Dual Projector Retrofit
Old Jan 12, 2008 | 10:58 PM
smartdude24's Avatar
Hey gang, I've been sitting on these parts for a few weeks trying to decide what I was going to do and I finally think I have a pretty clear idea of what I want.
So far I have the bezel sanded down and almost ready for paint, both projectors are mocked up in place as well as the clear side markers are cut and molded.
The next step is to get them in my car and do some aiming, followed by permanently mounting them and finishing the shrouds around each projector. Let me know what you think.
Old Jan 12, 2008 | 10:59 PM
REIGN SS's Avatar
Original Hayden Fanatic
interesting, what are you going to do for turn signals?
Old Jan 12, 2008 | 11:04 PM
saunders1986's Avatar
x2....
Old Jan 12, 2008 | 11:07 PM
lil_kano's Avatar
those look familiar. nice work man!
Old Jan 12, 2008 | 11:10 PM
blk ss/sc 1's Avatar
nicce man, im also wonderin about the turn signals
Old Jan 12, 2008 | 11:19 PM
I am either:
1. going to see if there is a yellow bulb or yellow lens for my single xenon projector and use that as my DRL and turn signal
2. look at fitting a small motorcycle turn signal near the top where the two lights meet and come to a point
3. look at fitting a small motorcycle turn signal on the far end beside the single xenon.
Obviously the easiest option would be 1, but what does everyone think about that? Does using a projector for a turn signal sound like a ridiculous idea? Thanks
Old Jan 12, 2008 | 11:22 PM
REIGN SS's Avatar
I like #2, except, at the bottom, instead of the top
Old Jan 12, 2008 | 11:26 PM
That's actually not a bad idea other... have to consider that as well.
I guess I could also just fit some high intensity amber LEDs and use those, but I want to stay away from that, the whole reason for this build was that I wanted projectors without halos or LEDs.
Switt23's Avatar
... Your like 2 steps ahead of me. I did the singels. I have the parts for doubles, just with the cold haven't started again.
If your gunna use a bulb for the DRL in the projector, do not... i repeat do not use an HID bulb. Anything requiring a ballast will die after a short period of time as they aren't ment to be turned on and off rapidly.
You probably already knew that though Looks like FXs? What type of projectors?
Old Jan 12, 2008 | 11:31 PM
That's cool man, good luck with yours.
Ya, thanks for the tip and I have already thought of that. My bi-xenons are FX35's and the xenons are some projectors out of a Volvo that actually have a nicer cutoff that the FX35's, which kind of surprised me considering I snagged that pair for only $20 on eBay
VeNoM0713's Avatar
wow.. those are awesome. real sweet job man
Old Jan 13, 2008 | 12:15 AM
Switt23's Avatar
What you making the shrouds out of? I used thin sheet metal, cut with tin snips and painted it with high quality paint. 2nd time around I'm fiberglassing it all.
Old Jan 13, 2008 | 12:39 AM
thanks Venom!
I'm utilizing the yellow 'egg yolk' from the turning signal, painting it black, cutting out a hole for the projector and gluing the chrome shroud (in the above pics) and that will be the complete shroud for that projector.
For the other projector, I will probably fiberglass some kind of contours leading up to the chrome shroud I have.
Old Jan 13, 2008 | 12:52 AM
Raven SS's Avatar
so ur gonna run 2 hid headlights?
Old Jan 13, 2008 | 01:02 AM
no, just the bi-xenons are going to be HIDs, the outer single xenons are going to be halogens and probably amber to be used a turning signals/DRL
Old Jan 13, 2008 | 01:04 AM
Raven SS's Avatar
gotcha gotcha...so if ur gonna do that then why do u need another turn signal?
and what projectors are both of those? where did u get them/
Old Jan 13, 2008 | 01:08 AM
I would only need another turn signal if I don't end up using my second set as turn signals themselves.
The bi-xenons are FX35 and the xenons are from a Volvo, both pairs I got off of eBay. The FX's were new and I got for $50 while the Volvo were used and I got for $20.
Old Jan 13, 2008 | 01:14 AM
elecblue06's Avatar
oh ****.. this is actually similar to an idea I was thinking about doing with my ion... i am eventually going to make A8 style headlights for my ion using dual projectors, I'm really looking forward to seeing how this turns out
and damn those are awesome prices makes me want to do this even more... lol once it warms up a bit junkyard shopping i go lol
Last edited by elecblue06; Jan 13, 2008 at 01:14 AM. Reason: Automerged Doublepost
Old Jan 13, 2008 | 01:15 AM
Raven SS's Avatar
so what are u gonna do with them if u use sperate turn signals?
anthonyS88's Avatar
looks nice, i should do something like that with mine, i still have high beam projectors i could fit into my housing
Old Jan 13, 2008 | 01:41 AM
Thanks everyone.
@Raven, if I do fit in separate turn signals, I will use them as always on low beams for DRL and night lights as well as when I have my high beams on, these could stay on so I have both lows and highs on at the same time (not sure if that is possible/practical).
Raven SS's Avatar
o ok cool
Old Jan 13, 2008 | 01:47 AM
elecblue06's Avatar
Thanks everyone.
if you figure out how to split themm pleasssse let me know because thats part of the problem for my set up I want to make the spot where my DRLs are now my lows and my headlights my high beams but i have no clue to how separate everything, basically i can do the labor but i have no clue about the wiring issues so if you could share it with me i'd be really thankful
Old Jan 13, 2008 | 10:53 AM
red07g5's Avatar
There is a fuse for DRLs in the fuse panel, and if you pull that fuse your DRLs wont come on any more but your high beams will. So what Im saying is its gotta be possible to separate them. You might have to run another wire from the fuse block up to the headlights though.
I have a 07 where the low beams are the DRLs.
Old Jan 13, 2008 | 10:55 AM
articzap's Avatar
You should have an HID in the turn signal area then leave the stock area for a regular headlight. HID for low and high and when you hit high, the normal high beam comes on. This will make for GREAT visibility.
