Calling all AEM WB Users
Does anyone else have a fitting problem with their WB? I have a 3 guage pillar pod and the damn thing doesn't fit. Any suggestions would help be great.
BTW I have a dremel and not afraid to use it!
Just trying to get other ideas before I start hacking away
sandpaper ftw - yes there are others that have had problems as well:
https://www.cobaltss.net/forums/***************************/viewtopic.php?p=5315#5315
the airbag is in the ceiling of the car not in the pillar. I ran the cable up through the grommet behind the brake pedal, up through the side of the dash (you can push it through the gap btwn the dash and door frame). used the stck boost gauge power supply since it is no longer installed and ran a seperate lead from the fuse box under the trunk for the aeroforce.
