charge pipe paint help
Old Mar 25, 2012 | 04:35 PM
klutch814's Avatar
alright so i got dupli color engine paint (black) we scuffed the pipes with a red scuff pad then painted.. well some spots are rough.. we then got the bright idea of putting it in the oven on a rag..and the rag stuck to the pipe. so how do you CORRECTLY paint charge pipes?
Old Mar 25, 2012 | 04:37 PM
Omiotek's Avatar
powdercoat is the correct way.....
the only spray bomb way that works for me is if you put clear over it..... otherwise it looks like crap. light coats and cosistency is what really matters. usually prepping with 600 grit wet paper works best too.
Old Mar 25, 2012 | 04:43 PM
klutch814's Avatar
could i leave this dry then hit with 600 wet spray light coats then clear?
Old Mar 25, 2012 | 04:45 PM
Omiotek's Avatar
yeah let it dry because spray paints a real bitch to get off period...... let your sand paper soak(get proper wetsanding paper) and then use a little bit of soap in some warm water and wetsand away. get it perfectly smooth.
Old Mar 25, 2012 | 05:23 PM
klutch814's Avatar
Okay then what
Old Mar 25, 2012 | 05:33 PM
Omiotek's Avatar
let it dry completely... no water anyway. clean with a wax and grease remover let that dry(it dries fast) and then start painting. light coats in a non windy area. 3 coats should do the trick... 4 for insurance. ALLOW FOR PROPER DRY TIMES BETWEEN COATS. then clear.
Old Mar 25, 2012 | 05:36 PM
Omiotek's Avatar
technically idont like painting stuff like that because its really easy to damage. powdercoating will with stand stuff better.
Jan 12, 2016 12:01 AM
Oct 20, 2015 09:56 PM
Oct 13, 2015 09:32 PM
717ssbalt
Oct 2, 2015 04:01 PM
