Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
Questions About Water Methanol Alcohol Injection - Post Them Here
Old Nov 4, 2008 | 12:37 AM
  #176
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Originally Posted by airtonics
I didn't see this asked so if it's a repeat I apologize. I realize spraying before the supercharger is ok, but what about the intercooler? Is there a chance of puddling at the lower areas of the intake or not dispersing the water/meth evenly?
I have a cavalier with a water/meth setup and the cobalt/ion supercharger parts on my car. I've made a best pass of 12.77@112mph and I've been contemplating running a distribution block and drilling the manifold after the intercooler cores with one nozzle in each cylinder.
My concerns are that the nozzles would be very close to the combustion chamber and might not allow for proper atomization. Also a change in injector would be difficult to change, more expensive and change are limited as you'd increase in multiples of 4.
For anyone else running water/meth. Does it actually cool your supercharger? Since I installed mine, even when I ran 14 second passes or 12 second passes the charger has always been hot to the touch. I've only ever ran a 3gph nozzle so maybe I should go bigger? I've heard others with the m45 s/c setup on a cavalier that their charges stay cool with the water/meth.
Longer post than I intended, any help is appreciated.
I haven't scene anyone have any problems with puddling even when using 6 gph nozzles. With the amount of heat these superchargers make and with the nozzle sized properly you will not have any of these problems.
As for the multiple nozzles after the intercooler. I wouldn't bother with that at all. For one, it's going to be considerably more expensive as you will need a distribution block and three additional nozzle assemblies.
Two, even if you place the nozzle just before the distribution block your going to have problems with fluid siphoning out of the hoses every time you pull your foot out of it. Depending on how many inches of hose you have going from the distribution block to each nozzle you may also experience a noticeable delay the next time the system is activated.
Three, based on some other direct port experiments we have tried. The performance wasn't any better at all. Since these superchargers aren't moving any fuel through them and only air. Spraying the water methanol injection before the supercharger is really helpful as it is cooling down the rotors and the case and substantially reducing the discharge temperatures. In turn the intercooler is now receiving a much cooler air charge, then further reducing the air charge temperature.
If you decide to go with a water methanol injection system just go with a singke nozzle before the throttle body.
Let me know if you have any other questions or how i can help.
Rodney
Originally Posted by mrsilent13
ok so ive been thinking about adding meth lately.....but you are saying that i dont need a tune...but its best for me to tune....
well in my case i was having some trouble tuning for WOT....it would lean out to about 12.8 by about 5.8krpm...now if i add meth into this equation and i dont tune for it, it should richen my mix up by about .7-1 point. Which would put me at about 12.0 or so...which is still a bit lean...i havent retuned yet but im working on it...but if i tune for it...i would see something better where i can actually take advantage of my 7.5krpm redline...is this correct?
btw im an LS with Turbo, built head, cams, forged pistons/rods....and im planning on making at least 300whp
now my other question is
where would i hook the nozzle up, is it the same as the s/c guys that hook it up before the TB?
First of all. I would fix the lean condition right away or risk hurting the motor. I would pull the plugs and check them to see if they are showing any signs of melting or excessive heat on the grounding strap.
Yes, you can count on the water methanol dropping your A/F about .5-1.0 drop when using a 50/50 mix and depending on what size nozzle you use. For the type of power you plan on making I would go with at least a 5 gph single nozzle before the throttle body or a staggered nozzle arrangement with one 3 gph nozzle before the throttle body and one 3 gph nozzle before the turbo for the best results.
Give me a call directly at 801.447.2559 and I would be more then happy to explain how to tune for this and what to expect from the water methanol injection system.
Rodney
Old Nov 11, 2008 | 03:12 PM
  #177
AIS's Avatar
AIS
Let me know if you have any questions or how I can help. You can email me directly at rodney@alcoholinjectionsystems.com
Old Nov 12, 2008 | 12:53 AM
  #178
mrsilent13's Avatar
Rodney
well my car is currently not running as i have changed out my pistons and head and all the good stuff...so i need a new tune...so im not worried about the lean condition right now....that just a tuning issue i was having with trifecta....i was the 2nd turbo he tuned and we didnt finish the tuning process....so now i need a new tune.
hmmm that staggered arrangement sounds like fun...that way it would cool my turbine and feed cooler air and then it would cool down before it enters the manifold....i like the sound of that setup.....but i need to get my car running first before i can do any of this
Old Nov 12, 2008 | 11:56 AM
  #179
AIS's Avatar
AIS
Yeah, the staggered nozzle arrangement works great. With applications such as yours it's by far the best nozzle arrangement to go with. If you would like to discuss this in more detail or if you have any other questions feel free to give me a call directly at 801.447.2559. At that time I can find out more info about your engine.
Rodney
Old Nov 21, 2008 | 11:18 AM
  #180
AIS's Avatar
AIS
Many of you have asked for us to do a group buy over the past 2-3 months...and here it is. To make this as easy and uncomplicated as possible for members. No Group Buy Needed! And No Minimum Number Of Members To Qualify!
Good till the end of this month we will be offering the following discounts to CobaltS.net members on the water methanol injection systems listed below.
