Calling all AEM WB Users
Old Feb 28, 2007 | 03:30 PM
M88ArRamadi's Avatar
Exclamation Calling all AEM WB Users
Does anyone else have a fitting problem with their WB? I have a 3 guage pillar pod and the damn thing doesn't fit. Any suggestions would help be great.
BTW I have a dremel and not afraid to use it! Just trying to get other ideas before I start hacking away
Old Feb 28, 2007 | 04:25 PM
bc3tech's Avatar
sandpaper ftw - yes there are others that have had problems as well:
https://www.cobaltss.net/forums/***************************/viewtopic.php?p=5315#5315
Old Feb 28, 2007 | 04:30 PM
yellowcobaltss05's Avatar
mine fits fine...its on the very bottom of my pillar took a little force but it went in there not completely but enough that you cant tell that its not pushed all the way in
Old Feb 28, 2007 | 04:31 PM
06blackg85ss's Avatar
yeah you have to sand/grind/cut away the inside of the pillar pod to make it fit since it's not the standard 2 1/6 size.
Old Feb 28, 2007 | 11:47 PM
Where/how did you alll run your cable?
BTW g85SS = My meth prob was a freaking fuse!!!
Old Mar 1, 2007 | 07:11 AM
haha man... these things happen... gotta always check the little stupid things first
Old Mar 1, 2007 | 10:45 AM
g85ss = do you have pics of your pillar pod set-up?
Old Mar 1, 2007 | 10:54 AM
yeah... umm hold on a sec.
Old Mar 1, 2007 | 11:14 AM
It didn't hit your AirBag Bracket?
Old Mar 1, 2007 | 11:15 AM
Nope
Old Mar 1, 2007 | 11:30 AM
Dremel.....Here I come!!
Old Mar 1, 2007 | 11:35 AM
the airbag is in the ceiling of the car not in the pillar. I ran the cable up through the grommet behind the brake pedal, up through the side of the dash (you can push it through the gap btwn the dash and door frame). used the stck boost gauge power supply since it is no longer installed and ran a seperate lead from the fuse box under the trunk for the aeroforce.
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
