 09:40 PM
  #253
mexi_loco's Avatar
Originally Posted by ajjaro
to AIS:
50/50 meth/water should do the trick just fine. If you're looking more for octane boost, try 60/40, but make sure you tune for it. I'm not a whiz at this stuff, but I would assume you need to retard timing a little for that mixture. Anyone else got feedback here?
Old Apr 10, 2009 | 07:40 PM
  #254
Deathscythe's Avatar
Ok. I have a stage 2 trunk mount kit. I just bought the stainless lines and the dual connection that I want for my ss/sc. I want the mix to atomize better so what size nozzles do I need for it to be effective?
Old Apr 10, 2009 | 10:29 PM
  #255
mexi_loco's Avatar
the ones they give you in the kit should be fine, unless you're running two nozzles, in which case i wouldn't know. I'm assuming you are, so I would thing you would need one nozzle larger than the one they give you.
Old Apr 12, 2009 | 09:16 PM
  #256
startingline05's Avatar
anyone ever try the direct port for the water/meth kits?????
Old Apr 13, 2009 | 09:29 AM
  #257
brett5's Avatar
hey i have a front mount kit right now...but where do you guys have it mounted in the engine bay???it needs to be below my windsheild wiper tank and i have no idea where to go with besides the bumper beam in back or the fans. any sugg.???
Old Apr 14, 2009 | 10:32 AM
  #258
SCcobaltSS's Avatar
What kit do you have? nvm I see it in your sig.
Why does it need to be below the washer tank? Its a pump, it will suck it vertically. Or am I missing something? Do they have a gravity fed pump or something?
I have a Devils own kit and I mounted mine on the fender, where the option B tank would go, basically.
I would worry about water damage if the pump is that low, unless they are completely sealed.
Old Apr 20, 2009 | 09:44 PM
  #259
bolus's Avatar
AIS, does Holy water work better than distilled? I'm thinking about getting my tank blessed
Old Apr 21, 2009 | 02:12 AM
  #260
evilmonkitar's Avatar
you can advance your timing more with water meth..
question for you water/meth gurus, i put some parade windshield washer fluid in which im going to assume is ~40% meth/60% water, i could and probably am wrong, and i also added a bottle of heet, im curious as to what you would estimate my ratio to be? would it be closer to 50/50 or would it be higher?
tnx
Old Apr 21, 2009 | 09:18 AM
  #261
mexi_loco's Avatar
tnx
thanks for the correction. and for your help, i give you this thread:
https://www.cobaltss.net/forums/south-central-60/meth-fluid-help-155857/
hope that helps.
Old Apr 21, 2009 | 02:16 PM
  #262
ahh cool thanks
Old Jun 5, 2009 | 06:58 PM
  #263
Hockeyman's Avatar
I think my meth pump just went out, it has a proper ground/power supply, fuse is fine. It just won't spray, plugged the power line directly up to the always on metal piece and it didn't spray. What should I do about this? Would AIS send me a new one? It's the trunk mount stage 1 kit.
Old Jun 5, 2009 | 08:45 PM
  #264
Maxim_X's Avatar
What is the max amount of water meth that should be allowed to be sprayed pre turbo?
Old Jun 15, 2009 | 07:43 PM
  #265
hiltu's Avatar
As much as i should read through the last 15 pages, im kinda lazy so here goes. For your stage 2 kit, it states it can be ran as a 2 dimensional system using 0-5V, MAP, MAF, etc. Also it states free windows based software AVAILABLE. I'm trying to put 2 and 2 together here. Is the water meth system tuned by the included software? and if so, what would someone need to change? Do you guys offer advice and tuning help for the engine, as in if i hook up the system get it going and than scan with my HP Tuners, can i send the data log for you guys to review and adjust my timing, boost, etc?
Old Jan 14, 2010 | 02:05 PM
  #266
AIS's Avatar
AIS
Non Authorized / Non-Supporting
All New AIS Competition Rear Trunk Mount Water Methanol Injection Systems
Were proud to announce the release of our all new "Competition Series" trunk mount water methanol injection systems. We designed this specifically for our racers in mind. While the tank sports a simple, clean fuel cell look from above. Its package with a lot of new features as listed below making it very functional as well.
If anyone has any questions or would like to get in in the special were running contact us at 801.447.2559.
All pre-orders will be the following prices until tanks are avoidable to ship late next week.
AIS Stage 1 Competition Trunk Mount $349.99
AIS Stage 2 Competition Trunk Mount $479.99
Once the tanks arrive and systems are available to ship the new retail prices below will apply.
AIS Stage 1 Competition Trunk Mount $419.99
AIS Stage 2 Competition Trunk Mount $549.99
Features Include The Following:
*3 gallon capacity
*Dimensions are 14" long (not including the 1.25" rear sump) by 10.5" wide by 7.5" tall
*Aircraft style locking cap with built in flapper vent.
*Large cap allows you to access the inside for those who want to stuff the tank with safety foam
*Built in virtual sump with dual 3/8 npt rear pick up's
*Dual pick ups allows the use of a second pump for our high horsepower guys who max out one pump - sounds crazy but it happens!
*Pump is reversed under the tank for a clean over head appearance
*Reversing the pump under the tank allowed also to also break up the floor of the tank to help control fluid slosh
Old Jan 14, 2010 | 02:13 PM
  #267
rico's Avatar
x2 on this question
Old Jan 14, 2010 | 04:34 PM
  #268
AIS's Avatar
AIS
Originally Posted by rico
x2 on this question
There's a lot of factors to consider. Such as the type of fluid your spraying, how much boost, how much horsepower, type intercooler or if its non-intercooled, etc. It varies with every application. We do pre-compressor injection on a lot of dual turbo 1200+ horsepower setups which require a lot more then a 400 horsepower engine. Just varies.
Rodney
Old Jan 22, 2010 | 01:50 AM
  #269
AIS's Avatar
AIS
www.AlcoholInjectionSystems.com
Old Jan 22, 2010 | 08:57 AM
  #270
rico's Avatar
im thinking 20-22 psi. 320-370 hp range maybe for now
Old Jan 26, 2010 | 05:48 PM
  #271
AIS's Avatar
AIS
On a set up like yours I would use a number 2-3 GPH nozzle pre-turbo when using a 50/50 mix or washer fluid. If using pure methanol run a number 5 GPH nozzle. Let me know if you have any other questions or how I can help.
Rodney
Old Feb 21, 2010 | 03:14 PM
  #272
AIS's Avatar
AIS
Old Apr 22, 2010 | 10:10 AM
  #273
s h a y n e's Avatar
hello AIS Ive been reading the prior posts and was curious if you could explain to me if metanol would be useful on a fully bolted NA L61, i know its effects are really worth while for FI applications but I was playing with the idea, I would need tuning correct?
Old Apr 22, 2010 | 08:18 PM
  #274
hiltu's Avatar
Rodney
that high of a flow rate prior to the turbo? I thought you wanna keep it .5-1GPH to not damage the turbo.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
Slick_Nick
Sep 28, 2015 09:15 PM
ThoR294
Sep 28, 2015 05:31 PM
SlowSaturn
Sep 28, 2015 11:03 AM
