Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
Questions About Water Methanol Alcohol Injection - Post Them Here
Old Mar 27, 2008 | 09:56 PM
  #126
DVSk8er's Avatar
i dont know if you said this already but what kinds of washer fluids do you suggest to run. and will it say on the bottle the amount of methanol that it has?
Old Mar 28, 2008 | 10:03 AM
  #127
AIS's Avatar
AIS
Non Authorized / Non-Supporting
This is a subject which has been gone over many times here on this thread as well as others. Give me a call directly at 1.801.447.2559 and I would be more then happy to go over the various types of fluids you can use. Additionally, be sure to read our article
What types of fluids can I use with my water methanol injection system?
Old Mar 30, 2008 | 05:04 PM
  #128
cooljake73's Avatar
whats should you set ur system at like when shoul dyo have it kick in on what pound of boost.....for example im seeing bout 16.5-17 pounds of boost whats a good setting point
Old Apr 2, 2008 | 12:14 PM
  #129
AIS's Avatar
AIS
With our Stage 1 systems, you want to set the activation point between 70-80% of your total peak boost.
For example, if you were running 17psi this would be an activation point between 12-14 psi.
Let me know if you have any other questions.
Old Apr 5, 2008 | 08:45 PM
  #130
stryder's Avatar
ok it would be nice if you had instructions setup on your website on how to install your trunk mount kit. does it need a switched power source or can one just hook it to a constant source?
Old Apr 5, 2008 | 08:49 PM
  #131
M-Dub's Avatar
I love how this kit came out after I bought mine.... oh yeah I remember I posted pictures then this kit came out!
Anywho I have mine set to spray at 4psi!!
Old Apr 6, 2008 | 01:09 PM
  #132
cooljake73's Avatar
4 psi wow
Old Apr 7, 2008 | 09:08 AM
  #133
AIS's Avatar
AIS
Instructions are included with every system. Additionally, we pre-assemble and pre-wire each trunk mount system before it's packaged. Thereby, eliminating much of the work for you. We will see what we can do about loading the instructions on our website.
As for hooking it up. Use a switched power source. Do not hook this up straight to the battery.
Old Apr 22, 2008 | 12:52 PM
  #134
AIS's Avatar
AIS
www.alcoholinjectionsystems.com
Old Apr 22, 2008 | 02:07 PM
  #135
kwest's Avatar
Here's some pics of my stage 1 standard kit. I have had it on for about 4 weeks now and havent even used half of my windshield wiper fluid tan. I run a 50/50 mix of pure methanol and distilled water. has worked great so far, but will be better once i get it tuned.
Thanks Rodney.
Old Apr 22, 2008 | 03:18 PM
  #136
AIS's Avatar
AIS
Thanks Rodney.
Hey Kelby,
Looks like you finally got everything worked out. Thats great. Looks like you put sometime into the installation integrating into the factory wiring harness. Good deal. I'm happy to se you have everything up and running. Thanks again for the business and support. Hey did you get those extra stickers and how did you like them?
Rodney
Old Apr 28, 2008 | 04:12 PM
  #137
AIS's Avatar
AIS
Kelby, we've added you to our customer section. Here's the link.
http://www.alcoholinjectionsystems.c...icle_info.html
Old May 1, 2008 | 02:25 AM
  #138
kwest's Avatar
sweet man. just to make a correction you put intake manifold where it should say exhaust manifold...and ima email you the updated pictures of my engine bay clean and the wiring re-ran with wire loom.
oh and you put tenXo instead of tenZo...haha. oh and to let you know im going to be getting dynotuned with my 60lb. injectors next weekend so ill let you know how well the meth is doing after that! thanks again
Old May 1, 2008 | 04:50 PM
  #139
AIS's Avatar
AIS
Hey Kelby,
Made the corrections. Thanks for the heads up on that. Let me know how it goes on the dyno. Sounds like your set and ready. Thanks again for the support and pictures. I will see about having your pictures up dated with the new ones.
Rodney
Old May 3, 2008 | 12:57 PM
  #140
TommySSSC's Avatar
awesome thread, i live in columbus, can i come up and talk with someone in person?
