Alcohol Injection Systems Alcohol Injection Systems is a Supporting Vendor
Questions About Water Methanol Alcohol Injection - Post Them Here
Old Jan 14, 2009 | 12:45 PM
  #201
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Originally Posted by thecobaltguy
So I can ust straight washer fluid then
Yes. Just make sure it is -20 degree's below zero type.
Old Jan 14, 2009 | 09:16 PM
  #202
thecobaltguy's Avatar
ok thanks...
Old Jan 15, 2009 | 10:33 AM
  #203
AIS's Avatar
AIS
Sure thing. Let me know if you have any other questions or how I can help.
Rodney
Old Jan 24, 2009 | 11:33 AM
  #204
RedEcotecSS's Avatar
I read the post on AIS website about windshield washer fluid and all, but Im wondering, does anyone have a specific "brand" or place they buy their windshield washer fluid? Thanks.
What did everyone wire their pump to if you mounted in the trunk?
Last edited by RedEcotecSS; Jan 24, 2009 at 11:33 AM. Reason: Automerged Doublepost
Old Jan 24, 2009 | 05:22 PM
  #205
ebristol's Avatar
Peak -20 Blue washer fluid from Walmart.
http://www.peakantifreeze.com/msds/m...h_minus_20.pdf
Old Jan 26, 2009 | 11:56 AM
  #206
AIS's Avatar
AIS
Peaks very popular. If you can't get Peak there are plenty other brands (some generic) which you can also use. Let me know if you have any other questions.
Rodney
Old Jan 26, 2009 | 12:18 PM
  #207
Area47's Avatar
Rent me! per hour
why is it. that YOUR kit, will not spray under 11psi?
Old Jan 26, 2009 | 02:26 PM
  #208
AIS's Avatar
AIS
Sure it will. Our stage 1 type systems use an adjustable diaphragm boost switch that can be adjusted to activate between 1-25 psi. The switch is adjusted using a 5/64" allen wrench.
Why do you ask?
Rodney
Old Jan 26, 2009 | 03:04 PM
  #209
Area47's Avatar
Rent me! per hour
newp. it would not spray below 11-12 psi on the trunk mount kit. i dealt with this yesterday on someones car
Old Jan 26, 2009 | 07:06 PM
  #210
ColeJJones's Avatar
Bannned
same pump and switch my car uses. i had it spraying at 7-8 psi one time.
Old Jan 26, 2009 | 07:31 PM
  #211
Area47's Avatar
Rent me! per hour
i had the screw 90% of the way out and still wouldn't spray below 11psi
Old Jan 27, 2009 | 03:21 AM
  #212
RailHomie's Avatar
I have a question that might've been asked, but there's a lot of pages here. What is the word on possibilities of corrosion in the intake/supercharger/cylinders with water/meth injection? Specifically when running higher ratios of water.
I have heard of mixtures running a water soluble oil additive to help protect from this.
Old Jan 27, 2009 | 11:30 AM
  #213
AIS's Avatar
AIS
Sounds like you were adjusting pump pressure switch and not the boost switch. Do you know for sure that your were adjusting the boost pressure switch. They both have the same size Allen screw.
No problems with corrosion within the intake or cylinders and no need for additives in the water methanol mix either. These pumps are designed for water and alcohol. If you use a petroleum type lubricants it will cause the pump to fail and will not be covered under warranty.
Old Jan 27, 2009 | 11:44 AM
  #214
well i couldn't figure out which screw was which so i unscrewed both, and went from there on a few test runs. got it spraying at 7-8psi now. stage 1 trunk mount.
would adjusting the pressure switch be bad for it? i tightened it back down after unscrewing it..
couldn't find -20* washer fluid right now. had a gallon of 0* in the garage (pure blue ****, no additives, what-so-ever. and 2 bottles of HEET (yellow bottles) so i put that in. car feels like a new machine.
  #215
AIS's Avatar
AIS
Sounds like you were adjusting pump pressure cut off switch. This is the switch which shuts the pump off once it reaches a certain pressure. You'll notice the pump will cycle (pulsate) much slower (when activated) as this screw is backed out further and further. Our pumps come preset at 150 psi. Sounds like you backed the screw out quite a ways significantly lowering pump pressure below below 100 psi.
Looking at this picture below. Center in the middle of the picture is the nipple for the boost line. Just beneath it is a round circular column which extends out and has a round hole in its center. Inside that hole is the adjusting screw for setting the pump pressure cut off switch.
Now at the very top of the screw you have a red wire with a blue female slider connector connected to a male terminal post. just behind it is a small hole with another screw in it. This is your adjusting screw for the boost switch. Hope this helps. Let me know if you have any other questions.
Old Jan 27, 2009 | 11:54 AM
  #216
bump for question on that screw.
Old Jan 27, 2009 | 12:11 PM
  #217
AIS's Avatar
AIS
If you look closely you will notice the resin around the base of the boost switch which we used to connect it to the pump. That is a completely separate piece. The boost switch is actually epoxied to the pump pressure switch which by coincidence both happen to have the same size adjusting screw.
It's not necessarily bad to adjust the pump pressure. It's just not needed as the pump pressure is already set for you. if you have turned the pump screw back in you should be just fine now.
Old Jan 27, 2009 | 12:19 PM
  #218
alright man just making sure. i still have to rewire my power to a key-on source. it's wired straight to my amp power which is constant. but other than that, i LOVE this kit. feels great.
Old Jan 30, 2009 | 12:12 PM
  #219
Took a pic inside my intake.. Is this how the nozzle is supposed to look?
Old Jan 31, 2009 | 04:51 PM
  #220
AIS's Avatar
AIS
[QUOTE=RedEcotecSS;3394767]Took a pic inside my intake.. Is this how the nozzle is supposed to look?
No, the nozzle is designed to thread in from the outside of your steel piping. You have it threaded from the inside out, connected to the nozzle holder. Just as you received the nozzle assembly as we sent it to you (assembled) is how it is to be installed. Also, it looks like you removed the o-ring and moved it to the other side as well. The o-ring is suppose to be on outlet side (tip of the nozzle with less threads) as shown below.
Old Feb 2, 2009 | 02:08 PM
  #221
[QUOTE=AIS;3400550]
so what exactly do I have wrong? any other way didn't seem logical.. that, and you told me to thread the filter part into the elbow fitting. what do i need to do to fix my mistake?
Old Feb 2, 2009 | 05:39 PM
  #222
AIS's Avatar
AIS
[QUOTE=RedEcotecSS;3408078]
Give me a call directly so we can discuss this over the phone.
Rodney
Old Feb 7, 2009 | 01:32 PM
  #223
AIS's Avatar
AIS
www.AlcoholInjectionSystems.com
Old Feb 16, 2009 | 10:50 AM
  #224
AIS's Avatar
AIS
Old Feb 16, 2009 | 11:58 PM
  #225
ColeJJones's Avatar
Bannned
Rodney thanks again for the super fast shipping and superior Meth kit you sell. the trunk kit conversion kit is sexy. cant wait to install it on my back seat delete!
back seat for the trunk kit...
trunk conversion kit
brackets and nozzle