Have questions or need help setting up a system for you Mustang give us a call at 801.447.2559.
Stage 1 Trunk Mount Water Methanol Injection System
Normally $369.99
On Sale Now For $299.99
Click Here For Product Details
Stage 2 Trunk Mount Water Methanol Injection System
Normally $599.99
On Sale Now For$524.99
Stage 1 Basic Fender/Firewall Mount Water Methanol Kit
Normally $239.99
On Sale Now For $189.99
Stage 1 Standard Fender/Firewall Mount Water Methanol Kit
Normally $259.99
On Sale Now For $209.99
Old Dec 1, 2008 | 09:17 AM
  #181
AIS's Avatar
AIS
www.AlcoholInjectionSystems.com
Old Dec 5, 2008 | 03:50 AM
  #182
zackss's Avatar
i have been using the -20 washer fluid from wal mart mixed with a 12oz bottle of heet
when i refilled the other day i used the red bottle of heet because they were out of the yellow and i really
needed a refill. is there any risk of running the red heet rather than the yellow?
Old Dec 5, 2008 | 12:07 PM
  #183
AIS's Avatar
AIS
No it won't hurt the water methanol injection systems. I believe the red Heet is simply isopropanol alcohol. If your trying to make a 50/50 mix add 2-3 bottles.
Rodney
Old Dec 5, 2008 | 12:11 PM
  #184
thecobaltguy's Avatar
I have seen people use the washer fluid for the mix...so that is safe to do?
Old Dec 5, 2008 | 12:18 PM
  #185
AIS's Avatar
AIS
Of course. If you search on this post you will find most members use -20 degree below zero windshield washer fluid.
Let me know if you have any other questions or how I can help.
Rodney
Old Dec 5, 2008 | 03:58 PM
  #186
zackss's Avatar
Rodney
awesome thanks
Old Dec 5, 2008 | 05:50 PM
  #187
i didnt know u could use that..i have been using the pre mixed boost juice from snow performance...if i use windshield washer fluid do i mix with water and how much?
Old Dec 5, 2008 | 05:52 PM
  #188
ColeJJones's Avatar
Bannned
i have the fender mount kit... wanting to go to the trunk mount kit with steel lines... is that kit available yet? and prices
Old Dec 5, 2008 | 11:40 PM
  #189
zackss's Avatar
you shouldn't mix the washer fluid with water you should add more meth to it depending on the mixture you are looking for
i'm not sure exactly the percentage i use but i'm tuned for 1 bottle of heet which is 99% methanol mixed with 1 gallon of -20 peak washer fluid from wal-mart
Old Dec 6, 2008 | 12:31 AM
  #190
ok...i have been using boost juice from snow performance and i ran out that is why i was asking...so u can pour the washer fluid directly in the reservoir as is from bottle.
Old Dec 6, 2008 | 12:45 PM
  #191
AIS's Avatar
AIS
Hey Cole,
Yeah we've always had the rear trunk mount system with stainless steel hose option available. Our stainless steel hose comes with the hose fittings already swedged on so there is no assembly required either.
Give me a call and I'll hook you up.
Rodney
Old Dec 15, 2008 | 04:36 PM
  #192
ebristol's Avatar
When you mention that a 50/50 mix are you refering to the mix by volume or by weight?
Old Dec 16, 2008 | 10:38 AM
  #193
AIS's Avatar
AIS
By volume
Old Dec 27, 2008 | 10:23 PM
  #194
Jrhdpaintball's Avatar
do u have any information on spraying after the sc. found a kit that has a spacer that goes under the supercharger and didnt know what kinda of effects that would yield rather than before the supercharger. also would it be any benefit to spray both before and after?
Old Dec 29, 2008 | 01:12 PM
  #195
AIS's Avatar
AIS
Yes, I have some experience with spraying after the supercharger with the 03-04 Ford Cobra's which are essentially very similiar to the Cobalts in the sense that they come equipped with the larger Eaton M112 supercharger and are also equipped with an air to water intercooler.
Give me a call directly at 801.447.2559 if you would like to discuss this in detail. In short, while it did have some slight advantages in some area's but in the end it ultimately did not perform any better performances wise then spraying before the unit. Matter of fact, there are considerable advantages to spraying before the supercharger. Give me a call if you would like to discuss this in more detail.
Rodney
Old Jan 9, 2009 | 10:57 AM
  #196
AIS's Avatar
AIS
Old Jan 11, 2009 | 11:43 AM
  #197
25bduse's Avatar
Which trunk mount kit wouold be best for me?
Old Jan 11, 2009 | 04:39 PM
  #198
I have seen somebody mixes heet into washer fluid, my question is: is that needed to get the right mixture or is that just something added in?
Old Jan 12, 2009 | 02:05 PM
  #199
AIS's Avatar
AIS
All you need is a stage 1 type system with a single nozzle. We have them on sale right now. If you have questions or would like to order one feel free to give me a call directly at 801.447.2559.
Rodney
This isn't required. Its just something you can do if you want to pump up the methanol content of your windshield washer fluid.
Rodney
Old Jan 14, 2009 | 12:10 PM
  #200
So I can ust straight washer fluid then