Old May 6, 2008 | 11:09 AM
  #141
AIS's Avatar
AIS
PM Sent
Old May 12, 2008 | 10:55 AM
  #142
LamboW9's Avatar
wow...great thread..i'm tryna update myself with wat i can do as far as not getting tuned...i'm buyin a zzp stage 3 in a few weeks and i was debating whether i wanted to get a heat exchanger or meth kit...i was under the impression i needed a tune for meth till i read this thread...now i have a question..i'll be gettin tuned from zzp with all my mods and since noone around me can tune i'm left to do things w/o tuning till i find someone but anyway...Questions: If i get a meth kit and i'm on essentially a stage 2 tune can i expect to get a decent reduction in iat temps and some performance out of your meth kit? Down the road can I run pure methanol <makes me rich w/o tune, and a 30-50 dry shot nitrous <makes me lean w/o tune, together and expect them to even each other out w/o needing a tune?
Old May 14, 2008 | 10:33 AM
  #143
AIS's Avatar
AIS
Yes. Regardless if tuned or untuned, IAT's are going to drop by injecting water methanol into the intake. Until you get a tune start by running a 70/30 mix of water methanol to begin with. You can change up the mixture in the water meth container to bring in more or less fuel as needed. Watch your A/F with and without the water methanol injection. Without a tune you can expect to pick up about 10-15 horsepower at the tire with no knock.
Down the road can I run pure methanol? makes me rich w/o tune, and a 30-50 dry shot nitrous makes me lean w/o tune, together and expect them to even each other out w/o needing a tune?
Yes, you can change up the mixture in the water meth container to bring in more fuel if needed or to compensate for a dry shot of nitrous. Keep some water in the mix as it will help to keep the combustion chamber temps down and reduce EGT's.
We've been working much more with nitrous oxide in the last 4-5 months. Be sure to read our article on using water methanol injection with nitrous. You can click on the picture to read the article.
Old May 14, 2008 | 11:26 AM
  #144
LamboW9's Avatar
yea i read that article a while back when you's first posted it here on the website...its actually wat turned me on to learning about it but just recently i'm able to afford some of the stuff i've been dreamin bout...i missed that part about the timing retard at the bottom...i'm interested an will most likely be purchasing a kit from you's in the near future hopefully you's will work with me an help me out during my install and situating the methanol w/o tune an when i decide to run N2o with it w/o tune...thanks...big bump for your quick replies and great customer service so far
Old May 14, 2008 | 11:49 AM
  #145
AIS's Avatar
AIS
Sounds great. And if you have any specific questions email me directly at rodney@alcoholinjectionsystems.com.
Rodney
Old May 14, 2008 | 04:02 PM
  #146
TommySSSC's Avatar
thanks for the help rodney, ill be getting the stage1 kit shortly
Old May 16, 2008 | 12:16 AM
  #147
RedEcotecSS's Avatar
Sorry if it's been answered. But do you just tap into your existing windshield washer fluid if you want to go the route without the spare tank? How would one go about this? Thanks!!
P.S. any GB's coming up? Soon to be ordering a stage 1 kit fender kit!
Old May 16, 2008 | 11:37 AM
  #148
AIS's Avatar
AIS
Yes, you can simply tap into your existing windshield washer container using the supplied fitting which comes with the water methanol kit. It's a s simple as drilling a hole and inserting the fitting into it.
No GP purchases coming up. We did one about 2 months ago. Sorry. Let me know if you have any other questions or how I can help.
Rodney
Sounds great. Look forward to hearing from you.
Rodney
Old May 25, 2008 | 01:34 PM
  #149
AIS's Avatar
AIS
Old Jun 3, 2008 | 11:23 AM
  #150
AIS's Avatar
AIS
For those who are looking for a great deal on a AIS water methanol injection system. Be sure to check out our Group Purchase which will be going on till the 14th of June. Here's the link below to join in on it.
https://www.cobaltss.net/forums/alcohol-injection-systems-154/ais-meth-injection-gb-114304/
